mhernach Guest
02-04-2011, 20:41 Subject: Problems with the BRT system in the Sharan |
Hello everyone...
I hope someone can still help me.
I have a Sharan 2.0 TDI (BRT engine), and my MFA display shows 'Exhaust system - workshop'.
Okay, so I did that, of course, and dutifully paid the €26 for a fault diagnosis which I couldn't understand anything about. The mechanic said they would need another 2-3 hours to find the problem, as it wasn't easy to locate.
Error in the control unit:
I just finished reading that.
Saturday, April 2, 2011, 8:36:17 PM: 39957
VCDS version: RKS 10.6.3
Data as of: 20110306.
Address 01: Engine
Label file: RKS\03G-906-016-BRT.lbl
Control unit part number: 03G 906 016 JP. Hardware version: 03G 906 016 JP.
Component and/or version: R4 2.0L EDC G000SG 9330.
Encoding: 0000072
Operating number: WSC 00401 219 43411
VCID: 7AFE61DB4C59
'One error found:'
008194 - Particle filter bank 1: Malfunction.
P2002 - 000 - -
Environmental conditions:
Error status: 01110000
Error priority: 0.
Error frequency: 1.
Mileage: 175,950 km
Time: 0.
Speed: 2898 RPM
Speed: 134.0 km/h
(no unit): 0.00
(no unit): 0.00
Air mass: 75.38 g/s
Temperature: 336.0 °C
Temperature: 17.1°C
Readiness: 0 0 0 0 0
Can anyone give me a tip on which logs I need to check to narrow down the error?
I am grateful for any advice.
Best regards, Michi.
Translated on 17-07-2026, 3:56.
Joined: 04/12/2002 Posts: 18064 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
03-04-2011, 17:55 Subject: Problems with the BRT system in the Sharan |
First, check the soot level in the DPF, then see if the differential pressure sensor and temperature sensors are displaying reasonable values.
Translated on 17-07-2026, 4:00.
Profile PM WWW Garage |
mullemaus Guest
03-04-2011, 20:00 Subject: Problems with the BRT system in the Sharan |
Title: Problems with the infotainment system in the Sharan
mhernach Guest
03-04-2011, 20:12 Subject: Problems with the BRT system in the Sharan |
First, check the loading status of the DPF, then see if the differential pressure sensor and temperature sensors are displaying reasonable values.
Best regards, Rainer
Okay, I'd like to do that. With which measurement blocks can I see this data!?
I have the latest version of VCDS, and I was able to use it successfully with my old 1Z car. However, this one has so many values/parameters...
To everyone: Feel free to keep any spelling mistakes you find *lol*. Thanks!
Best regards, michi.
Translated on 17-07-2026, 4:01.
04-04-2011, 10:50 Subject: Problems with the BRT system in the Sharan |
Please refer to measurement block (MB) 67 and subsequent blocks. See the corresponding label file; within VCDS, click on the filename located in the upper left corner of the measurement block area.
Translated on 17-07-2026, 4:02.
mhernach Guest
04-04-2011, 11:15 Subject: Problems with the BRT system in the Sharan |
Thanks for the information, I'll try that today.
'lg' translates to 'best regards' or 'kindly regards' in English. It is a common abbreviation used at the end of emails and letters.
Translated on 17-07-2026, 4:03.
mhernach Guest
04-04-2011, 17:54 Subject: Problems with the BRT system in the Sharan |
Hello everyone...
I've now read out a few values...
17:30:36 Block 068: Particle filter (exhaust values II)
19.7% loading factor.
104.0 Ash content
0.0% Ash content.
17:31:40 Block 070: Particle filter (regeneration status II).
00000000 Status 4: Regeneration.
0.0 s Regeneration time.
0.0 Unsuccessful regenerations.
Successful regenerations.
17:32:38 Block 073: Diesel particulate filter (vehicle data).
36.2 liters - Consumption since regeneration.
520 km distance since regeneration.
504.0 Time since regeneration.
17:32:38 Block 074: Particle filter (exhaust values III).
0 RPM Motor speed (G28)
12.0°C Temperature before the turbocharger.
1.00 Lambda value.
0.0 mg/H Injection volume offset.
17:32:38 Block 075: Particle filter (exhaust values IV).
12.0°C Temperature before the particulate filter.
Temperature after diesel particulate filter.
'These values were recorded with the engine cold and idling.'
Translated on 17-07-2026, 4:06.
mhernach Guest
04-04-2011, 21:13 Subject: Problems with the BRT system in the Sharan |
Okay, I now have a log file.
I think everything is correct, so why am I getting this error message?
| Description: |
 Download |
| File name: |
LOG-01-067-068-074.CSV |
| File size: |
212.38 KB |
| Downloaded: |
737 times |
Translated on 17-07-2026, 4:09.
04-04-2011, 22:10 Subject: Problems with the BRT system in the Sharan |
WOW.
I've seen some that weigh more than 60 grams before... but 104?
You should be happy that it's still running at all.
