Golf III TDI: Remove Underbody Panel
bindpe
Karma: +5 / -2   Thank you, like it!
Post02-02-2009, 21:20    Subject: Golf III TDI: Remove Underbody Panel Quote
Hello, does anyone have instructions on how to remove the underbody cover on a G3 TDI? Is it possible to do this without a lift?
Unfortunately, I'm having a problem with my oil filter, it seems to be stuck on very tightly (rusted?). I have an oil filter chain, but it's difficult to reach it from above. How does it look from underneath the car?
Thank you for your help.
best regards
Peter.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 27-08-2026, 6:54.
neubaupe
Post03-02-2009, 12:39    Subject: Golf III TDI: Remove Underbody Panel Quote
The Seat Ibiza AFN (similar to a Golf III TDI) is actually the best car for it.
If you clean the filter from the outside and make sure it's securely attached with clean hands.
tightens (If you tighten it by hand, you can usually get it back off again).
I've tried all the tools, but there's simply not enough space.
Best regards.
peter
Translated on 27-08-2026, 6:55.
Post03-02-2009, 14:32    Subject: Golf III TDI: Remove Underbody Panel Quote
Just loosen a bunch of SW10 screws. Specifically, the ones that hold the tub in place.
It's helpful when you're putting the tractor on stands or driving it up ramps.
Translated on 27-08-2026, 6:56.
efistho
Post03-02-2009, 15:24    Subject: Golf III TDI: Remove Underbody Panel Quote
It's more difficult to install the roof rack on a Passat 35i without a lift, as the front part needs to be hooked onto the carrier. It shouldn't be a problem with a 1H model.
You can't really get to the oil filter from below either!
Best regards, efistho.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf II - Spurstange vom lenkgetriebe demontieren? Transmission, Chassis, Body & Interior
No new posts Blechfalz am Unterboden reparieren.. Transmission, Chassis, Body & Interior
No new posts Expensive engine - cheap cover Transmission, Chassis, Body & Interior
No new posts Clunking Noise Under Car When Accelerating Diesel Engine Technology
