matt Guest
12-08-2013, 22:10 Subject: Climatronic coding not changeable? |
Hello everyone,
Is it normal that the coding of the Climatronic cannot be changed? The vehicle is a 2005 Passat 3BG.
The input from a different encoding simply isn't being saved. Does this require a login code?
Matthias.
DieselBĂ€r30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂŒnchen & Passau
12-08-2013, 22:22 Subject: Climatronic coding not changeable? |
Hi Matthias!
Please always perform a complete vehicle scan first and post the results here.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
matt Guest
13-08-2013, 14:51 Subject: Climatronic coding not changeable? |
Hello DieselBĂ€r30x,
Thank you for your feedback! I have attached a scan of all the control units. I hope this helps.
Matthias.
| Description: |
 Download |
| File name: |
Auto-Scan.pdf |
| File size: |
4.65 KB |
| Downloaded: |
1855 times |
13-08-2013, 17:31 Subject: Climatronic coding not changeable? |
The VAG-COM version used is no longer supported.
Please use VCDS-Lite.
Profile PM WWW Garage |
matt Guest
14-08-2013, 11:00 Subject: Climatronic coding not changeable? |
I completely forgot to mention that saving with a different encoding also fails with the current VCDS version.
The question of whether a login code is required still remains.
mullemaus Guest
14-08-2013, 13:45 Subject: Climatronic coding not changeable? |
I completely forgot to mention that saving a different encoding also fails with the current VCDS version.
The question of whether a login code is required still exists.
Please do that once.
Then it continues. Not before  .
matt Guest
16-08-2013, 12:43 Subject: Climatronic coding not changeable? |
Hello everyone,
Attached is a scan using the current VCDS-Lite software.
The result, regardless of the version â whether it's the current VCDS license with the corresponding interface, VCDS-Lite, or the older VAG-COM â is always the same: I cannot change the coding of the Climatronic.
Matthias.
| Description: |
 Download |
| File name: |
VCDS-Lite Auto-Scan Printout.pdf |
| File size: |
3.58 KB |
| Downloaded: |
812 times |
16-08-2013, 16:15 Subject: Climatronic coding not changeable? |
Quote: | | The result is that I cannot change the coding of the Climatronic. |
change to what?
matt Guest
16-08-2013, 18:51 Subject: Climatronic coding not changeable? |
Hello Rainer,
Changing from 17000 to 17200. This is the US setting. This adjustment is intended to better cater to the preferences of customers in the United States, particularly regarding the Climatronic system. I would like to test this setting to see if it works better for me.
Matthias.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
16-08-2013, 19:06 Subject: Climatronic coding not changeable? |
I can easily imagine that for us Europeans, the American coding system isn't appealing, because the Americans tend to exaggerate with their climate zones.
NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
16-08-2013, 20:32 Subject: Climatronic coding not changeable? |
Quote: | | VW Passat without L-shaped flap (3BG - Model year 2000 >) |
"Are you sure this air conditioning system was ever available with US-market coding for this vehicle?"
Find only "3B1 907 044 J" using "17200" as the encoding.
matt Guest
16-08-2013, 20:51 Subject: Climatronic coding not changeable? |
Hello Rainer,
I cannot be entirely certain about that  . My only source of information is the former openobd website. Of course, it's possible that the information provided isn't always 100% accurate.
Matthias.
matt Guest
21-08-2013, 15:34 Subject: Climatronic coding not changeable? |
Sure, here's the translation:
'Quick question:'
So, is it actually normal for the used Climatronic control unit in this case that other codings are simply not accepted?
Matthias.
22-08-2013, 13:16 Subject: Climatronic coding not changeable? |
matt wrote: | Quick question:
Matthias |
Others may have, but probably not the specific one you're looking for. As I mentioned before, I am not aware of any vehicle with the desired coding and that uses the parts with the part numbers and .
matt Guest
22-08-2013, 22:26 Subject: Climatronic coding not changeable? |
Hi Rainer,
Then I guess that's just the way it is.
Thank you for your assistance.
Matthias.
