Motor Mount Broken: Eye Damaged
Go to page: 1, 2  Next
cesys
Avatar-cesys
Post02-07-2007, 18:34    Subject: Motor Mount Broken: Eye Damaged Quote
Hello, I have a G4 with an AJM engine.
After 10,000 km following the timing belt replacement at 120,000 km, the mounting point for the engine mount on the right side of the engine block, in the direction of travel, has broken off.
link to a picture.
http://www.zewegriwweler.xdn.de/Bilder/DSCF0004.JPG
Has this happened to anyone else?
Translated on 19-09-2026, 5:22.
Malte1408
Post02-07-2007, 18:43    Subject: Motor Mount Broken: Eye Damaged Quote
This has happened before in this forum and in other forums as well.
It always turned out to be due to assembly errors and improperly torqued fasteners.
(Torque wrench? I don't need one, I can do it by feel...) <- Original quote from one of my former workshops.
Translated on 19-09-2026, 5:23.
Holger247
Post04-07-2007, 14:48    Subject: Motor Mount Broken: Eye Damaged Quote
Take a look at this:
https://community.dieselschrauber.org/en/viewtopic.php?t=1254
If the timing belt was replaced at the workshop, then the work was done incorrectly.
They have to stand in line for that.
GIV - 98 - ALH
Touran 5T 2.0 TDI
cesys
Avatar-cesys
Post04-07-2007, 15:52    Subject: Motor Mount Broken: Eye Damaged Quote
hello,
I've now read the article as well... The problem is that the workshop (VW dealer) doesn't see any fault on their side. Their insurance company, VVD, has commissioned an expert who confirms this. I've also commissioned my own expert, with legal support, to see how they assess the situation.
Translated on 19-09-2026, 5:24.
Post04-07-2007, 15:58    Subject: Motor Mount Broken: Eye Damaged Quote
Grossklos?
cesys
Avatar-cesys
Post04-07-2007, 17:35    Subject: Motor Mount Broken: Eye Damaged Translating...
[Translating...]
Jacob NK
cesys
Avatar-cesys
Post18-07-2007, 12:51    Subject: Motor Mount Broken: Eye Damaged Quote
Today, the expert I ordered for an assessment examined the car.
Clear result: one of the three motor mounting screws had come loose or was not properly tightened. Consequently, the threaded insert was overloaded over time and eventually broke off.
So, there's definitely a clear error during the timing belt installation... icon_lol.gif
This should ensure that the dealer covers the cost of the repair. I'm curious to see how he will react.
Translated on 19-09-2026, 5:25.
Post18-07-2007, 13:03    Subject: Motor Mount Broken: Eye Damaged Quote
With that, the dealer should cover the cost of the repair. I'm curious to see how he reacts.
"Should," "would have," and other subjunctive forms are not worth the money.
Given the costs involved, it is highly likely that this will result in a legal dispute.
- Start looking for a lawyer.
- Check if Jakob's business is a registered trade association (if so, it might be possible to resolve the issue without involving the courts).
Greetings.
Translated on 19-09-2026, 5:26.
cesys
Avatar-cesys
Post18-07-2007, 13:46    Subject: Motor Mount Broken: Eye Damaged Quote
From the very first day, everything has to be handled through a lawyer; it's impossible to do it without one.
The car dealership is part of the trade association. Let's see how things develop; I definitely returned the "black Peter" (a derogatory term).
Translated on 19-09-2026, 5:27.
BM
Avatar-BM
Post18-07-2007, 14:03    Subject: Motor Mount Broken: Eye Damaged Quote
So, there's definitely a clear error during the timing belt installation... icon_lol.gif.
"Yes, I completely agree (personally). It's probably because the lower rear screw wasn't tightened, as it's the most difficult to access."
In my opinion, it depends on how much time has passed since the timing belt was replaced.
If it's less than 6 months, the chances are good. The icon_biggrin.gif is in the position of having to prove that they worked properly, which will be difficult.
After 6 months, things become difficult because that's when the burden of proof shifts. This means you have to prove to him that he was negligent, which is also challenging. How, for example, are you going to prove that there were no material defects in the screws, or that no unauthorized person has worked on the car in the meantime?
In this case, you and your expert should first consider, before going to court, how and with what evidence the icon_biggrin.gif might be able to refute or disprove the accusation.
In plain terms, what arguments could he put forward that you cannot disprove?
It is also important that all defective parts and screws are actually present.
3B5 AJM
Translated on 19-09-2026, 5:29.
tdi pumpe düse
Post18-07-2007, 20:38    Subject: Motor Mount Broken: Eye Damaged Quote
Hello, I agree with everything you've said, but I'd like to know the vehicle's year of manufacture and which letter designates the engine type.
Because this problem was known to Volkswagen in the past, but I can give you more details once I have some data about it.
Translated on 19-09-2026, 5:31.
cesys
Avatar-cesys
Post19-07-2007, 10:40    Subject: Motor Mount Broken: Eye Damaged Quote
Volkswagen Golf IV, engine code AJM, first registration 04/2000.
tdi pumpe düse
Post19-07-2007, 19:06    Subject: Motor Mount Broken: Eye Damaged Quote
Please ask another dealer to check very thoroughly in the HST archive. There was a change to the engine block related to this problem during the model change in 2001. However, it's possible that this information was removed from the HST. A good dealer should still know about it, but I don't think it will help you much. However, it can't hurt to ask, or you could contact VW directly.
Translated on 19-09-2026, 5:32.
cesys
Avatar-cesys
Post19-07-2007, 20:04    Subject: Motor Mount Broken: Eye Damaged Quote
Thanks for the information. I think that after 7 years, Volkswagen will no longer offer any goodwill coverage for any part.
Post19-07-2007, 20:07    Subject: Motor Mount Broken: Eye Damaged Quote
"Probably not, but it's important information to have, especially if a legal dispute arises, because you could end up looking foolish. So, it's worth protecting yourself, and it doesn't cost anything."
Translated on 19-09-2026, 5:33.
cesys
Avatar-cesys
Post19-07-2007, 20:16    Subject: Motor Mount Broken: Eye Damaged Quote
Sure, asking questions doesn't cost anything, I'll look into it in the next few days. icon_biggrin.gif
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASZ Engine Mount: Find Help & Parts Now! Diesel Engine Technology
No new posts Motor Mount Repair Kit, Passenger Side. Transmission, Chassis, Body & Interior
No new posts Tuned ASZ: Vibration Issues - ZMS or Engine Mounts? Diesel Engine Technology
No new posts Engine Block Clutch Bell Diagram Diesel Engine Technology