Or is the BRT something "different" that doesn't have the 60g limit?
Translated on 17-07-2026, 4:10.
Profile PM Garage |
mhernach Guest
05-04-2011, 5:09 Subject: Problems with the BRT system in the Sharan |
What? Wow...
Do you mean the ash in the DPF (Diesel Particulate Filter)?
If that's a lot, I don't understand because the DPF was replaced at 120,000 km!
Could it be that this wasn't reset?
*I want my money back.*
Translated on 17-07-2026, 4:11.
05-04-2011, 8:29 Subject: Problems with the BRT system in the Sharan |
If the DPF has been replaced (and you're not driving the vehicle with a fuel consumption of 30 liters per 100 kilometers), then the replacement was likely not done correctly.
The exchange also includes resetting the ash mass.
That part really has to handle a lot, because based on my calculations and my not-so-economical burning rate, I'm already approaching nearly 200,000 kilometers before I produce 60 grams of ash.
75,000 km with 22 grams -> 60/22 * 75,000 km = 204,545 km (assuming 6.9 liters per 100 km have been consumed since the beginning).
I got 22g / 750,000 km = 0.293 (whatever).
So, you have 104 grams of ash after 176,000 kilometers: 104 / 176,000 = 0.59.
Du muesstest also 6,9 * (0.59/0.293) fast 14 l/100km verbrauchen !?!??!?!
Something is definitely wrong here.
Translated on 17-07-2026, 4:13.
Profile PM Garage |
mhernach Guest
05-04-2011, 8:41 Subject: Problems with the BRT system in the Sharan |
I also think something is off here. If we assume that it was replaced with 120,000 kilometers on the odometer (according to the workshop), then it's been running for at least 55,000 kilometers with an ash content of 104 grams...
I'm no longer sure what I should do now... Should I reset the ash counter to 50, and then have the diesel particulate filter flushed at 240,000 km?
Translated on 17-07-2026, 4:15.
mhernach Guest
05-04-2011, 9:18 Subject: Problems with the BRT system in the Sharan |
If the DPF has been replaced (and you are not driving the tractor with 30 liters per 100 kilometers), then the replacement was probably not done completely.
That part really has to handle a lot, because based on my calculations and my not-so-economical burning rate, I'm already approaching almost 200,000 kilometers before I produce 60 grams of ash.
Irgendwas stimmt da aber gewaltig nicht.
I'm sorry, I don't quite understand something here.
If I were to use your calculation and substitute different values, I no longer arrive at a real-world result.
I'm going to assume that I have collected 104 grams of ash over a distance of 55,000 kilometers (this is just an example calculation).
So, 104g / 55000 = 0.00189, which is approximately 0.000189 (shifting the decimal point three places to the left).
Okay, then (0.000189 / 0.293) * 6.9 = 0.00445.
That would mean that the more ash I have, the less I've consumed!
I don't understand anything anymore  .
My fuel consumption, according to the vehicle's onboard computer, is approximately 7.5 liters.
Please provide the text you would like me to translate from German to English. I'm ready when you are!
Translated on 17-07-2026, 4:18.
05-04-2011, 9:38 Subject: Problems with the BRT system in the Sharan |
I just removed a few powers of ten (which are then expressed in the unit "whatever"  ).
I calculated based on 104 grams per 176,000 kilometers. This results in a "smoke emission index." So, it's a value that increases as the vehicle produces more smoke.
104/176 = 0.59
If you now want to claim that the 104 grams were only added after the exchange:
104/55 = 1.89
I consume 6.9 and waste 0.293.
So, if you're driving with a Russian index of 1.89 (since the adjustment), you'll have to consume more fuel – assuming that our vehicles produce the same amount of soot from the same diesel.
6. 9 * (1.89 / 0.293) = 44 liters per 100 kilometers.
No matter when your filter was replaced, it's producing nonsense.
Therefore, it's possible that the technician wasn't skilled enough to properly set the diagnostic tool and instead entered a random value into the engine control unit (ECU), likely a much too high value instead of a zero for the ash mass.
Nobody knows for sure anymore, and you're stuck with that grumpy old thing.
"Quite decent would be:"
- swap again.
- Truly 0g ash programming.
But that costs money!
Translated on 17-07-2026, 4:22.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
05-04-2011, 9:48 Subject: Subject: Issues with the BRT system in the Sharan |
mhernach wrote: | | Der Mechaniker meinte sie müssen noch 2-3 Stunden suchen, ist nicht einfach den Fehler zu finden. |
Did this statement come from a Volkswagen dealership, or was it from the company with the red flags?
At Volkswagen, checking the ash mass is part of the regular maintenance schedule starting at 120,000 km (approximately 75,000 miles).
Translated on 17-07-2026, 4:25.
Profile PM Garage |
05-04-2011, 9:50 Subject: Problems with the BRT system in the Sharan |
Sure.
But it doesn't matter who it was.
It's important to NEVER GO THERE AGAIN!
Translated on 17-07-2026, 4:26.
Profile PM Garage |
