Resistance Wattage Between Pin 4 & 7 (10c)
328ci
Post02-12-2002, 20:24    Subject: Resistance Wattage Between Pin 4 & 7 (10c) Quote
Hi.
Actually, the subject line says it all.
270 ohms at 1/4 watt?
Thank you.
Translated on 19-09-2026, 10:28.
Post02-12-2002, 22:19    Subject: New Car Tuning: Modifications & Upgrades Quote
Hi.
What do you want to achieve by connecting pins 4 and 7 (which connector are you referring to)?
328ci
Post03-12-2002, 11:17    Subject: Resistance Wattage Between Pin 4 & 7 (10c) Quote
According to the 10-cent tuning guide, this modification causes the Motronic system to believe that the fuel is cold, and consequently, it injects more fuel.
Translated on 19-09-2026, 10:29.
Post03-12-2002, 13:08    Subject: Resistance Wattage Between Pin 4 & 7 (10c) Quote
328ci wrote:
According to the 10 cent tuning guide, this causes the Motronic to believe that the fuel is cold, and it injects more fuel.
Unfortunately, that's incorrect. Cold diesel has a higher density, so the control unit reduces the fuel delivery amount when it's made to believe that the fuel is colder.
The parallel resistance causes a higher reported fuel temperature than is actually present.
I wouldn't expect too much from this resistance. Why don't you just run the performance test once with the fuel temperature sensor manipulated and once without, and let us know the differences?
Translated on 19-09-2026, 10:30.
328ci
Post03-12-2002, 15:04    Subject: Resistance Wattage Between Pin 4 & 7 (10c) Quote
Hi!
I would like to do that, provided I know how many watts the resistor should/can have? icon_smile.gif
Okay, one more quick question about the actual 10-cent tuning. I'm going to try it out later. Do I connect the potentiometer between cable 2 and 3? So, basically, I use two terminal blocks, connect a cable with a potentiometer in the middle between pin 2 and 3, and then set it to approximately 200 ohms, right?
Thank you.
Translated on 19-09-2026, 10:31.
Post03-12-2002, 16:40    Subject: Resistance Wattage Between Pin 4 & 7 (10c) Quote
328ci wrote:
Hi!
It's not critical; 1/4W is okay.
Just a quick question about the actual 10-cent tuning; I'll test that later too. I'll connect the potentiometer between cable 2 and 3, right? So, I simply use two terminal blocks to connect a cable with a potentiometer in the middle between pin 2 and 3, and then set it to approximately 200 ohms, correct?
"200 Ohms is probably a bit low; a more sensible range is likely somewhere between 1.2kOhms and 220 Ohms -> experiment to see when the limp-home mode no longer occurs."
Translated on 19-09-2026, 10:33.
No new posts Error Zünder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How many watts does a cigarette lighter provide? Transmission, Chassis, Body & Interior
No new posts Timing belt replacement: How many hours for a VW 1Z? Diesel Engine Technology
No new posts Difference between the Steuergerät for AAT and AEL? Diesel Engine Technology
No new posts LMM: Resistance and Challenges Diesel Engine Technology
