Cable Clips for Car Hood/Bonnet Contact
Post27-03-2013, 18:44    Subject: Cable Clips for Car Hood/Bonnet Contact Quote
HI.
The Golf has two different sizes of cable holders installed in the castle pillar : .
- Large, horizontal crossbar for the NebelSW connection.
and
- small ones that carry the cable from the hood latch contact to the right.
Does anyone have the ticket numbers for the small one?
Because in the Touran, the temperature sensor is permanently wired to the bumper, which means you have to tear off the clips when removing it.
 File size:  310.12 KB
 Viewed:  1325 times
Translated on 22-08-2026, 10:20.
Post27-03-2013, 20:51    Subject: Cable Clips for Car Hood/Bonnet Contact Quote
No. If you can't find anything better, the larger ones might be 1H0971 939C.
Because in the Touran, the temperature sensor is permanently wired to the bumper, so when removing it, you have to tear off the clips.
Do you mean the white "T" clips that are attached to the wiring harness with electrical tape? If handled carefully, they don't break immediately on the first try. You might still need them once. icon_cool.gif
The materials used in premium vehicles these days are truly top-notch.
One is always amazed at what humans are capable of.
Have you ever considered using simple cable ties?
Translated on 22-08-2026, 10:22.
Post27-03-2013, 21:49    Subject: Cable Clips for Car Hood/Bonnet Contact Quote
Martin only does high-quality (original parts) work... let's just forget about that one slip-up... although I wouldn't underestimate the quality of those cable ties icon_smile.gif.
Translated on 22-08-2026, 10:24.
Post28-03-2013, 10:36    Subject: Cable Clips for Car Hood/Bonnet Contact Quote
On the front, there are flat, protruding noses.
You can put something on these noses, just like you would on a doorknob.
That must really "stick".
These holders are designed for the SRA hose (very large, part number 1J0955846), the windshield washer nozzle (large), and the wiring connector (small). Additionally, the cable can be easily detached during disassembly; the clip remains attached to the component (front panel/locking bar).
My goal is to be able to disassemble the front section by myself and easily detach the wiring harnesses - this is possible on the G5 and 3C models.
By default, a part is installed on the Touran to which the wiring harness is firmly glued with tape. You have to tear these things off icon_sad.gif.
Here's an example of such a nose:
 File size:  123.76 KB
 Viewed:  638 times
Translated on 22-08-2026, 10:25.
No new posts Broken Fuel Line Holder: Causes & Fixes Diesel Engine Technology
No new posts Golf IV ESP Adapter: Does AHH fit AFN? Diesel Engine Technology
No new posts SW Holder: Replace or Keep? Transmission, Chassis, Body & Interior
No new posts CAN Interface RKS+CAN & SUB-D9 Cable On-Board Diagnostics (OBD)
