VCDS Installation CD Missing: Troubleshooting Guide
toni66
Avatar-toni66
Post26-12-2010, 15:32    Subject: VCDS Installation CD Missing: Troubleshooting Guide Quote
hello,
I wish you a very merry Christmas.
I have a problem.
My original VCDS installation CD is missing. If I download a version from my customer account at http://shop.dieselschrauber.de and install it, the connection to MSG doesn't work. I think I once read that you always have to install with the original CD first, and then possibly perform updates. If that's the case, what options do I have if I can't find my CD?
Thank you in advance. - Best regards, Toni.
Audi A4 Avant 2.5 tdi MKB AKE
Translated on 11-08-2026, 18:48.
mullemaus
Post26-12-2010, 15:35    Subject: VCDS Installation CD Missing: Troubleshooting Guide Quote
The standard installation package is sufficient. icon_wink.gif You have a different problem. Are other control units affected?
Translated on 11-08-2026, 18:49.
toni66
Avatar-toni66
Post26-12-2010, 15:43    Subject: VCDS Installation CD Missing: Troubleshooting Guide Quote
Hi... thanks for the quick reply... I'll see what might be causing it. Another MSG to test isn't readily available here... but the laptop already acted strangely during the installation of the USB drivers. I'll take another look. Now that I know a normally downloaded installation package is sufficient, I can rule that out as the problem.
Best regards, Toni.
Translated on 11-08-2026, 18:50.
toni66
Avatar-toni66
Post26-12-2010, 16:12    Subject: VCDS Installation CD Missing: Troubleshooting Guide Quote
ok... it's working now... it was due to the installation of the USB drivers... have a nice Boxing Day... cheers icon_smile.gif
Post26-12-2010, 19:38    Subject: VCDS Installation CD Missing: Troubleshooting Guide Quote
The original installation CD from VCDS is missing.
This is only intended as a help for the initial installation; after use, it can be disposed of. Usually, VCDS automatically downloads updates when there is internet access; otherwise, the installation package in the customer account is identical to the one on the CD.
Translated on 11-08-2026, 18:51.
No new posts Brake Bleeding with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS: Version 11.11.2 Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Important: VCDS: Register HEX-NET and HEX-V2 On-Board Diagnostics (OBD)
