AGR Disconnect: Engine Coolant Temp. Error 00522
sulzi
Post03-05-2004, 9:40    Subject: AGR Disconnect: Engine Coolant Temp. Error 00522 Quote
1. The AGR (Abgasrückführung) system was disabled by disconnecting and blocking the hose. When the engine is cold, error code 00522 - Engine Coolant Temperature Sensor (G62) is displayed. When the engine is warm, there are no issues.
The engine is an AYM.
Could it be that a false message is being displayed, perhaps because I haven't found the correct labeling file for the AYM? Does VAGCOM always read data from the AKE?
2. Additionally, the engine is louder when idling if the EGR valve is defective. Is that okay?
Where can I find the target values for the AYM?
Otherwise, it's a great forum, and I've already learned a lot.
Best regards, sulzi.
Translated on 18-10-2026, 18:40.
Gremlin
Post03-05-2004, 10:01    Subject: AGR Removal: Engine Coolant Temp Error 00522 Quote
With a cold engine, error code 00522 - Engine Coolant Temperature Sensor (G62) is logged. When the engine is warm, there are no issues.
Since '522' has the same meaning for all other engines, I assume you're having a problem with it. It could be a broken wire, a corroded connector, etc.
The engine runs rougher with the EGR deactivated, which is normal. If you activate the EGR and adjust it to its full recirculation rate, it will run smoothly, like a diesel engine.
It results from the functionality of the 'exhaust gas recirculation' system.
CU Gremlin.
Translated on 18-10-2026, 18:42.
sulzi
Post03-05-2004, 10:17    Subject: AGR Disconnect: Engine Coolant Temp. Error 00522 Quote
'With a functioning EGR valve, there are no error messages when the engine is cold. However, if I disable the EGR valve by disconnecting the connector, I only get an error message related to the EGR valve, and nothing from the G62 sensor. This is strange and I don't understand it.'
But let's see, I'll investigate this further.
Translated on 18-10-2026, 18:43.
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM Error: Coolant Temperature Sensor (G2) On-Board Diagnostics (OBD)
No new posts Disconnect the battery Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI 110HP: Disconnect & Reconnect Tuning Box On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Can you reset the control unit by disconnecting the battery? Diesel Engine Technology
