A6 2.5 TDI No Power: Common Problems & Fixes
chriskross
Post08-09-2011, 12:19    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
Hello!
I'm experiencing a significant loss of power in my Audi A6 4B 2.5 TDI.
The mass airflow sensor (MAF) values are very low, as is the boost pressure. The MAF sensor has already been replaced, but there has been no change.
Lt. dem icon_biggrin.gif liegt die vermutung bei einem def. Cat.
Is there a way to use VCDS to check if the catalytic converter is actually defective?
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:16.
Post08-09-2011, 13:17    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
Looking inside the KAT (catalytic converter) is the only thing that helps. Are you sure the turbocharger is being controlled correctly?
Keyword: Vacuum sleeving.
Translated on 16-10-2026, 11:17.
chriskross
Post08-09-2011, 13:44    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
Yes, the vacuum pressure is correct, and the VTG (Variable Turbine Geometry) adjustment is working properly.
There's no rattling sound when you tap the KAT either.
NW looks good too.
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:18.
mullemaus
Post08-09-2011, 14:25    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
Are you sure the pressure sensor itself is intact? icon_eek.gif Test it during startup to see if it actually engages. icon_wink.gif And when you stop, check if it retracts. }
chriskross
Post08-09-2011, 14:37    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
I tested the pressure vessel with a vacuum pump, and there was no pressure loss.
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:19.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post08-09-2011, 14:45    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
Does it also work under vacuum?
"Previously, the plastic hoses located above the splash guard, where the hose leading to the brake booster connects, were leaking."
Just try taking it apart and, if you're a smoker, try blowing a little smoke into it and see what happens.
chriskross
Post09-09-2011, 8:25    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
I replaced the catalytic converter, and now it's running wonderfully again.
I'm going to cut off the catalytic converter and post a picture if anyone is interested.
Best,
Chris
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:20.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post09-09-2011, 8:57    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
A.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
chriskross
Post09-09-2011, 14:41    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
Attached are the photos icon_wink.gif.
 File size:  80.83 KB
 Viewed:  9256 times
 File size:  114.18 KB
 Viewed:  11876 times
 File size:  94.42 KB
 Viewed:  9623 times
A6 AFB
A6 BRE DPF
Post09-09-2011, 18:37    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
It just looks really messy.
Air mass okay, and no leaks in the charge air system? Is the software original?
chriskross
Post09-09-2011, 20:38    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
The vehicle had previously been tested on a dynamometer, and it was only producing 90 horsepower at the wheels.
AFB 150 hp.
According to the customer, something was modified on the software, resulting in approximately 180 horsepower, similar to the AKE.
The vehicle has been running perfectly since the catalytic converter was replaced and has full power.
Best, Chris.
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:21.
Post09-09-2011, 20:53    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
And does it leave a trail of smoke like a steam locomotive when running at full speed?
To be honest, I wouldn't be surprised if this is a consequence of a failed attempt at "boundary limitation through air mass manipulation"...
Translated on 16-10-2026, 11:22.
Post09-09-2011, 21:46    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
I'd like to try troubleshooting here as well.
It's only a matter of time before the "new" one looks like that again.
Is it just loose soot that can be removed by scraping, or is it a really hardened mass?
Translated on 16-10-2026, 11:23.
chriskross
Post10-09-2011, 9:45    Subject: A6 2.5 TDI No Power: Common Problems & Fixes Quote
The soot can be scraped off; it's not baked on!
I no longer have the car, I have no idea who did the tuning, and I couldn't detect any excessive smoke during the test drive, it seemed perfectly normal.
Best,
Chris
A6 AFB
A6 BRE DPF
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger/Compressor System No Power - P2263 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Engine Problems: Intermittent Power Loss Diesel Engine Technology
No new posts A6 96 No Power: Troubleshooting & Fixes Diesel Engine Technology
No new posts A6 2.5 TDI: No Power? Troubleshooting Guide Diesel Engine Technology
No new posts A3 TDI: No Power? Troubleshooting Guide. On-Board Diagnostics (OBD)
