Polo 6N Throttle Body Initial Adjustment
Thomas_Alt
Post03-02-2012, 20:02    Subject: Polo 6N Throttle Body Initial Adjustment Quote
"I have a Polo 6N 1.4 with 44kW, manufactured in August 1999. Unfortunately, the basic throttle valve setting is not working. According to the diagnostic display, measurement block 098 is not available, and measurement block 001 is also not showing the expected values. The error memory always indicates that the basic setting is missing." Can someone perhaps help me here?
Thank you.
Thomas.
Post03-02-2012, 21:00    Subject: Polo 6N Throttle Body Initial Adjustment Quote
Please post the Autoscan results.
Thomas_Alt
Post04-02-2012, 7:33    Subject: Polo 6N Throttle Body Initial Adjustment Quote
VCDS Version: RKS 11.11.1
Data as of: 20120106.
Saturday, February 4, 2012, 07:38:13:01988
Vehicle type: 6N - VW Polo
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
Mileage: 60,270 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine, File name: RKS\030-906-027-AEX.lbl
Part number: 030 906 027 AS.
Component: MOTRONIC MP 9.0 2409
Operating number: 1037356699
VCID: 5FC67BFEDD26BC1
2 errors found:
01087 - Initial calibration not performed.
20-00 - Error in initial settings.
00533 - Idle speed control.
09:00 - Adaptation limit exceeded.
Readiness: Not available.
Address 02: Transmission Label file: None
Part number: 001 927 749 C.
Part: AG4 Transmission 001 1013
VCID: 1A300AEA8684999
"1 error found:"
00518 - Throttle potentiometer (G69)
16-10 - Signal out of tolerance - Intermittent.
Address 03: Brakes Label file: RKS\6X0-907-379.lbl
Part number: 6X0 907 379 B.
Component: ABS 30 IE CAN V004
Encoding: 05703
Operating number: WSC 05703
VCID: 438E978E518EF81
No error codes found.
Address 15: Airbag
Label file: RKS\1J0-909-60x-VW3.lbl
Part number: 1J0 909 603 E.
Component: AIRBAG VW3 - V04
Encoding: 00069
Operating number: WSC 00788
VCID: 2B5EDF2ED91E101
Address 17: Combination Instrument
Label file: RKS\6N0-919-xxx-17.lbl
Part number: 6N0 919 860 T
Component: MMO V19 COMBINATION INSTRUMENT.
Encoding: 00141
Operating Number: WSC 00001
VCID: 499285A673A2221
"1 error found:"
01039 - Coolant temperature sensor (G2).
64-10 - Currently not verifiable - Sporadic.
Address 25: Immobilizer
Label file: RKS\6H0-953-257.lbl
Part number: 6H0 953 257 B
Part number: IMMO VWZ3Z0X4309976 V71
Encoding: 09600
Operating Number: WSC 00000
VCID: 2F66CB3EED066C1
End.
Post04-02-2012, 10:26    Subject: Polo 6N Throttle Body Initial Adjustment Quote
What work has been done on the throttle valve so far?
What are the values for the throttle angle in measurement block 3 (once with no throttle, once with full throttle)?
Were the environmental conditions suitable?
See also:
Okay, I'm ready. Please provide the German text you want me to translate.
What does the idle switch (measurement block 7 under setting conditions) indicate?
If you click on the blue name of the label file in the measurement block area in the upper left corner, you can see what the individual status bits mean and check the states.
Thomas_Alt
Post04-02-2012, 12:38    Subject: Polo 6N Throttle Body Initial Adjustment Quote
"Nothing was done to the throttle body. The vehicle started, but then stalled after about 3 meters of driving. I then had it towed and replaced the spark plugs, wires, distributor cap, and rotor. It seems to be running again, but I'm experiencing occasional misfires." The error codes stored were these, and because a stud on the exhaust manifold had broken off, I also replaced this gasket.
The engine is running, although it's an automatic transmission, but it's running very unevenly and making a knocking sound in the intake.
Throttle valve settings: 6.2 and 81.2 degrees.
"Idle bit" would also be a suitable term.
The environmental conditions are also satisfactory.
Sure, no problem.
Thomas.
BM
Avatar-BM
Post04-02-2012, 13:38    Subject: Polo 6N Throttle Body Initial Adjustment Quote
The engine is running (yes, it's also an automatic), but it's running very unevenly and making a knocking sound in the intake.
Spark plug wires crossed?
Are the new spark plug wires okay?
Possibly. Was if the spark plug insulator is damaged when being screwed in?
If all other possibilities have been ruled out, there's a possibility that the camshaft or lifters are worn or stuck, which could prevent the valves from closing completely.
The throttle body component actually has nothing to do with the engine's smooth and even running. The error code appears because the engine control unit (ECU) is unable to regulate the idle speed within normal parameters.
Okay, first make sure the engine is running properly again, then clear the error codes and perform a basic reset. While you're at it, you might as well clean the throttle body.
3B5 AJM
Thomas_Alt
Post04-02-2012, 17:00    Subject: Polo 6N Throttle Body Initial Adjustment Quote
I just figured it out (I must have checked the spark plug cable three times).
He achieves compression between 12 and 13 bar (at 60,000 km).
Unfortunately, you were right about the camshaft icon_sad.gif. The hydraulic lifter on the fourth cylinder was already completely worn out.
Thomas.
Post04-02-2012, 21:29    Subject: Polo 6N Throttle Body Initial Adjustment Quote
Thank you for the feedback!
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Audi A2 Throttle Body, cannot set default settings Gasoline Engine Technology
No new posts Audi A5 throttle body Diesel Engine Technology
No new posts Throttle valve - error Diesel Engine Technology
No new posts Adapt throttle valve Lupo 16V Gasoline Engine Technology
