Problem with basic settings, headlights, PA06 bi-xenon
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post07-01-2013, 18:22    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
After replacing the headlight housing and then performing a supposedly "successful" initial adjustment, the automatic leveling function no longer works. Calibration after light activation also fails.
Error memory is empty.
While doing some research, I came across a software bug in the VCDS forum.
Is there any information available on this topic?
VCDS Version 11.11.3
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 11-07-2026, 10:16.
Post07-01-2013, 19:04    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
No, I am not aware of any bugs in that regard. The current VCDS-RKS version is 11.11.4.
Was sagen die Messwerte? Autoscan?
Translated on 11-07-2026, 10:17.
Post07-01-2013, 20:43    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
Aktuelle VCDS-RKS Version ist 11.11.4.
Update function of VCDS --> No update available at this time. icon_wink.gif Let's see.
Today, I also reset all the learning values -- now it's working again. icon_wink.gif
Translated on 11-07-2026, 10:18.
Post07-01-2013, 21:27    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
But: http://shop.dieselschrauber.de/support-downloads.php
Translated on 11-07-2026, 10:19.
Post07-01-2013, 22:04    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
Hello Rainer,
I actually wanted to wait until it updated automatically before...................icon_wink.gif
Post21-01-2013, 16:05    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
Hi.
What happened with the actual problem regarding the headlight?
Post21-01-2013, 17:24    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
Autoservice wrote:
Heute zusätzlich alle Lernwerte zurßckgesetzt -- jetzt geht´s wieder. {Micon_wink.gif
Translated on 11-07-2026, 10:20.
Post21-01-2013, 18:10    Subject: Problem with basic settings, headlights, PA06 bi-xenon Quote
Check three posts above.
Now I just have to wait for Valeo to replace the headlight because the new one has a color band at the light/dark boundary. The old headlight was fine. The bulb and electronics were taken from the old one.
According to Valeo Service: Have you ever swapped the burners horizontally?
Okay, I can do that. Just need to quickly remove and reinstall the front bumper, turn the headlights on and off, align them, adjust them, etc. However, removing the bumper from this vehicle will likely cause some damage.
Die seitlichen Halter zerbrĂśseln zumindestens. Who pays for it?
Valeo: Okay, then order a new headlight and a new bulb from your dealer.
(Possible cause according to Valeo: Burr formation (uneven edge) on the bezel for the low beam headlight.)
Replace the burner, check the headlight before installation. If not okay, replace the headlight... etc. Return the defective headlight.
Me: Question: Do the original equipment (OE) headlights come from a different production facility?
Valeo: No.
Also den Scheinwerfer bestellt -- Null Bestand bei Valeo. Liefertermin 1. February week.
Let's see what happens and who ends up paying for it. If necessary, the supplier will have to take the blame – not me!
Well, the rest of that bucket isn't much better either... The whole thing is (in my opinion) simply an outrage. Whether the new models are better remains to be seen. But maybe they won't break down and stay on the side of the road anymore, but will actually make it to the icon_lol.gif.
Translated on 11-07-2026, 10:22.
No new posts XENON...2 Bulbs, 2 Days, One Headlight General Tips
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary about foggy headlights and odors inside Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Xenon Scheinwerfer On-Board Diagnostics (OBD)
No new posts Golf 4 Xenon Headlights, Generation 2 Transmission, Chassis, Body & Interior
No new posts Grundeinstellung Xenon mit VCDS Audi A5 2014 On-Board Diagnostics (OBD)
No new posts Bremsverschleissanzeige RĂźcksetzen & Xenon Problem On-Board Diagnostics (OBD)
