Diesel Performance: Boost Your Engine's Power!
VWGOLFIII
Post13-09-2002, 20:07    Subject: Diesel Performance: Boost Your Engine's Power! Quote
Hello.
I have a Golf III TD (diesel) manufactured in 1997, with a 1.9L engine. Does anyone have any ideas on how to get more horsepower out of the TD engine? I was thinking about increasing the turbocharger pressure or using a chip tuning solution, or something else. Maybe someone has a good idea or tips on where I can read more about it! Preferably in a good and cost-effective way.
I would be grateful for any suggestions.
Translated on 07-08-2026, 20:52.
Uwe
Post13-09-2002, 21:48    Subject: Diesel Performance: Boost Your Engine's Power! Quote
Hi!
There are many possibilities for increasing horsepower in your vehicle. All of them share one thing: if done correctly, you'll enjoy driving more and typically won't experience any limitations in terms of driving comfort or increased fuel consumption. On Rainer's homepage, you can find articles about chip tuning/power boxes as well as "10-cent tuning." You'll find a lot of information there.
Uwe
Translated on 07-08-2026, 20:53.
VWGOLFIII
Post13-09-2002, 22:09    Subject: Is that okay? Quote
Hi.
Does this also apply to a turbocharged diesel engine? I don't have a TDI! As far as I understand, this is only for TDIs.
Unfortunately, it's only a TDI with 55 kW (75 hp), but it has a 1.9-liter engine.
Translated on 07-08-2026, 20:54.
Stukov
Post14-09-2002, 6:45    Subject: Diesel Performance: Boost Your Engine's Power! Quote
Yep, that won't work for you. Your car doesn't have a 'chip' in the same way as a TDI. However, given the year of manufacture, it's possible you might have an AGR valve.
Your engine has the AAZ code, which is always good to specify. Just take a look at my website; it might help you.
http://www.golf3td.tk
Translated on 07-08-2026, 20:55.
Uwe
Post14-09-2002, 9:09    Subject: Diesel Performance: Boost Your Engine's Power! Quote
Hey Golf III!
"Sorry, I misread; I thought it was a TDI. But I think there are still things you can do to improve the performance – just not as much and it might be a bit more involved."
Uwe
Translated on 07-08-2026, 20:56.
VWGOLFIII
Post14-09-2002, 9:30    Subject: Best German Restaurants: Find Top Rated Dining Quote
Hi.
Thanks, I'll be sure to visit your site! X
The engine code is AAZ!
Translated on 07-08-2026, 20:57.
Golfmann
Post14-09-2002, 23:41    Subject: Diesel Performance: Boost Your Engine's Power! Quote
You might be able to retrofit an intercooler with a bit of ingenuity.
That would probably add about 20 horsepower.
Then you should also increase the boost pressure a bit. However, I have no idea how to do that best on an AAZ engine.
Perhaps with a steam valve on the wastegate.
You should ask someone who knows about this now.
The Golfman.
Translated on 07-08-2026, 20:58.
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts More power for standard TD Diesel Engine Technology
No new posts V-Power Diesel Diesel Engine Technology
No new posts Touran: Transfer log files to laptop On-Board Diagnostics (OBD)
No new posts Chip Tuning: More Than Just Performance Diesel Engine Technology
