Must the engine control unit (ECU) be unlocked after the air conditioning system is installed?
Benno
Post16-02-2004, 11:59    Subject: Must the engine control unit (ECU) be unlocked after the air conditioning system is installed? Quote
Hello everyone,
I have installed an air conditioning system in my 35i -1Z-. Everything works perfectly.
Only when the air conditioning is turned on does the engine's RPM not increase, as it should. What else is the engine control unit (ECU) informed about when the air conditioning is turned on?
I already asked VAG if the control unit would be unlocked for this.
When the master finally understood what I actually wanted, he told me: "Generally, this isn't possible. If the vehicle is already equipped with a climate control system from the factory, the control unit will be different."
Now, believe it or not, he's already told me more than I wanted to know.
Who can tell me more about this or immediately provide the login code?
Best regards, Benno
Post16-02-2004, 13:11    Subject: Re: Does the engine control unit need to be unlocked after installing the air conditioning system? Quote
Benno wrote:
Hello everyone,
Okay, so far so good, where are the problems?
It doesn't work with my standard Climatronic and the AHF either.
What's important is that when the air conditioning is turned on, the engine doesn't suddenly shut off in fright. The air conditioning signal is there for this purpose, IMHO. Almost, so that the MSTG can already give a little boost at the moment of switching on, so that the engine speed does not drop too much.
Best regards, Benno
I have no knowledge of anything that would need to be enabled for this.
Hello, Rainer
Benno
Post16-02-2004, 17:32    Subject: Must the engine control unit (ECU) be unlocked after the air conditioning system is installed? Quote
Hello Rainer
Thank you for your quick and helpful answer!
Greetings, Benno
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Interface HEX+CAN is no longer unlocked after MFT update. On-Board Diagnostics (OBD)
No new posts GRA Installation Error: Troubleshooting Guide Diesel Engine Technology
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
No new posts Noise after installation of 0.216 injectors Diesel Engine Technology
