Type Plates After 9 Weeks & 5500 km
Go to page: 1, 2  Next
Post10-04-2007, 8:42    Subject: Type Plates After 9 Weeks & 5500 km Quote
...and I would say, you can tell.
I removed the fonts "PASSAT" and "2.0".
- Using a thin thread, carefully cut through the foam pads located between the paint and the chrome emblem.
- The Passat pads could then be easily peeled off the paint because they are extremely elastic and durable. Once loosened at one corner, they could almost be peeled off in one piece.
- The 2.0 pads stuck like crazy, and it was a constant struggle to remove them.
- Then, everything was cleaned of any adhesive residue using turpentine.
(Now I would have said that you can still see the outlines.)
- Everything was washed again with water used for cleaning.
- polished with hard wax polish.
From a normal distance, nothing is recognizable anymore. Macro shots follow...
Only the TDI is now very far to the right, abandoned and alone.
Possibly, it might also be removed later... and then changed to "PASSAT" in dark chrome, which would then be converted to "PS SATT" icon_smile.gif.
Translated on 12-09-2026, 0:15.
Maxx1278
Avatar-Maxx1278
Post10-04-2007, 9:05    Subject: Type Plates: After 9 Weeks & 5500 km Quote
dieselmartin wrote:
It might also disappear later... and then be changed to "PASSAT" in dark chrome, which would then be converted to "PS SATT" icon_smile.gif
That's really a good idea: PS SATT icon_lol.gif.
Translated on 12-09-2026, 0:18.
Post10-04-2007, 17:52    Subject: Type Plates After 9 Weeks & 5500 km Quote
I made a mistake.
You can't see anything of the distant symbols.
What's noticeable is the clear difference between the "simply washed" sections of the tailgate and the polished areas. (I had only just polished the areas where the symbols were located).
and that's how it looks (should I also remove the TDI?).
 File size:  54.34 KB
 Viewed:  1250 times
tdi pumpe düse
Post10-04-2007, 20:10    Subject: Type Plates After 9 Weeks & 5500 km Quote
Martin, please change that, it looks so awful.
Translated on 12-09-2026, 0:19.
Post10-04-2007, 20:47    Subject: Type Plates After 9 Weeks & 5500 km Quote
Okay, like this:
(is retouched)
 File size:  54.26 KB
 Viewed:  1405 times
Post11-04-2007, 9:14    Subject: Type Plates After 9 Weeks & 5500 km Quote
I would prefer the "PS SATT" option, and keep the TDI (either leave it as is or potentially move it).
That is a clear message icon_wink.gif.
Maxx1278
Avatar-Maxx1278
Post11-04-2007, 9:15    Subject: Type Plates After 9 Weeks & 5500 km Quote
I would also get rid of the TDI.
It really looks lost in the massive rear icon_smile.gif.
However, it would fit again in conjunction with "PS SATT".
Best regards.
Maxx.
Translated on 12-09-2026, 0:20.
ObenbeiMutti
Post11-04-2007, 14:04    Subject: Type Plates After 9 Weeks & 5500 km Quote
I would like to point out that the term 'PS-SATT' might cause some road users to...
forced to exhibit uncomfortable, childish courtship and comparison behavior, which might be annoying.
Think about all those unbalanced drivers of 320cc motorcycles who absolutely need to know if they can keep up with one of the still relatively rare 2.0 TDI Passats that have 7 horsepower more. icon_wink.gif
Translated on 12-09-2026, 0:21.
Post11-04-2007, 14:26    Subject: Type Plates After 9 Weeks & 5500 km Quote
Well,
They usually only try to intimidate each other when I approach from behind. The other day, a Touran without license plates did this: First, it moved to the left in a slow and deliberate manner, then it moved to the right and accelerated to mark its supposed territory... but it ended at 210 icon_wink.gif.
Translated on 12-09-2026, 0:22.
ObenbeiMutti
Post11-04-2007, 15:52    Subject: Type Plates After 9 Weeks & 5500 km Quote
'Why don't you get a 1.9-inch badge and an exhaust system like the one on the A6 (even the 140hp TDI model has a dual exhaust system that would make Aston Martins envious)? Then you'd have created the right kind of environment for any potential games.'
