Burli wrote: |
Is the turbo whistle really no longer audible?? |
Hi.
As far as I know, you can't usually hear a noticeable turbocharger whine in most TDIs. And if you do, it's usually only at low RPMs or when accelerating with the car stationary.
Quote: |
| After various problems with the charging regulation and VTG adjustment, the speedometer now indicates a top speed of approximately 185 km/h, which, in my opinion, is relatively sluggish. |
- The 1Z does not have a VTG supercharger.
- 185 kilometers per hour according to the speedometer, or is that the actual speed?
- Regarding the supposed sluggishness: the DZR test usually provides clarity
Engine specifications:
1Z engine, 1.9 TDI, 90 horsepower, manufactured in August 1995.
Thank you and best regards.
Burli.
