Temperature Variations in Measurement Blocks
hnsteyding
Post08-01-2010, 13:55    Subject: Temperature Variations in Measurement Blocks Quote
Hello specialists,
I've just noticed some significant temperature discrepancies while reading temperature values from various measurement blocks.
Address 01: Engine (038 906 019 HH)
12:57:47 Block 007: Temperature sensor.
-5.4°C Fuel temperature (G81) -> THIS VALUE IS EXACTLY CORRECT!
0.0% Oil temperature.
-2.7°C Intake air temperature (G42) -> Not OK or what?
-3.6°C Coolant temperature (G62) -> Not OK or what?
and
Address 08: Climate Control/Heating (3B1 907 044 C)
13:04:23 Block 006: Temperatures and solar radiation.
-5.0°C calculated outdoor temperature -> is OK.
-3.0°C Temperature (G89) Intake manifold -> Not OK or what?
-5.0°C Outdoor temperature (G17) -> is OK.
2.0% Sunlight (G107)
Now, this is probably off-topic:
13:04:50 Block 007: Temperatures (interior).
Mid-range outflow (G191)
-4.0°C Foot warmer (G192) -> Is this still okay?
-2.0°C Dashboard (G56) -> Not OK or what?
-2.0°C Evaporator -> Not OK or what?
Are there some temperature sensors that are defective?
I replaced the coolant temperature (G62) sensor about a year ago (it was probably displaying -99°C or something like that, and you could tell from the engine's starting behavior).
Thank you in advance for your answers!
Mark.
Golf VII GTD 135kW
BJ: 03/2015 EZ: 04/2015
MKB: CUNA
GKB: M6F
Translated on 13-09-2026, 3:51.
Post08-01-2010, 14:36    Subject: Temperature Variations in Measurement Blocks Quote
Everything is perfectly OK. These deviations are completely normal. If all values were supposed to be the same, the car wouldn't have been able to run for at least 2 weeks, and it would have to be in a cold chamber where there is no sunlight. icon_wink.gif
Translated on 13-09-2026, 3:54.
haithamina
Post08-01-2010, 15:09    Subject: Temperature Variations in Measurement Blocks Quote
@hnsteydingViewing profile: hnsteyding:
You can read the oil temperature using VCDS via Control Module 3 in the instrument cluster, if you are looking for that temperature reading.
haithamina
Translated on 13-09-2026, 3:55.
hnsteyding
Post08-01-2010, 18:04    Subject: Temperature Variations in Measurement Blocks Quote
Thank you for the "reassuring" answers icon_wink.gif; the car was parked outside on the street for a little over a day at approximately -7°C.
Mark.
Golf VII GTD 135kW
MKB: CUNA
GKB: M6F
Post08-01-2010, 18:11    Subject: Temperature Variations in Measurement Blocks Quote
hnsteyding wrote:
The car was parked on the street for a little over a day at approximately -7°C.
Then you don't need to worry.
Translated on 13-09-2026, 3:56.
Post08-01-2010, 19:23    Subject: Temperature Variations in Measurement Blocks Quote
TDI-GTI-4-Motion wrote:
If all values were to be the same, the car would not have been able to run for at least 2 weeks, and it would need to be in a cold chamber where there is no sunlight. icon_wink.gif
Not even then, because the sensors also have a tolerance range.
-> Even in a thermally isolated environment, you would only get the same data across all channels with strictly selected sensors, or if all installed sensors happen to have the same deviation from the target resistance curve.
Translated on 13-09-2026, 3:57.
Post08-01-2010, 20:10    Subject: Temperature Variations in Measurement Blocks Quote
-> Even in a thermally isolated environment, you would only get the same data on all channels with strictly selected sensors, or if all installed sensors randomly have the same deviation from the target resistance curve.
Translated on 13-09-2026, 3:58.
No new posts Mismatched mileage readings, P0204 injector circuit malfu... Diesel Engine Technology
No new posts Temperatures at LLK PQ 34 Upload
No new posts Cold Start Problems: Engine Won't Start Below 10°C Diesel Engine Technology
No new posts Different temperatures at the outlets Transmission, Chassis, Body & Interior
