Adjusting the engine control unit (ECU) for a VW Sharan.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
save
Post23-05-2008, 8:55    Subject: Adjusting the engine control unit (ECU) for a VW Sharan. Quote
Hello everyone.
I got this for my VW Sharan, manufactured in 1997.
Engine number: AFN. A used engine control unit was obtained.
Same VW part number as the old 028906021 CG.
Bosch Part Number: 0281 001 529
I have a VAG 1551 diagnostic tester available.
Can someone explain how to install it on the vehicle?
"On the old one, the vacuum hose burst and it was full of engine oil."
Thank you, Werner.
Translated on 20-07-2026, 14:47.
Back to top Profile PM Email
Post23-05-2008, 9:20    Subject: Adjusting the engine control unit (ECU) for a VW Sharan. Quote
Check the engine control unit coding and adjust the immobilizer (save adaptation channel 0 in the immobilizer system). That's it. It works exactly like with VAG-COM.
http://www.ross-tech.com/vag-com/cars/immobilizer2.html
Translated on 20-07-2026, 14:48.
Uwe@Ross-Tech
Post24-05-2008, 1:39    Subject: Adjusting the engine control unit (ECU) for a VW Sharan. Quote
Up to August 1997, the Sharan still had Immo 1, so it's more likely to be found here.
http://wiki.ross-tech.com/index.php/Immobilizer_I_ECU_Swapping
-Uwe-
Translated on 20-07-2026, 14:49.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wegfahrsperre im Motorsteuergerät anpassen On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Adjust the engine control unit (ECU) for Audi A3/8P On-Board Diagnostics (OBD)
No new posts Wegefahrsperre, Kombiinstrument, Motorsteuergerät anpass... Diesel Engine Technology
No new posts Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Transmission, Chassis, Body & Interior
