VCDS Support for MAN TGE Vans
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post29-12-2017, 19:30    Subject: VCDS Support for MAN TGE Vans Quote
Evening.
Currently, I'm wondering whether the new MAN TGE is also supported by VCDS. The TGE is essentially just the Crafter with a different grille and the MAN logo on the steering wheel. Does anyone know if the control units have been retained, or if MAN has made any changes to the software that would allow their own diagnostic system to communicate with it?
Translated on 19-09-2026, 0:28.
Post02-01-2018, 12:27    Subject: VCDS Support for MAN TGE Vans Quote
Does it have a 12V or 24V electrical system, and therefore the corresponding voltage at the diagnostic connector?
Background: The central rib of the OBD2 connector is designed differently for 24V systems to prevent damage due to excessively high operating voltage.
Translated on 19-09-2026, 0:29.
klahaui
Avatar-klahaui
dieselschrauber likes this.
Post02-01-2018, 13:39    Subject: VCDS Support for MAN TGE Vans Quote
Hello Rainer,
The TGE has a 12V electrical system.
Thilo.
Edit:
According to Ross Tech, support for VW Crafter and MAN TGE has been available since release version 17.8.0.
However, it seems that only a limited number of control units are supported. The Crafter mostly uses control units from DB, and thus also the TGE.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts TDI ECU: Does it support mileage correction? On-Board Diagnostics (OBD)
No new posts Vehicle/model not supported On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
