Interface HEX+CAN is no longer unlocked after MFT update.
Nusini
Post03-10-2007, 19:25    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
About 3 years ago, I purchased the HEX+CAN professional system via USB from the Dieselschraubershop. Software version was until now "VAG-COM Release 504.1"
I have been very satisfied with this so far, and it has worked perfectly.
However, I have now installed version 704 of DRV-Berlin and now almost nothing works anymore. The firmware was updated from 1.4x to 1.78 during this process. And now, basically, nothing seems to be working properly anymore.
The status in the software is set to "not unlocked"!
How can I fix this problem?
Thank you in advance for your constructive suggestions!
Swen
vagtuning
Post03-10-2007, 19:43    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
The interfaces are partner-specific.
So, get a new version of the partner from where you bought it.
There is also a download section that covers this.
Nusini
Post03-10-2007, 20:00    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
Thanks for the tip!
Unfortunately, I had to experience this bitter experience regarding the distributor partnership myself.
Where can a merchant find the latest soft and Download the firmware to fix this problem?
Post03-10-2007, 20:08    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
The latest VAG-COM version is always available in the customer's account on the online shop. Simply log in and download the 704.1 version:
http://shop.dieselschrauber.de/account.php
Hello, Rainer
Nusini
Post03-10-2007, 20:22    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
Thank you both for your quick help!
It is now running with the new version 704 and has been re-enabled.
The only drawback is that "CAN INACTIVE" is... let's see what's causing this.
Swen
Post03-10-2007, 20:28    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
Hi Swen,
CAN INACTIVE
That's because you connected the diagnostic system to a car that doesn't use a CAN bus for diagnostics icon_wink.gif
Hello, Rainer
Nusini
Post03-10-2007, 20:35    Subject: Interface HEX+CAN is no longer unlocked after DRV update. Quote
Is a Golf 4 with a 2.8l V6 engine (engine code: BDE) with a BiTurbo conversion.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 16.8.0: Channels Unavailable After Update On-Board Diagnostics (OBD)
No new posts Must the engine control unit (ECU) be unlocked after the ... Transmission, Chassis, Body & Interior
No new posts ESP 1.9D no longer boosts after assembly!! On-Board Diagnostics (OBD)
No new posts Engine (SDI) Won't Start After Tuning! Diesel Engine Technology
