Creaking Noise: Causes and Solutions
juri
Post20-05-2007, 14:40    Subject: Creaking Noise: Causes and Solutions Quote
hello,
I've recently started hearing a creaking noise when braking and turning left.
I initially suspected the wheel bearing, so I tightened the wheel hub slightly.
I had my car specialist check it out, and he said "definitely not the wheel bearings."
The noise only occurs when braking. If I turn into the curve normally,
I don't hear anything.
Maybe you have an idea.
My data.
VW Bora Variant, year 2000.
115 hp, 148,000 km.
Thank you in advance for your help.
Translated on 07-10-2026, 10:20.
BM
Avatar-BM
Post20-05-2007, 19:57    Subject: Creaking Noise: Causes and Solutions Quote
I don't hear anything at all.
Recently, there have been isolated cases of front suspension spring breakage in the Golf IV / Bora.
In this process, the uppermost, tapered part of the spring breaks off. The feather then rests directly on the upper dome of the spring strut. When disassembling, extreme caution is required.
The spring must be secured with a clamp before removing the shock absorber.
3B5 AJM
Translated on 07-10-2026, 10:22.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K, from KW26/97, Loud Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window Motor Noise: Clicking, Grinding Sounds Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Audi A3 2.5 TDI Engine Noise - 2003 Diesel Engine Technology
No new posts Correlation between AGR rate and noise Diesel Engine Technology
No new posts TDI Passat: Ticking Noise - Common Problem? Diesel Engine Technology
