Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post18-05-2009, 0:04    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
Hello
I was wondering if it's normal that the illumination of the A4 8E Bi-Xenon headlights is so terrible. I have also checked the headlight alignment with VAG-COM --> it's correct. I've seen many halogen headlights that produce more light.
christians
Post22-05-2009, 22:42    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
Horrible are the in the Audi 100/A6 C4 and A6 4B-VFL.
The 8E already has the improved DEs with concentric rings, just like in the 4B-FL.
However, if they are also foggy from the inside or if the bulbs are already old, the light will definitely suffer noticeably.
Gruß Christian
Post22-05-2009, 23:59    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
christians wrote:
However, if they are also foggy from the inside or if the bulbs are already worn out, the light will certainly be affected.
Both headlights + bulbs are new! Both are original Audi!
It probably isn't the case either.
christians
Post23-05-2009, 19:14    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
Welches brand has Audi sold?
Gruß Christian
Post23-05-2009, 19:27    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
Headlights: Valeo
I don't know what a Brenner is anymore, but there was an Audi logo on it everywhere, so no accessories.
christians
Post23-05-2009, 22:12    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
Now, Hella would have been better, but it's hard to quantify.
Is the light simply dim, or is it unevenly distributed, streaky, patchy, or something else?
Gruß Christian
Post23-05-2009, 22:15    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
Simply not enough/too dark. Distribution is good.
christians
Post24-05-2009, 19:01    Subject: Question for Audi A4 8E Bi-Xenon drivers regarding illumination: I'm looking to improve the illumination provided by my Bi-Xenon headlights on my Audi A4 8E. I'm currently using the standard halogen bulbs. Could you please share your experiences and recommendations regarding: * * * * Specifically, I'm interested in: * * * Thank you for your input! Quote
I don't have an 8E myself, but as I said, there are even worse, but also better headlights. Otherwise, I would check the 8e forum on Motortalk.
With halogen lamps, it would be relatively easy to loosen the lamp's clips in the dark and then move something around inside the housing in all directions, which would allow you to see if the adjustment is correct or not. At Xenon: No idea, but high voltage.
Gruß Christian
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Codierung des APS bei Audi Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Question for Polo 6R drivers with the CAY. Transmission, Chassis, Body & Interior
No new posts Audi A4 8k conversion to xenon headlights Electrical Systems, Vehicle Electronics, Multimedia
No new posts Replacing xenon ballast, Audi A3, but how? Transmission, Chassis, Body & Interior
No new posts Grundeinstellung Xenon mit VCDS Audi A5 2014 On-Board Diagnostics (OBD)
