vwSchrauber Profi-Schrauber
07-12-2009, 14:19 Subject: BLS 3C Loader: Top or Bottom? |
How should the turbocharger be removed from a Passat 3C with engine code BLS?
I unscrewed it, but I couldn't get it out. I couldn't get it out from the top, even after removing the intake manifold, and I couldn't get it out from the bottom, because the right driveshaft is in the way.
Since it's already defective, I've now removed the pressure sensor, and I took it out through the center tunnel (where the DPF also exits, if it's still there  ).
Since I don't want to/can't/am not allowed to play this game with the new loader because it's under warranty, and the VTG linkage shouldn't be adjusted, I would like you to explain to me where this thing should come out.
"Thank you."
John. selber schrauben - statt Werkstattpfusch
Translated on 16-09-2026, 18:25.
mullemaus Guest
07-12-2009, 14:29 Subject: BLS 3C Loader: Top or Bottom? |
Go down. Remove the DPF, remove the connecting pipe to the exhaust gas recirculation cooler, remove the lower support, etc., etc.
Translated on 16-09-2026, 18:26.
07-12-2009, 15:05 Subject: BLS 3C Loader: Top or Bottom? |
There was nobody inside  .
Quote: | | Remove the connecting pipe to the exhaust gas recirculation cooler | .
I have.
Quote: | | Support from below |
It's also outside...
Does the heat shield (aluminum plate) in the center tunnel now need to be removed, or will it work without it? I think I remember that it had to be removed when the DPF was replaced before *scratching head*. selber schrauben - statt Werkstattpfusch
Translated on 16-09-2026, 18:27.
chli1976 Profi-Schrauber
07-12-2009, 15:17 Subject: BLS 3C Loader: Top or Bottom? |
Doesn't the generator support need to be lowered? VCDS
Translated on 16-09-2026, 18:28.
mullemaus Guest
07-12-2009, 15:46 Subject: BLS 3C Loader: Top or Bottom? |
Is it not necessary to lower the aggregate carrier  ?
We certainly expect some level of visual acuity. }
09-12-2009, 8:02 Subject: BLS 3C Loader: Top or Bottom? |
Quote: | Doesn't one have to lower the generator carrier?
We do, of course, expect some visual work to be done | .
Oops...
Then it's better to remove the heat shield, or disassemble the charger  . selber schrauben - statt Werkstattpfusch
Translated on 16-09-2026, 18:29.
10-12-2009, 10:03 Subject: BLS 3C Loader: Top or Bottom? |
Okay, heat shield removed, power steering shroud removed, front axle lowered by 1cm, shift cables moved aside, and then it went in with carefully applied force  .
Are there any torque specifications for the 6 screws on the front axle? selber schrauben - statt Werkstattpfusch
10-12-2009, 11:18 Subject: BLS 3C Loader: Top or Bottom? |
Generator carriers:
M 12 x 110, 70 Nm + 90°, Use new screw(s).
M12 x 100, Grade 01, 70 Nm torque, Use new screw(s).
M12 x 100, Grade 02, 180°
M 12 x 90, torque setting 01, 70 Nm, use new screw(s).
M 12 x 90, Level 02, 180°. MfG. Michael
Translated on 16-09-2026, 18:30.
Profile PM Garage |
10-12-2009, 11:31 Subject: BLS 3C Loader: Top or Bottom? |
Thank you! selber schrauben - statt Werkstattpfusch
Translated on 16-09-2026, 18:31.
