30-12-2012, 13:07 Subject: Replacing the Golf 5 crossmember |
Hi.
What needs to be done if someone wants to get a new door knocker?
Sure, first of all, everything "before" has to be removed.
- Bumper
- the impact body, which is the steel beam.
Okay, here's the translation:
Now, the interesting part:
How does that work with the three coolers?
- Climate
- Water
- LLK
Greetings.
martin
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
30-12-2012, 21:50 Subject: Replacing the Golf 5 crossmember |
Officially, the water cooler, etc., must be disconnected.
For example, with the Go4, the entire radiator assembly can be detached and accessed from below after removing the locking mechanism. When the locking mechanism is removed, the assembly remains connected to the vehicle.
I think it might also be possible with the Go5, but I'm not 100% sure.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
30-12-2012, 21:58 Subject: Replacing the Golf 5 crossmember |
I read in a "guide to converting to a GTI front" that those guys left everything in place. http://hypuh.3d-nexus.de/seite2.htm
But that was a gasoline-powered car, so it already had my auxiliary liquid cooling system connected.
Since everything is new anyway  , I might as well convert it to a GT/GTI.
Profile PM Garage |
30-12-2012, 22:00 Subject: Replacing the Golf 5 crossmember |
No separation is required for the coolers.
Simply unscrew the entire assembly and then either prop it up or have an assistant hold it.
Profile PM Garage |
03-01-2013, 0:00 Subject: Replacing the Golf 5 crossmember |
Hi.
The support is connected by - but through a central brace that, in my opinion, is not so important.
A reinforcing triangle is broken off, and a retaining loop has been torn out.
Does it need to be replaced (immediately), or will it continue to work for a while longer?
| Description: |
| Defekter SchloĂtrĂ€ger Golf 5 |
| File size: |
135.49 KB |
| Viewed: |
18335 times |
Profile PM Garage |
03-01-2013, 1:56 Subject: Replacing the Golf 5 crossmember |
The whole thing might be a bit wobbly (unstable). It's not pretty. What do the other attachment points look like? They should be able to handle a bit more.
Whether it absolutely has to be replaced immediately -- other people drive around with it for years  .
Actually, it must be renewed immediately  .
03-01-2013, 2:46 Subject: Replacing the Golf 5 crossmember |
Quote: | | What do the other attachment points look like? |
So far, I have only found the cracks that are marked.
Otherwise, everything is set.
Profile PM Garage |
03-01-2013, 9:15 Subject: Replacing the Golf 5 crossmember |
dieselmartin wrote: | | Does it need to be replaced (immediately), or can it work like this for a while longer? | It sounds like you're already expecting Damage Update V1.1?
As mentioned before, many people wouldn't worry about it at all and would drive like that for years. Just pop the headlight in and compare it to the other side to see how firmly it's still attached. If it's very unstable, I would replace it.
Profile PM Garage |
18-01-2013, 9:19 Subject: Replacing the Golf 5 crossmember |
Okay.
I now also have two T10093s...
I'm going to play around with that now.
Profile PM Garage |
06-02-2013, 1:18 Subject: Replacing the Golf 5 crossmember |
OK.
"Carriers outside."
In my opinion, it's quite risky to engage in sports alone without the two T10093s. Above all, the climate control pipes would suffer unnecessarily.
It's relatively easy with T10093.
15 EUR for tools that are worth it.
| Description: |
| Demontage SchlosstrÀger Passat 3C |
| File size: |
348.61 KB |
| Viewed: |
11244 times |
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7812 Karma: +1090 / -0 Location: BAR
06-02-2013, 7:37 Subject: Replacing the Golf 5 crossmember |
Beautiful weather for tinkering!  Good luck!
06-02-2013, 10:52 Subject: Replacing the Golf 5 crossmember |
After two extreme snowstorms yesterday, it was dry overnight, and the air was quite dry - absolutely no problems.
Let's see when and how I can fit some fun into my day today.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
06-02-2013, 10:54 Subject: Replacing the Golf 5 crossmember |
I'm keeping my fingers crossed for you, Martin  !
06-02-2013, 21:48 Subject: Replacing the Golf 5 crossmember |
West Palatinate, 2 degrees Celsius, light sleet... the castle gate is still open.
Attention: The locking mechanism of the latch can be closed even if the internal sliding part is twisted. Then you can only unlock it once; after that, the locking mechanism will remain in the "open" position.
Profile PM Garage |
07-02-2013, 9:23 Subject: Replacing the Golf 5 crossmember |
Savings are needed everywhere.
Now, even with the castle door handles, they are saving money by no longer "pressing them hot" during the manufacturing process, and the metal body is no longer welded to the plastic body.
| Description: |
| Verbindungen zum SchloĂtrĂ€ger, Golf 5 |
| File size: |
329 KB |
| Viewed: |
10277 times |
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
07-02-2013, 16:16 Subject: Replacing the Golf 5 crossmember |
This obsession with saving money is crazy.
NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
