Hello fellow forum members,
"I have an LT35 here where, after experiencing undervoltage during startup (the battery is likely at the end of its life this winter), both the WFS control light and the SRS lamp are now constantly illuminated!"
I was able to delete the WFS, but the airbag control unit won't allow access! Is there a trick to it? Or could the voltage fluctuations have damaged the control unit?
I hope you can help me – I couldn't find anything when I searched.
Thank you very much, and best regards.
Alex.
| Description: |
| SRS Light On After Low Voltage - LT 35 2.5 TDI |
 Download |
| File name: |
Log-134887.txt |
| File size: |
1.03 KB |
| Downloaded: |
619 times |
Translated on 14-10-2026, 7:19.
