Gearbox for LT/Sprinter models - compatibility guide (part number)
vwSchrauber
Post13-11-2009, 12:27    Subject: Gearbox for LT/Sprinter models - compatibility guide (part number) Quote
I have a 1997 Land Rover here with a broken tooth in the gearbox. During an oil change, a whole tooth came out of the transmission.
Since the LT is a sprinter van with a TDI engine, the transmission is logically from Mercedes-Benz.
The Mercedes engine code is 711.614, and the designation is G28-5R.
Furthermore, the following is also indicated: Var. No./NA 017318/DDY 08 08 7.
My question is: which gearboxes are compatible with this vehicle? Or can I find the same one, or perhaps a slightly different one with a longer ratio, in a Sprinter? Or am I limited to using gearboxes from the LT model?
The engine is a 75 kW 2.5 R5 TDI.
Translated on 18-07-2026, 5:31.
No new posts Documentary: LD errors on the Sprinter 315CDI, two-stage ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zu welchem Getriebe passt diese Teilenummer 1H0711088B Diesel Engine Technology
No new posts KW Seal Part Number & Gearbox Seal Search Diesel Engine Technology
No new posts R-Gang defekt; welches Getriebe passt? Polo MKB AKU Diesel Engine Technology
No new posts OBD beim Mercedes Sprinter On-Board Diagnostics (OBD)
