{QUESTION} - Where is the best place to tap into the {TERM}?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post22-10-2007, 17:26    Subject: {QUESTION} - Where is the best place to tap into the {TERM}? Quote
I have a digital boost pressure gauge on my engine, which indicates overboosts up to 2.3 BAR. I have connected the boost pressure sensor directly next to the original boost pressure sensor. I thought that's where VW would have done it, so I did the same. The hose to the sensor is about 10 cm long and secured with zip ties (fuel hose with woven covering). This issue occurs both with and without OBD tuning. I heard that it's better to tap into the boost pressure sensor near the intake manifold, close to the exhaust recirculation. Is there something to that?
Thank you for your tips.
Best regards
Tom
Audi SQ5 8R Cvub
Back to top Profile PM Email
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post22-10-2007, 20:55    Subject: {QUESTION} - Where is the best place to tap into the {TERM}? Quote
In my opinion, it doesn't matter, because the pressure is the same everywhere in the system.
At AGR, it's simply advantageous because you can simultaneously monitor the function of the AGR if it's in operation.
ehemals G4 ASZ, jetzt G4 ARL
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Turbo Control Unit: Tapping into Boost Pressure (Image) Transmission, Chassis, Body & Interior
No new posts B4 Avant, 1Z - Best way to connect to the OBD port Transmission, Chassis, Body & Interior
No new posts Drive Shaft Damage: Best Verification Methods Transmission, Chassis, Body & Interior
No new posts Best way to glue rubber: Tips & tricks. Transmission, Chassis, Body & Interior
