awissus001
Joined: 11/28/2005 Posts: 27 Karma: +0 / -1 Location: Gifhorn
02-12-2013, 19:41 Subject: CAN USB Interface: Troubleshooting & Repair |
Hello.
Unfortunately, I seem to have damaged my interface. I purchased the official version from Rainer Kaufmann's shop back in 2005. It worked perfectly fine until last week, when I plugged in an adapter (2x2) that I borrowed from a friend, and that's when it stopped working. Is there any way to repair it?
Translated on 24-10-2026, 19:49.
awissus001
02-12-2013, 19:49 Subject: USB Interface Failure: Troubleshooting & Repair |
Here's the designation to explain which system I purchased:
1 x OBD/OBD2 Professional Diagnostic System KKL+CAN (USB)
awissus001
02-12-2013, 20:04 Subject: USB Interface Failure: Troubleshooting & Repair |
It's resolved itself, as I received an offer that I can't refuse.
Translated on 24-10-2026, 19:50.
03-12-2013, 12:07 Subject: CAN USB Interface: Troubleshooting & Repair |
http://shop.dieselschrauber.de/adapter-obd2-auf-2x2-p-34.php
Quote: | High-quality OBD2 to 2x2 adapter for older Audi or Volkswagen vehicles.
With metal nibs for a secure hold. No more waste that attaches incorrectly or falls off immediately! |
Of course, you can also use the widely available, cheap, soft plastic version...
Profile PM WWW Garage |
awissus001
03-12-2013, 18:33 Subject: USB Interface Failure: Troubleshooting & Repair |
Of course, that's possible, but it was very expensive in my case, so it's better to go with the original product to avoid problems and to have constant, good support.
Translated on 24-10-2026, 19:51.
awissus001
03-12-2013, 18:36 Subject: USB Interface Failure: Troubleshooting & Repair |
And also, my laptop gave up the ghost – the USB port is broken due to a power surge. So, no more compromises for me.
Translated on 24-10-2026, 19:52.
03-12-2013, 20:36 Subject: KEY-USB Interface Failure: Troubleshooting |
awissus001 wrote: | | Oh, and also, my laptop also broke down; the USB port is done, due to a power surge. So, no more compromises for me. |
"However, it shouldn't fail with incorrectly wired 2x2 adapters... how do you know it was a power surge?"
It sounds more like a mass problem, as already mentioned:
Quote: | Please ensure that when working on vehicles, appropriate power supplies are used.
"to be used. A faulty laptop power adapter plugged into a wall outlet, for example."
Connecting a battery charger to a power outlet simultaneously can lead to...
"The voltage output of the car charger is different from the voltage output of the laptop charger. -> Problem: it's smoking."
I recommend:
http://shop.dieselschrauber.de/product_info.php/products_id/48 |
Does the vehicle's mass affect the current flow, potentially causing compensating currents that could damage diagnostic cables or the laptop?
-> Such damages are not covered by the warranty!
Therefore, it's better to use your common sense beforehand (!) when connecting a laptop to a car's power supply, especially if the connection involves a car battery via a charger -> power outlet -> laptop power adapter -> USB port -> ground -> car battery (= ground).
Unfortunately, I have to say this directly because there are some people who apparently don't understand otherwise. Fortunately, these are few people, and the person asking the question is not meant either. However, it's a real and relatively annoying problem that arises from unsuitable or faulty power supplies.
I'm explaining this in such detail because, unfortunately, there are always some clueless people who simply don't understand, and they end up "consuming" interfaces/laptops, which they, of course, don't want to pay for...
Translated on 24-10-2026, 19:54.
awissus001
05-12-2013, 14:28 Subject: USB Interface Failure: Troubleshooting & Repair |
"I'm certainly glad I wasn't the one being referred to, because my laptop was only connected to the car via the interface. Also, I didn't mix up the white and black connectors, so it's probably the adapter I bought online that's the problem, right? Because I'm not colorblind, and even if someone looks at my profile, they wouldn't be completely clueless."
And the laptop says that a USB device caused the port to be disabled due to overvoltage. Unfortunately, the error cannot be easily fixed, and I hope my computer expert can help. And of course, it's my problem; if something like this happens, I have to replace the damage myself.
Translated on 24-10-2026, 19:57.
Autoservice Profi-Schrauber
05-12-2013, 17:31 Subject: CAN USB Interface: Troubleshooting & Repair |
Quote: | | Because I am not colorblind, and when someone views my profile, they are not entirely clueless either. |
Hopefully, you don't work as poorly as you write.........
