AFN ECU Replacement: Tuning Chip Compatibility?
sidonie
Post12-09-2006, 10:36    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
I had to replace the engine control unit (ECU) in my car (TDI-AFN in a Golf 3). It used to have a 028145702DX, and now it has a 028145702GN. My old ECU was chipped by a tuner, and I'm not sure if I can transfer that chip to the new ECU. What do you think?
Translated on 09-10-2026, 0:18.
Rudi
Post12-09-2006, 10:39    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
No. The control units have different ASICs.
Rudi
Translated on 09-10-2026, 0:19.
Rudi
Post12-09-2006, 10:46    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
'Supplement:'
The part numbers you posted look like a mix of turbocharger parts.
and MSTG... I'm guessing it's a change from 028 906 021 DF to 028 906 021 GN (which is an A4 AFN;
Okay, so don't be surprised if the engine roars, especially if you try to use the clutch to...
(To disable the graphics card).
Sure, here's the translation:
'lg' is a German abbreviation that stands for 'liebe Grüße,' which means 'best regards' or 'warm greetings.' It's commonly used in emails, letters, and other forms of communication to express affection or goodwill.
Translated on 09-10-2026, 0:20.
sidonie
Post12-09-2006, 11:19    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
Okay, I seem to have made a mistake in the line with the part numbers, sorry! The correct ones are:
028 906 021 FQ (old)
028 906 021 GN (new)
The part number you suspected, 028 906 021 DF, is therefore also incorrect!
Regarding the corrected part numbers I provided, is the ASIC also different, or is there still hope? The new control unit comes from a Passat 3B.
Translated on 09-10-2026, 0:21.
Rudi
Post12-09-2006, 11:46    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
FQ uses the same ASIC as DF, so it's not compatible.
Even though the GN comes from a Passat, it has the Audi entry-level components.
The other levels are expected to be different from those of the G3.
Besides the ASIC, other components might not fit either.
Rudi
Translated on 09-10-2026, 0:23.
sidonie
Post12-09-2006, 11:58    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
Okay, thank you for your help! I'm now going to consider whether I should replace my engine control unit again, possibly returning the currently new one (which I received like that icon_smile.gif), or having the current engine control unit re-chipped, which is also not exactly cheap.
But in principle, there's nothing stopping me from using a Passat engine control unit (ECU) in my Golf, right?
Rudi
Post12-09-2006, 12:30    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
Basically, certain things aren't going to work the way they're supposed to.
You could possibly swap the STG with Guste - why don't you ask him?
Rudi
Translated on 09-10-2026, 0:24.
sidonie
Post12-09-2006, 13:50    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
I once searched for a user with the nickname "Guste" in this forum, but I couldn't find anyone with that name! Could the nickname be spelled differently? Or maybe it's my fault, and I just couldn't find it.
Translated on 09-10-2026, 0:25.
Nebelwerfer_TDI
Post12-09-2006, 14:38    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
He is, as far as I know, called 'guste100', and he has the rank of 'Pro Mechanic', in case Rudi is referring to him (which I strongly assume, since I don't know any other 'guste'). icon_wink.gif
sidonie
Post12-09-2006, 15:34    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
Okay, I was only looking for the nickname without the "100", so thanks for the information! I'll talk to him about it, and I hope he doesn't mind.
Translated on 09-10-2026, 0:26.
Rudi
Post12-09-2006, 18:41    Subject: AFN ECU Replacement: Tuning Chip Compatibility? Quote
Guste100 is correct. Wildcard (*) rules icon_wink.gif.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Control Module Replacement: Error 00589 On-Board Diagnostics (OBD)
No new posts Tuning Chip AFN: Multiple Data Maps On-Board Diagnostics (OBD)
No new posts Tuning Chip Fails? Check Your MAF Sensor. Diesel Engine Technology
No new posts Temperature Sensor Replacement Diesel Engine Technology
