Speed Sensor Gear
digger71
Post30-05-2006, 15:56    Subject: Speed Sensor Gear Quote
Hi everyone,
I have a rev limiter for a T2 gearbox.
(with an inductor) built.
Now I've heard that VW/Audi also use hall effect sensors.
They are available in 2- or 3-wire versions.
Does anyone know how they work/are verified?
Greetings
bloesch
Post30-05-2006, 18:04    Subject: Speed Sensor Gear Quote
normal, hallgeber have the following labeling:
8H = +
7 = signal
31d= -
"Hallgeber with 2 cables - I think only the French use them, because I don't know the cable connection anymore. I don't think VW used something like that either."
boki2006
Post30-05-2006, 22:18    Subject: Speed Sensor Gear Quote
The voltage of the signal in an inductive sensor is speed-dependent. At low speeds, the voltage is also relatively low.
The tension in Hallgebers remains constant.
Greetings,
Klaus
digger71
Post31-05-2006, 7:47    Subject: Speed Sensor Gear Quote
Thank you for the responses, great forum!
From Bosch, the catalog only lists 3-pole Hall sensors.
Best regards
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Workshop Action: Software Adjustment, Gearbox, 3L Lupo Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS speed sensor seized! Transmission, Chassis, Body & Interior
No new posts Tachometer G28: Troubleshooting and Diagnosis Diesel Engine Technology
No new posts BMR fails to start after replacing speed sensor (G2).8) Diesel Engine Technology
No new posts Automatic Transmission AFN: Oil Change, Gearbox. Diesel Engine Technology
