Buddy Blaumann
17-11-2009, 19:23 Subject: Clean the DPF instead of replacing it |
I've now looked into this more closely, and I've noticed that in workshops, especially with  , a new DPF is usually installed. Those who have done some research online know that it might also work with a reverse flush.
Now there are already machines that can do that.
http://www.dartec.ch/index.php?id=20
There, the filters are cleaned using compressed air and a suction system in approximately 10 to 20 minutes.
Why is something like this offered to the industry, and why don't we get it?
I find it outrageous coming from the automotive industry.
I will definitely try that method, or use water, if I ever get a blockage.
What kind of experiences have you been able to gain?
Grüße Buddy
Golf3 Variant TDI Bj95 90PS und 203000km ohne Reparaturen
s202 C220 CDI T Bj98 125PS 133000 mit vielen Reparaturen
Translated on 12-07-2026, 1:23.
17-11-2009, 20:54 Subject: Subject: Cleaning the DPF to remove ash instead of replacing it |
Buddy wrote: | | Wieso wird soetwas für die Industrie angeboten und wir bekommen es nicht? |
Because your  won't earn anything then.
Translated on 12-07-2026, 1:25.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
17-11-2009, 20:55 Subject: Clean the DPF instead of replacing it |
Interessante Idee, aber so richtig kann ich der Maschine nicht trauen. Die Website klingt nach meinem subjektiven Empfinden irgendwie, als wäre etwas aus dem chinesischen nicht korrekt übersetzt worden: dartec wrote: | | Die Reinigung von DPF-Filtermodule kann (...) durch den Betreiber von Fahrzeuge (...) ausgerüstet mit DPF durchgefûhrt werden durch Mittel der AutoCleanIt Reinigungsmaschine. |
Anyone who puts such a text on their homepage cannot be certain of my trust  .
However, even though I don't think the cleaning machine you mentioned is ideal, I find your question very interesting. My DPF also only has about 50,000 km left before it needs to be replaced...
I imagine that the cost of replacing DPFs (Diesel Particulate Filters) might become more affordable once a larger number of them have been replaced.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 12-07-2026, 1:26.
Profile PM Garage |
Buddy Blaumann
17-11-2009, 21:25 Subject: Clean the DPF instead of replacing it |
The poor German might also be due to the fact that it was translated from Austrian German into standard German  .
Okay, putting the jokes aside, the system consumes approximately 830 liters of air at about 8 bar. So it uses a little more than a normal sandblasting booth. Additionally, it has a vacuum system attached. Basically, it's quite simple. Even with a standard workshop compressor and a vacuum cleaner, you should be able to achieve this, even if it takes longer. What excites me particularly is this simple method of cleaning. It apparently doesn't even require complex physical or chemical cleaning processes. That's why I find it so appalling that  makes so much money from this. Who knows if they are then reinstalling the uncleaned DPFs for customers, even if they have been refurbished by another company.
Grüße Buddy
Translated on 12-07-2026, 1:28.
Benni Blaumann
Joined: 11/19/2005 Posts: 302 Karma: +15 / -0 Location: Braunschweig
17-11-2009, 21:52 Subject: Clean the DPF instead of replacing it |
You will find my experiences in the search results if they are not already listed.
However, I also see problems with the new, near-engine and additive-free systems that use coated Diesel Particulate Filters (including the catalytic converter).
The coating will inevitably wear out over time.
The older, non-motorized systems are indeed just uncoated ceramic elements that can be flushed clean.
As far as I know, you can get the DPFs replaced relatively cheaply when dealing with French mechanics  .
Translated on 12-07-2026, 1:29.
goettmann Guest
18-11-2009, 8:35 Subject: Subject: Cleaning the DPF to remove ash instead of replacing it |
What is an outrage in the automotive industry?
Are you saying that you have no knowledge about DPF cleaning systems?
Sorry, aber da muss ich lachen.
DPF cleaning systems have been around for as long as the DPF itself. Any workshop can purchase these machines for a significant amount of money. Furthermore, private individuals can also buy these 'washing machines.'
The reason workshops avoid using this principle is simply due to the warranty that must be provided for the work performed. Workshops don't want to tie themselves down with that responsibility. Therefore, new parts are often used instead.
I will definitely try that method, or use water, if I ever experience constipation.
Soak in soapy water and then rinse thoroughly. This is enough for personal use!
Translated on 12-07-2026, 1:31.
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
18-11-2009, 9:48 Subject: Clean the DPF instead of replacing it |
This is what happened with the retrofitted DPF on my 1.4 HDI ("open system")! After two years and approximately 70,000 km, it took me an hour and countless rinsing cycles to get clear water out of the black mass when flushing it. I started by using hot water and dish soap.
Why was I even involved? Well, the flexible pipe section between the exhaust and the DPF was leaking and needed to be replaced. It could only be replaced after completely removing the DPF. And since it was already out...
Translated on 12-07-2026, 1:33.
vwSchrauber Profi-Schrauber
18-11-2009, 10:30 Subject: Clean the DPF instead of replacing it |
Quote: | Basically, I also see problems because the new engine-related and additive-free systems work with coated DPFs (including the catalytic converter).
The older motor-driven flushing systems are indeed just uncoated ceramic elements that can be flushed clean.
Okay!
