Lambda Sensor Problem: 1.4L 16V AXP Engine
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post04-02-2012, 15:14    Subject: Lambda Sensor Problem: 1.4L 16V AXP Engine Quote
Hello.
I'm having a small problem with a Golf 4, manufactured in 2001, with an AXP engine, and 88,000 km on the odometer.
He has been showing the MIL (Message Indicator Light) for some time now, and is exhibiting the two errors listed below.
Okay, I unplugged it and measured the heating element with a multimeter. The result: an open circuit.
Okay, the sensor is defective, a new one has been ordered, installed, but two days later the MIL (Malfunction Indicator Lamp) is back on and the errors are present again. icon_mad.gif
"New sensor measured, result: 2.3 ohms, which should be correct. Cable from the control unit to the sensor measured, no breaks detected. Fuse 43 is also okay."
Conclusion: The system incorrectly identifies errors where none exist.
Question: Is there still a software update available for the engine control unit (ECU), or is it already running the latest version?
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module
Label file: DRV\036-906-032-AXP.LBL
Control unit part number: 036 906 032 P.
Component and/or version: ME7.5.10 3695
Encoding: 00031
Company number: WSC 31414
VCID: 1D35EFF1BD2D
2 error codes found:
17513 - Bank 1, Probe 2; Heating circuit: Short circuit to positive.
P1105 - 35-10 - - - Intermittent.
16525 - Bank 1, Probe 2; Heating circuit: electrical fault.
P0141 - 35-10 - - - Intermittent.
Readiness: 0000 0000
Translated on 22-10-2026, 4:32.
Post04-02-2012, 21:27    Subject: Lambda Sensor Problem: 1.4L 16V AXP Engine Quote
Can you rule out a broken cable? Yes, there should be several updates available, but the question is what exactly they fix.
Translated on 22-10-2026, 4:35.
Post04-02-2012, 22:07    Subject: Lambda Sensor Problem: 1.4L 16V AXP Engine Quote
I've already checked it with a multimeter, and I've also wiggled it while measuring to see if there's any connection issue.
The cable remains completely stationary throughout its path from the control unit to the sensor.
Visually, everything looks great.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
