05-03-2009, 2:25 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
Hi.
(Image)
This is supposed to be an original VW short shifter.
Apparently, everyone has the 1K0 711 046 N part installed - and that definitely can't be right?!?!?
Can someone confirm the part number 8J0 711 046 B?
Translated on 27-09-2026, 6:33.
Profile PM Garage |
07-03-2009, 2:13 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
So, 100 people have read it, and nobody cares  .
That's enough reason for me to order it, because then I'll be one of the 100 people who have it (that was a joke). But I will order it.
Then there will also be an installation guide.
Translated on 27-09-2026, 6:34.
Profile PM Garage |
vc Guest
08-03-2009, 1:39 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
The short shift linkage 8J0 711 046 B is included with the S3 models from the year 2003 onwards (?), and costs €23.50. I ordered it today, and I'm hoping it will give my A3 8P with a BKD engine the same short shift feel as the S3. According to information from another forum, you need to replace the cable clamp until the year 2005 (the question mark is from the original post) because the fixing pin on the shift linkage lever has a 10 mm pin for attaching the shift cable, along with the corresponding cable clamp. However, the new lever has an 8.5 mm pin.
Translated on 27-09-2026, 6:35.
Joined: 04/12/2002 Posts: 18117 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
08-03-2009, 9:29 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
Most likely, the hole for attaching the cable linkage is simply located closer to the axis of rotation.
A drill or a welding machine  might have also been sufficient.
If you have a picture showing the lever (I'm not sure which specific configuration the picture depicts), you can determine the same drilling position by transferring the proportions, for example, of the mounting nut.
Translated on 27-09-2026, 6:37.
Profile PM WWW Garage |
08-03-2009, 22:54 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
vc
As far as I know, the locking mechanism is included when you buy the lever.
The day after tomorrow, I will know more  .
Then there are also photos of the standard, long, and short versions (which is probably also used in the GTI Edition30).
Translated on 27-09-2026, 6:38.
Profile PM Garage |
10-03-2009, 20:29 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
Okay, please provide the text you would like me to translate from German to English.
The part has arrived.
http://tequila.homeip.net/Passat/S3_Schalthebel/
Installation depending on the weather.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
10-03-2009, 22:42 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
I'm looking forward to reading your reports  .
Heheh, the caliper is from ALDI or LIDL  . I have one too!
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 27-09-2026, 6:39.
Profile PM Email Garage |
10-03-2009, 23:26 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
People who spend so much money upgrading a car like an expensive Passat probably can't afford anything else.
Okay, otherwise, I'm not too picky about the prices when it comes to tools.
But the display is ideal for photos.
Profile PM Garage |
14-03-2009, 23:27 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
The part is installed and it drives quite nicely. It's not extremely short, but it feels a bit more responsive.
I can recommend it.
The most important change was probably that I re-lubricated the sliding joint and the selector/shift mechanism, which connects to the transmission on a single shaft (where the MQ 350 is located).
After only 37,000 kilometers, the old gear stick here shows clear signs of wear and tear.
Generally, the old lever is covered with a layer of fine, but well-adhering dirt from the front. This dirt also accumulates wonderfully in the grease of the sliding piece. Smooth shifting is quickly a thing of the past.
Translated on 27-09-2026, 6:40.
Profile PM Garage |
21-01-2011, 17:21 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
To the 1.9 TDI section, those of you who are messing around with an MQ250.
Your solution is called 8J0 711 046 A.
Translated on 27-09-2026, 6:42.
Profile PM Garage |
26-01-2011, 0:14 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
Buy it.
| Description: |
| File size: |
76.77 KB |
| Viewed: |
7491 times |
Profile PM Garage |
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
26-01-2011, 13:29 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
dieselmartin wrote: | To the 1.9 TDI section, those of you who are messing around with an MQ250.
Your solution is called 8J0 711 046 A | .
Does that also apply to a 2003 EEN?
You're welcome, haithamina.
26-01-2011, 13:49 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
Sorry.
3Bx "Audis" do not have a seat adjustment function  and therefore do not fit.
Translated on 27-09-2026, 6:43.
Profile PM Garage |
29-01-2011, 19:32 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
is now also in the golf game, and I say:
Buy, buy, buy.
Although I already have the 12% reduction in the 3C, I am very excited about the 1K with 12% less forearm luxation  .
Translated on 27-09-2026, 6:44.
Profile PM Garage |
Octavia_4x4 Schrauber
04-02-2011, 21:28 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
"Hey, since you're writing about cleaning and greasing things, I'm also having some issues with the shifting on my car, which has 240,000 km, a 6-speed transmission, and 4Motion. Would the S3 part also fit in my case?"
Shorter shift travel wouldn't actually be that bad.
Did you have to readjust the settings after that?
EDIT: If I remember correctly, the gearbox code should be ESW.
EDIT 2: If I understand correctly, and I remove that diverter lever from my machine, nothing will happen, right? Just the nut that holds it onto the shift shaft in the gearbox? Or will it fall into the gearbox? Because if that happens, I could at least clean and lubricate it from behind.
Translated on 27-09-2026, 6:45.
04-02-2011, 23:07 Subject: Gearbox Shortening: Smooth Shifting at 37k Miles |
dieselmartin wrote: | | Does it fit?: | However, it apparently doesn't fit on all M350 models: Regarding the shift lever, the 9N and 6L models have the forward-reverse lever and the up-down block one after the other, instead of facing each other.
Even with the standard version, the forward-reverse lever is so short that the cable head, when a gear is engaged, almost touches the up-down control lever.
Therefore, implementing a SWV (Steering Wheel Vibration) would require a complete redesign of the steering column actuation system...
| Description: |
| File size: |
107.46 KB |
| Viewed: |
14121 times |
| Description: |
| File size: |
76.77 KB |
| Viewed: |
5692 times |
Translated on 27-09-2026, 6:46.
Profile PM Garage |
