AC Compressor Installation: No Refrigerant Needed?
Jan03
2010 Volkswagen Polo
Post17-04-2009, 20:14    Subject: AC Compressor Installation: No Refrigerant Needed? Quote
Hi.
I have a completely empty air conditioning system and I would like to reattach the compressor and then have the system filled. Can I assume that the magnetic clutch completely decouples the compressor, even in a system without pressure, which therefore doesn't offer much resistance to the compressor, and that it might therefore rotate slightly?
Or will I end up damaging the compressor on the way to the workshop because there's no lubricant in it?
/Jan
Translated on 14-09-2026, 19:27.
Post17-04-2009, 20:31    Subject: AC Compressor Installation: No Refrigerant Needed? Quote
HI.
Nothing can happen because the low-pressure switch prevents the magnetic coupling from engaging; if necessary, you can even disconnect the plug to that switch.
However, the compressor must be filled with the correct amount of compressor oil before installation. If you use a filling station, the oil may end up somewhere in the system, but not necessarily where it needs to be.
And importantly, use new O-rings and lightly lubricate both the O-rings and all connection points with compressor oil, and then replace the dryer after installation.
Best regards, Rüdi.
Translated on 14-09-2026, 19:28.
Jan03
Post21-04-2009, 9:32    Subject: AC Compressor Installation: No Refrigerant Needed? Quote
Well, unfortunately, I don't have any compressor oil, and I didn't really want to buy any extra, because the system will probably be flushed before being filled anyway, so the money for the oil would be wasted.
But then I probably won't be able to avoid it.
/Jan
Translated on 14-09-2026, 19:29.
Post22-04-2009, 15:40    Subject: AC Compressor Installation: No Refrigerant Needed? Quote
/Jan
It is flushed with nitrogen, and the oil remains inside, with no adverse effects.
You won't be able to avoid pre-charging the compressor, believe me.
Translated on 14-09-2026, 19:30.
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GIII - AHU mit kurzem Riemen ohne Klimakompressor? Diesel Engine Technology
No new posts Clutch Pressure Plate Installation Guide Diesel Engine Technology
No new posts Fuel Injector Disassembly and Assembly Diesel Engine Technology
No new posts Coolant G11: Buy Online & Save! Diesel Engine Technology
