AYM V6 Overheating: 2.5L Engine Problems
p_u
Avatar-p_u
1991 Volkswagen Passat
Post25-01-2009, 19:04    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
Unfortunately, I couldn't find anything using the forum search.
Ich habe einen A6 Avant bj 02. MKB AYM.
My engine is overheating, but the radiator and the lower hose are staying cold.
This must be the thermostat.
If so, what is the effort involved in replacing it?
Thank you in advance.
Markus
Passat Variant 35i (AAZ),Audi Avant 20020V (3B)
Audi Coupe Quattro (Typ 85/ Mkb KW),Subaru Justy
Güldner G30,Fortschritt ZT300
Gpz900R,HD 1200 Sportster
Translated on 10-09-2026, 6:29.
kuestenkuddel
Post25-01-2009, 20:45    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
Hello Markus,
Was ist mit der Heizung? Will it get hot?
If it's the thermostat, then an experienced Audi mechanic will typically need about 5 hours to complete the repair.
Best regards, Kurt.
Translated on 10-09-2026, 6:30.
p_u
Avatar-p_u
Post25-01-2009, 21:44    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
Thank you for the quick response.
The heating works perfectly. icon_biggrin.gif I also don't have any air or CO2 in the cooling system.
Markus
Translated on 10-09-2026, 6:31.
wingmaster
Avatar-wingmaster
Post25-01-2009, 22:37    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
Here's the translation:
"Coolant thermostat for the V6 TDI. Good luck. It's located behind the timing belt. You need to put the locking pin in service position, remove all the belts, both timing belts, and then remove the rear timing belt cover. Behind that is the flange where the thermostat is located. Ideally, it's best to replace it at the same time as the timing belt to avoid the expensive removal and reinstallation later."
p_u
Avatar-p_u
Post26-01-2009, 9:20    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
wingmaster wrote:
Coolant thermostat for the V6 TDI. Good luck. It's located behind the timing belt. The crossmember needs to be put in service position, all belts need to be removed, both timing belts need to be removed, and then the rear timing belt cover needs to be disassembled. Behind that is the flange where the thermostat is located. Ideally, it should be replaced at the same time as the timing belt to avoid the expensive reinstallation later.
Yawn.
I'm just back from the icon_lol.gif. It refers to either a Wapu or a thermostat. But it doesn't really make a difference, as the work involved is almost the same.
I still have 70,000 kilometers to go before I need to change the timing belt.
Markus
Translated on 10-09-2026, 6:33.
p_u
Avatar-p_u
Post26-01-2009, 12:19    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
I put him in a pot of boiling water.
The expansion is actually not a problem. You can take it out and put it back in without having to remove any belts. It's actually very easy.
It took me 1.5 hours to finish the interior work.
Markus
Translated on 10-09-2026, 6:34.
mserge
Post26-01-2009, 16:50    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 10-09-2026, 6:35.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post26-01-2009, 19:36    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
I also wanted to write something, but I thought you were going to handle everything.
The thermostat housing can be removed without having to remove any belts.
Simply push the timing belt slightly to the side with your finger, then the housing will come out, and you'll save yourself about 6 hours of work.
christians
Post26-01-2009, 20:22    Subject: AYM V6 Overheating: 2.5L Engine Problems Quote
It's doable. Getting the parts in place was a bit fiddly for me. The important thing is to be quick when installing the service panel; I don't remove the fender liners, but instead, I take out the headlight on the left side and the air filter housing on the right side.
Gruß Christian
Translated on 10-09-2026, 6:36.
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Heating Not Working? Troubleshooting Tips Transmission, Chassis, Body & Interior
No new posts Jetta JR Overheating: Causes and Solutions Diesel Engine Technology
No new posts A4 TDI: Engine Not Warming Up? Check Airflow! Transmission, Chassis, Body & Interior
No new posts Diesel Engine Heats Up Quickly - Troubleshooting Diesel Engine Technology
