AGR CBBB
slg60
Post12-01-2011, 21:55    Subject: AGR CBBB Quote
Hello everyone,
"Since I'm now using a CBBB engine instead of an ARL, I wanted to ask if there are any ways to disable the EGR system on the CBBB as well. With my ARL engine, I had mechanically disabled the EGR, but I suspect the CBBB engine has some software control over it. Are there any possible solutions?"
Translated on 27-10-2026, 10:30.
Post12-01-2011, 22:50    Subject: AGR CBBB Quote
Stummel
Post13-01-2011, 19:17    Subject: AGR CBBB Quote
Hi there.
Can the EGR valve be turned down as described in the instructions on this page for the 'newer' engines? And for which engines does this apply?
Translated on 27-10-2026, 10:31.
Post13-01-2011, 20:07    Subject: AGR CBBB Quote
Stummel wrote:
Does the "newer" engines still allow for reducing the EGR (Exhaust Gas Recirculation) as described in the instructions on this page?
No, the corresponding channel is not available.
Stummel wrote:
or which engines does this apply to??
Almost everything that meets the maximum EURO 3 standard.
Stummel
Post13-01-2011, 20:37    Subject: AGR CBBB Quote
hi
mhm, that's annoying... and with the new ones, do you have to look into the tube icon_sad.gif?
Translated on 27-10-2026, 10:32.
slg60
Post13-01-2011, 21:54    Subject: AGR CBBB Quote
No, if the AGR valve is clogged, you won't be able to see through the tube because it will be completely covered in carbon deposits icon_wink.gif.
semmi32
Post19-04-2011, 22:46    Subject: AGR CBBB Quote
Can I disable the AGR (automatic air recirculation) using VCDS? Is it possible to do this mechanically with a small metal plate, or will the control module (MSG) then throw an error?
Steffen.
Translated on 27-10-2026, 10:33.
Post20-04-2011, 7:14    Subject: AGR CBBB Quote
semmi32 wrote:
Can I, therefore, not deactivate the AGR (Acoustic Resonance Chamber) using VCDS? Can this be done mechanically with a small metal plate, or will the MSG (Modular Solution Gateway) then complain?
Steffen
No and no. Everything will be meticulously monitored.
No new posts Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Chatter: Causes & Solutions Diesel Engine Technology
No new posts Asche volume at Motor CBBB Diesel Engine Technology
No new posts CBBB Software: Performance Issues? Diesel Engine Technology
No new posts Coolant pump 2 on CBBB (2.0 CR 125 kW) is defective Diesel Engine Technology
