Speed signal at 6th gear is the same as 5th gear?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Uwe
Post20-10-2006, 20:38    Subject: Speed signal at 6th gear is the same as 5th gear? Quote
After I upgraded my now quite old A3 with a 110 horsepower engine and a 6-speed gearbox, the speedometer readings seem to be a bit optimistic.
In the lower speed range, I have achieved over 10% improvement. Due to the lack of a proper outlet, I haven't measured it at BAB speed yet.
Unfortunately, I don't have the reference value of my old gearbox. Could it be that the signal sender provides a few more impulses than in the old 5-speed transmission?
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
DariusPolo
Post23-10-2006, 12:33    Subject: Speed signal at 6th gear is the same as 5th gear? Translating...
[Translating...]Hallo!
...gibts auch Bilder zu deinen umbau!
Darius
Uwe
Post25-10-2006, 21:57    Subject: Speed signal at 6th gear is the same as 5th gear? Translating...
[Translating...]
Yepp, die gibts hier
Uwe
Post22-11-2006, 15:48    Subject: Speed signal at 6th gear is the same as 5th gear? Translating...
[Translating...]
*Hochschieb*, da Frage immer noch unbeantwortet ist.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post10-12-2006, 15:49    Subject: Speed signal at 6th gear is the same as 5th gear? Translating...
[Translating...]
Ja signal ist das selbe. Sogar der Stecker passte bei meinen A4 von 5 auf 6 gang
B.Eng (FH) u. KFZ Meister
Uwe
Post10-12-2006, 18:08    Subject: Speed signal at 6th gear is the same as 5th gear? Translating...
[Translating...]
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Schaltung/Synchronisierung dritter Gang (gelöst) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan/Alhambra/Galaxy(AFN) 5-Gang. Ändern 5.Gang? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts 6 Gang -Getriebe in G4 ALH mit 5 Gang Diesel Engine Technology
No new posts 5-Gang Getriebe auf 6-Gang Getriebe erweitern beim G3 AHU Diesel Engine Technology
