Hello everyone,
Does anyone else experience this problem?
Regarding the car: It's a Volkswagen Golf 5 4Motion with a 2.0 TDI engine (
Autoscan results at the end).
Problem: I'm experiencing a knocking/scraping sound coming from the rear right wheel that only occurs at low speeds (and is very loud).
The noise is no longer audible when the wheel is turned while it's on the jack.
Already excluded:
- No stones between brake pad/disc/caliper bracket.
- Brake pad does not crumble or detach.
- The handbrake releases smoothly and completely.
The only thing I could determine is that the right drive shaft has approximately 1 mm of play, while the left one does not. (The vehicle is parked on a level surface).
My guess is that there might be a problem with a joint or the wheel bearing.
Is that normal?
If so, how can I quickly check which one is broken?
If not, what else can/should I look at or check?
Sure, here's the translation:
"Best regards, Christian."
Code: |
Fahrzeug-Ident.-Nr.: WVWZZZ1KZ6W043xxx Kilometerstand: 51220km
00-Lenkwinkelsensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Bremsen -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: OK 0000
17-Kombiinstrument -- Status: OK 0000
18-Standheizung -- Status: Fehler 0010
19-CAN-Gateway -- Status: OK 0000
22-Allrad -- Status: OK 0000
25-Wegfahrsperre -- Status: OK 0000
42-Türelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: OK 0000
46-Komfortsystem -- Status: OK 0000
52-Türelektr. Beifahr. -- Status: OK 0000
55-Leuchtweitenreg. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Türelektr. hi. li. -- Status: OK 0000
69-Anhänger -- Status: OK 0000
72-Türelektr. hi. re. -- Status: OK 0000
Adresse 01: Motor Labeldatei: RKS\03G-906-016-BKD.lbl
Teilenummer SW: 03G 906 016 AQ HW: 028 101 184 8
Bauteil: R4 2,0L EDC G000SG 7000
Revision: 12345678 Seriennummer: VWZ7Z0E2487915
Codierung: 0000172
Betriebsnr.: WSC 01279 785 00200
Kein(e) Fehler gefunden.
Readiness: 0 0 0 0 0
Adresse 03: Bremsen Labeldatei: RKS\1K0-907-379-MK60-A.lbl
Teilenummer SW: 1K0 907 379 R HW: 1K0 907 379 R
Bauteil: ESP 4MOTION MK60 0102
Revision: 00T12001
Codierung: 0023170
Adresse 08: Klima/Heizung Labeldatei: RKS\1K0-907-044.lbl
Teilenummer: 1K0 907 044 BC
Bauteil: ClimatronicPQ35 066 0606
Adresse 09: Bordnetz Labeldatei: RKS\3C0-937-049-23-H.lbl
Teilenummer SW: 3C0 937 049 E HW: 3C0 937 049 E
Bauteil: Bordnetz-SG H37 1002
Revision: 00H37000 Seriennummer: 00000002119917
Codierung: 038B8F2701041800001400001400000000097F075C
Teilenummer: 1K1 955 119 C
Bauteil: Wischer VW350 013 0402
Codierung: 00065493
Adresse 15: Airbag Labeldatei: RKS\1K0-909-605.lbl
Teilenummer SW: 1K0 909 605 N HW: 1K0 909 605 N
Bauteil: 2E AIRBAG VW8 015 2100
Revision: 03015000 Seriennummer: 0038ED0KCCJF
Codierung: 0012869
Betriebsnr.: WSC 01269 785 00200
Adresse 16: Lenkrad Labeldatei: RKS\1K0-953-549-MY8.lbl
Teilenummer SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Bauteil: J0527 634 0070
Codierung: 0002022
Teilenummer: XXXXXXXXXXX
Bauteil: E0221 007 0050
Adresse 17: Kombiinstrument Labeldatei: RKS\1K0-920-xxx-17.lbl
Teilenummer: 1K0 920 872 B
Bauteil: KOMBIINSTRUMENT VDD 1212
Codierung: 0007103
Betriebsnr.: WSC 00805 219 58059
Adresse 18: Standheizung Labeldatei: RKS\1K0-815-007.lbl
Teilenummer: 1K0 815 007 AP
Bauteil: Standheizer 020 3602
Revision: 00020000 Seriennummer: 09011559000000
Codierung: 0001112
1 Fehler gefunden:
01406 - keine Flammenbildung
000 - - - Sporadisch
Umgebungsbedingungen:
Fehlerstatus: 00100000
Fehlerpriorität: 0
Fehlerhäufigkeit: 1
Verlernzähler: 16
Kilometerstand: 50422 km
Zeitangabe: 0
Datum: 2000.00.00
Zeit: 15:00:19
Start
Temperatur: 71.0°C
Temperatur: 67.0°C
Adresse 19: CAN-Gateway Labeldatei: RKS\1K0-907-530.lbl
Teilenummer SW: 1K0 907 530 F HW: 1K0 907 951
Bauteil: Gateway H10 0120
Revision: H10 Seriennummer: 2800105819013E
Codierung: FD3F5340070002
Adresse 22: Allrad Labeldatei: RKS\1K0-907-554.lbl
Teilenummer: 1K0 907 554 B
Bauteil: HALDEX 4Motion 0107
Codierung: 0000001
Adresse 25: Wegfahrsperre Labeldatei: RKS\1K0-920-xxx-25.lbl
Bauteil: IMMO VDD 1212
Adresse 42: Türelektr. Fahrer Labeldatei: RKS\1K0-959-701-MIN2.lbl
Teilenummer: 1K0 959 701 K
Bauteil: Tuer-SG 024 2369
Codierung: 0000180
Adresse 44: Lenkhilfe Labeldatei: RKS\1Kx-909-14x.lbl
Teilenummer: 1K1 909 144 J
Bauteil: EPS_ZFLS Kl.5 D04 1606
Adresse 46: Komfortsystem Labeldatei: RKS\1K0-959-433-MAX.clb
Teilenummer SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Bauteil: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Seriennummer: 00000000000000
Codierung: 809002085103087F2D04840560084F01E0A440
Betriebsnr.: WSC 01287 785 00200
Bauteil: Sounder n.mounted
Bauteil: NGS n.mounted
Bauteil: IRUE n.mounted
Adresse 52: Türelektr. Beifahr. Labeldatei: RKS\1K0-959-702-MIN2.lbl
Teilenummer: 1K0 959 702 K
Codierung: 0000180
Adresse 55: Leuchtweitenreg. Labeldatei: RKS\1T0-907-357.lbl
Teilenummer: 1T0 907 357
Bauteil: Dynamische LWR 0003
Codierung: 0000004
Adresse 56: Radio Labeldatei: RKS\1K0-035-1xx-56.lbl
Teilenummer: 1K0 035 186 P
Bauteil: Radio BVX 017 0023
Codierung: 0040400
Adresse 62: Türelektr. hi. li. Labeldatei: RKS\1K0-959-703-GEN2.lbl
Teilenummer: 1K0 959 703 F
Bauteil: Tuer-SG 021 2429
Codierung: 0000144
Adresse 69: Anhänger Labeldatei: RKS\8P0-907-383.lbl
Teilenummer SW: 8P0 907 383 HW: 8P0 907 383
Bauteil: ANHAENGERELEKTR H01 0010
Codierung: 0000001
Adresse 72: Türelektr. hi. re. Labeldatei: RKS\1K0-959-704-GEN2.lbl
Teilenummer: 1K0 959 704 F
Codierung: 0000144
