Speed Sensor Gear
digger71
Post30-05-2006, 16:56    Subject: Speed Sensor Gear Quote
Hi everyone,
I have a rev limiter for a T2 gearbox.
(with an inductor) built.
Now I've heard that VW/Audi also use hall effect sensors.
They are available in 2- or 3-wire versions.
Does anyone know how they work/are verified?
Greetings
bloesch
Post30-05-2006, 19:04    Subject: Speed Sensor Gear Quote
normal, hallgeber have the following labeling:
8H = +
7 = signal
31d= -
"Hallgeber with 2 cables - I think only the French use them, because I don't know the cable connection anymore. I don't think VW used something like that either."
boki2006
Post30-05-2006, 23:18    Subject: Speed Sensor Gear Quote
The voltage of the signal in an inductive sensor is speed-dependent. At low speeds, the voltage is also relatively low.
The tension in Hallgebers remains constant.
Greetings,
Klaus
digger71
Post31-05-2006, 8:47    Subject: Speed Sensor Gear Quote
Thank you for the responses, great forum!
From Bosch, the catalog only lists 3-pole Hall sensors.
Best regards
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Workshop Action: Software Adjustment, Gearbox, 3L Lupo Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS speed sensor seized! Transmission, Chassis, Body & Interior
No new posts Drehzahlgeber G28 Defektanalyse Diesel Engine Technology
No new posts BMR fails to start after replacing speed sensor (G2).8) Diesel Engine Technology
No new posts Automatic Transmission AFN: Gearbox-Axle Assembly Oil Cha... Diesel Engine Technology