After a charger malfunction, for example, where the DPF has been exposed to a large amount of (ash-free) engine oil, it may no longer be able to regenerate. The reason is that the catalytic layer has been poisoned. This is particularly noticeable in the temperatures.
During the regeneration of a healthy Diesel Particulate Filter (DPF), the temperature downstream of the DPF increases significantly more after ignition compared to the temperature before ignition.
If the catalytically active material is poisoned, this process will no longer occur, and the filter loading will not decrease.
Translated on 12-07-2026, 1:35.
18-11-2009, 10:45 Subject: Clean the DPF instead of replacing it |
Quote: | | Bei der Reg. eines gesunden DPF steigt die Temp. nach DPF nach erfolgter Zündung deutlich höher als die vor DPF. |
UI, I'll have to keep an eye on that. So far, I've only noticed the intense heat radiation when it was turned off while still running "in the middle."
Does it look like that? (Just kidding.)
| Description: |
| File size: |
12.65 KB |
| Viewed: |
16126 times |
Translated on 12-07-2026, 1:36.
Profile PM Garage |
18-11-2009, 12:06 Subject: Clean the DPF instead of replacing it |
Quote: | The UI, I need to observe that. So far, I've only noticed the extreme heat radiation when you stop it while it's "in the middle" of its operation.
You'll notice it even if you briefly run it in limp mode during a forced regeneration. You won't be able to keep your hand behind the exhaust pipes for long, even though there's supposedly no significant late injection (at least according to the map for regeneration mode on the 1.9 engine).
Quote: | | Does it look like this? (Just kidding) |
Unfortunately, I haven't been able to see the monoliths during the regeneration process yet. And by the time that thing is removed, it will probably be cold again  (especially with this stupid heat shield in the center tunnel  ).
Translated on 12-07-2026, 1:38.
18-11-2009, 12:31 Subject: Clean the DPF instead of replacing it |
I thought more that the exhaust pipes would glow  .
Translated on 12-07-2026, 1:39.
Profile PM Garage |
Octavia_4x4 Schrauber
18-11-2009, 18:15 Subject: Clean the DPF instead of replacing it |
However, when cleaning, especially if it's not a wet cleaning process, be sure to use respiratory protection that filters out fine dust particles. These particles are highly likely to enter the lungs, and once they do, they tend to stay there.
EMSimASZ Guest
18-11-2009, 19:36 Subject: Clean the DPF instead of replacing it |
Can't you just throw the thing into a bonfire for half an hour, let it glow properly, shake out the soot from the DPF, take it to a tuner to have the software adjusted if the DPF has been damaged by this process, so that it passes the emissions test... and that's it?
I remember that from my earlier days with mopeds.
Translated on 12-07-2026, 1:40.
18-11-2009, 19:40 Subject: Clean the DPF instead of replacing it |
Sure, you can disable the DPF through software after drilling a hole in it.
Was der Prüfer zu den gemessenen Trübungswerten sagt... dürfte ungünstig ausfallen.
Translated on 12-07-2026, 1:41.
Profile PM WWW Garage |
Buddy Blaumann
18-11-2009, 19:48 Subject: Subject: Cleaning the DPF to remove ash instead of replacing it |
goettmann wrote: | Buddy wrote: |
Are you unaware of the cleaning systems for Diesel Particulate Filters (DPFs)?
DPF cleaning systems have been around for as long as the DPF itself. Any workshop can purchase these machines for a significant amount of money. Furthermore, private individuals can also buy these "washing machines."
The reason workshops avoid using this principle is simply due to the warranty that must be provided for the work performed. Workshops don't want to tie themselves down with that responsibility. Therefore, they often only install new parts.
Place it in a soap solution and then rinse thoroughly. This is sufficient for personal use only. |
It seems they are very focused on getting other people's money. The service suffers as a result. Also, the suppliers who offer these services for commercial vehicles often don't provide them for passenger cars, which I find unacceptable. In other cases of difficult-to-estimate repairs, they usually offer alternatives to replacement. This just frustrates me.
I intended to express my opinion and point others towards alternatives.
I am aware that one cannot live on air and love alone  . I only find the relationships discussed in connection with this topic to be inappropriate.
Does soapy water suffice, or does the DPF also require something more aggressive?
Grüße Buddy
Translated on 12-07-2026, 1:43.
Bertil Profi-Schrauber
18-11-2009, 20:32 Subject: Subject: Cleaning the DPF to remove ash instead of replacing it |
Buddy wrote: |
No alternatives are offered...
Of course, alternatives are offered. Or where do you think Volkswagen gets its "X" parts from?
Quote: |
Even suppliers who are capable of doing this and sometimes offer it for commercial vehicles don't provide it for passenger cars.
Of course, they also offer this service for DPFs in passenger cars. However, it's not available to end customers! That remains the exclusive domain of the original equipment manufacturers (OEMs). And there are good reasons for that -> it concerns emissions control and ensuring its effectiveness. Therefore, this is neither suitable for a small workshop nor for hobbyists.
All DPFs that are removed are completely processed for refurbishment. However, whether they are actually suitable for refurbishment is determined only at that point. This is because possible mechanical damage also plays a role. In such cases, the parts can only be used for melting down.
Translated on 12-07-2026, 1:46.