The Sharan drivers sometimes felt very powerful, especially after the AFN model (just like all TDI drivers, including myself). A large wall in the wind and 110 horsepower sound pathetic even today, but the diesel engine turns dads with Leons/Lukas/Noahs on board into real lions icon_twisted.gif.
Translated on 12-09-2026, 0:23.
x world one
Post11-04-2007, 18:12    Subject: Type Plates After 9 Weeks & 5500 km Quote
It's quite funny to read this here icon_smile.gif.
However, I would avoid the "PS SATT" option. With 170 horsepower, you're really just in the middle of the pack these days.
What interests me, and also surprised me, when I read the data sheet from VW for the 170 hp TDI engine is that it supposedly only takes 8.8 seconds to accelerate from 0 to 100 km/h. That seems a bit low to me, considering a curb weight of 1512 kg. While the 350 Nm of torque is available from 1750 rpm, it's still a bit surprising.
Have you ever checked that with VAGCOM?
Spritmonitor
Translated on 12-09-2026, 0:24.
Post12-04-2007, 8:22    Subject: Type Plates After 9 Weeks & 5500 km Quote
Okay.
Let's ignore the PS (postscript) rumors.
I'm also going to finish the TDI project, and then I'll remove the polishing scratches from the 2.0 that I put there myself icon_evil.gif.
With the TDI-Saegen, I can take 1-2 pictures so we can create a "how-to" guide on removing the type plates.
Translated on 12-09-2026, 0:25.
Post12-04-2007, 11:20    Subject: Type Plates After 9 Weeks & 5500 km Quote
x world one wrote:
With 170 horsepower, you're more or less in the middle of the pack these days.
Yes, regarding the possible range of horsepower.
However, considering the frequency of power outputs in the "road" segment, 170 horsepower is still quite exceptional, as is a power-to-weight ratio of less than 10 for a passenger car.
icon_arrow.gif That would be an alternative for rear markings: 8.9 kg / PS instead of 2.0 TDI icon_razz.gif
Translated on 12-09-2026, 0:26.
Post12-04-2007, 11:51    Subject: Type Plates After 9 Weeks & 5500 km Quote
Okay, according to my source, the average power output of newly registered diesel engines in 2005 was in the range of 71 to 81 kW, which is significantly higher than that of gasoline engines. If you consider models like the Golf or Passat, you'll notice that the smaller engine options account for the largest number of units sold. Since these cars also represent the absolute highest number of registrations overall, this could be accurate. Of course, there's a significant spread and a good degree of variation.
I still have all the letters on my golf cart...after almost 5 years, I probably shouldn't take them off anymore.
Translated on 12-09-2026, 0:28.
Herr Antje
Post12-04-2007, 14:01    Subject: Type Plates After 9 Weeks & 5500 km Quote
After 13 years and 170,000 km, I removed the "VR6" badges because I simply don't need them anymore. Somehow, I felt like everyone wanted something from me, especially those who had already been surpassed. You can't even tell that they were ever there.
My Passat doesn't have any badges either. I just want people to think whatever they want and leave me alone. That's why my advice is to leave it as is. For me, any non-existent information doesn't come across very positively, unlike, for example, MB drivers who remove a "0" to make it look like an AMG.
Isn't it better to have more than you show, rather than the other way around?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 12-09-2026, 0:29.
Post12-04-2007, 14:19    Subject: Type Plates After 9 Weeks & 5500 km Quote
Hi.
If I had a car with a star, I would put ANYTHING on it! Of course, in the original letters icon_wink.gif.
Now, Ulf again icon_wink.gif, well, I'm just converting the performance of the most powerful production diesel engine back into comfort.
It has the advantage that I can actively help with 165 g/CO2, doing more for my hobby of paragliding (more warming, more thermals icon_twisted.gif).
Okay, I'm really stopping now. I actually thought that after 9 and a half weeks, you would start to see marks on the paint... but yesterday, I could only see the marks from my amateur polishing attempt.
Translated on 12-09-2026, 0:31.
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Graphics Card Failure After 8 Weeks? Troubleshooting. On-Board Diagnostics (OBD)
No new posts Removing type plates - when? Transmission, Chassis, Body & Interior
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