Why did the boss install a spelling assistant here? What do you think  ?
Translated on 24-10-2026, 19:58.
awissus001
05-12-2013, 19:01 Subject: USB Interface Failure: Troubleshooting & Repair |
Thank you for the constructive criticism. Of course, "Profil" is not spelled with a "v," but thankfully, there are people like you who pay attention to such things.
06-12-2013, 11:02 Subject: CAN USB Interface: Troubleshooting & Repair |
Quote: | | And the laptop says that a USB device has shut down the port due to overvoltage. |
No, the laptop most certainly does NOT say that. Why not just take a Screenshot instead of making claims? I won't believe you until you show me the corresponding Windows message.
A USB port provides a specific maximum amount of power to supply the connected devices. If the port is required to provide too much power, it will shut down to prevent damage, and Windows will display a corresponding message.
Usually, restarting the computer without the device that is causing the problem is enough to make the USB port work again.
Being colorblind is completely different from being brain-dead. Since the color of the 2x2 connectors doesn't change when you reverse their polarity, it has nothing to do with colors.
 Apart from that, even a person with color blindness can distinguish between black and white.
Translated on 24-10-2026, 20:00.
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
06-12-2013, 11:10 Subject: CAN USB Interface: Troubleshooting & Repair |
Regarding the USB port: There are definitely laptops and other devices where the USB output simply doesn't provide more than a certain (standard) value. Connected devices will either work with that power, or they may intermittently show signs of insufficient power, or experience permanent failures. In some cases, these issues only appear after a certain period of operation. An example is external hard drives. Normally, they are designed to use their own power supply, but some can run without one, provided the USB port can provide more than the standard 500 mA. This can work fine for a while, but eventually it can lead to the drive disconnecting ("loss of connection" between the drive and the computer), and in the worst case, result in data loss. With USB ports, standardization is often a matter of luck, and even if the connectors fit, the connected device may not work on every computer.
Translated on 24-10-2026, 20:02.
06-12-2013, 11:22 Subject: CAN USB Interface: Troubleshooting & Repair |
The VCDS diagnostic cable requires significantly less power than any USB port can provide; in fact, the USB descriptor even specifies the maximum value.
USB hard drives are actually an exception, as there's often a lot of borderline trickery involved, using things like Y-cables and external power supplies, etc.
Translated on 24-10-2026, 20:03.
Hutfahrer Schrauber
06-12-2013, 12:03 Subject: CAN USB Interface: Troubleshooting & Repair |
Okay, that's exactly it. And often, customers are also kept in the dark about the actual power consumption of the hard drives. And if you then include a power supply connector but don't include a power supply, the confusion is complete.
awissus001
06-12-2013, 12:57 Subject: USB Interface Failure: Troubleshooting & Repair |
"A USB port provides a specific maximum amount of power to supply the connected devices. If the port is required to provide too much power, it will shut down to prevent damage, and Windows will display a corresponding message."
Generally, restarting the computer without the device that is causing the problem is usually sufficient to restore the USB port's functionality.
"This is exactly as described above, but it cannot be reset, and the port is not working, not even with a simple USB mouse. I'm not a computer expert, so I'll have it checked and repaired by a professional."
I hope that I don't have any spelling mistakes in the sentence, because the spell checker hasn't reported anything.
Translated on 24-10-2026, 20:04.
Jan6K
06-12-2013, 13:17 Subject: CAN USB Interface: Troubleshooting & Repair |
Be careful... you're talking about different things!
It's not about the current being drawn, but about a voltage surge coming from the outside. Some driver chips can definitely detect this, as well as excessive interference. What they then do is another question... as far as I know, they initially shut down (and report an error), but if the voltage surge is too extreme, even a reset won't help, because something is simply broken in that case.
"For those who want a log... I actually had something like this before (the following log is from a Google search, but mine looked the same) under Linux:"
Code: |
[ 2164.504843] hub 6-3:1.0: port 7 disabled by hub (EMI?), re-enabling...
[ 2164.504890] usb 6-3.7: USB disconnect, address 4
The cause was a cheap, long USB extension cable connected to a mouse, which, in an environment with electromagnetic interference, would trigger this exact error every few weeks. In this case, the problem reappeared repeatedly, but that shouldn't happen with an overvoltage event, as the resulting surge could easily damage the components.
Are ALL the USB ports on your computer dead, or just some of them/one?
Jan.
1Z5 CFHF  / AHB H4D
Translated on 24-10-2026, 20:06.
