schnuffelvieh Guest
08-03-2006, 15:49 Subject: Front Axle Noise: Causes and Solutions |
Okay, so it's happened to me too.
After the 'harsh' winter storms and the supposedly very cold winter, I'm now hearing some rather heavenly noises coming from my front axle.
I initially thought it might be a faulty shock absorber or salt on the tire treads, but that's not the case.
Since my 4B is equipped with Xenon headlights, there are axle sensors located on the axles. It's hard to believe, but it's true: these small, dirty things make a noise like a faulty shock absorber.
So, you should probably encounter this issue as well: First, check the wheel speed sensors. A little WD40 might provide a quick, but temporary, fix. However, a new wheel speed sensor will likely need to be installed in the near future.
Basti.
Translated on 14-09-2026, 18:32.
joegolf Profi-Schrauber
Joined: 04/28/2003 Posts: 257 Karma: +3 / -0 Location: östlich von Stuttgart
09-03-2006, 8:57 Subject: Front Axle Noise: Causes and Solutions |
I've also experienced that:
/viewtopic.php?t=10444&highlight=
Golf 7 GTI
Translated on 14-09-2026, 18:33.
schnuffelvieh Guest
09-03-2006, 10:36 Subject: Front Axle Noise: Causes and Solutions |
And so far, is it quiet, or is there still occasional trouble?
09-03-2006, 12:57 Subject: Front Axle Noise: Causes and Solutions |
schnuffelvieh wrote: | | And so far, is it quiet, or does it occasionally cause trouble again? |
So far, everything is quiet, but I'll have to wait until the weather gets drier again. However, I will lubricate the joint during the next tire change.
Golf 7 GTI
Translated on 14-09-2026, 18:34.
schnuffelvieh Guest
09-03-2006, 13:01 Subject: Front Axle Noise: Causes and Solutions |
And that is just a ball joint, and you can 'easily' take it apart? That would certainly be a good thing  .
09-03-2006, 17:29 Subject: Front Axle Noise: Causes and Solutions |
schnuffelvieh wrote: | And that's just a ball joint, and you can "easily" take it apart? That certainly wouldn't be bad  | .
I didn't disassemble it; I just applied silicone (which creeps everywhere) and moved it back and forth.
It's a rubber composite part.
Golf 7 GTI
Translated on 14-09-2026, 18:35.
schnuffelvieh Guest
09-03-2006, 20:37 Subject: Front Axle Noise: Causes and Solutions |
Okay, then I'll get started on that  because the weekend is almost here  .
