Rear Door Problems: Sensor Not Detecting Opening
highspeed1
Post03-12-2013, 19:43    Subject: Rear Door Problems: Sensor Not Detecting Opening Quote
Hello, my Altea, manufactured in 2005, is giving me problems with the rear doors.
It manifests in the fact that, even though I open one of the rear doors, he still locks all the doors after a few minutes.
He doesn't realize that they were on. The lamp also doesn't turn on.
Error messages:
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MAX1.lbl
Part number: 1T0 959 701 A
Component: Door control unit 09 0139.
Encoding: 0000016
Operating number: WSC 06402 785 00200
VCID: 356525E725D1
"One error found:"
00932 - Power window motor, driver's side (V147)
005 - No or incorrect initial setup/adaptation - Intermittent.
Everything on the driver's side door is working.
Address 46: Comfort System
Label file: DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 BL
Component: 01 KSG 0301
Encoding: 98C000BC090005054C4F090000
Operating number: WSC 40801 188 08634
VCID: 7BF1F3DF4375
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
"One error found:"
00950 - Motor for central locking, rear door (V53); UNLOCK.
007 - Short circuit to ground.
The tailgate opens without any problems.
Address 56: Radio Label file: DRV\1K0-035-1xx-56.lbl
Part number: 5P1 035 152.
Component: Radio BNO 0029
Encoding: 0020400
VCID: E6C732ABA8F7
2 error codes found:
01044 - Control unit incorrectly coded.
000 - -
00856 - Antenna; for the radio.
011 - Interruption.
Poor reception, need to check the antenna, but having to remove the radio, and now the control unit is incorrectly coded?
Address 72: Door electrical, high, right.
Label file: DRV\1K0-959-704-GEN1.lbl
Part number: 1K0 959 704 B
Component: Door control unit 06 0206.
Encoding: 0000016
VCID: 306B14F3DAB3
00935 - Rear right window lifter motor (V27)
01037 - Window lifter, thermal protection active; rear right.
000 - - - Sporadically
The power windows are working, including the automatic function that activates when you touch the switch.
Thank you for your help!
Translated on 02-10-2026, 10:15.
Post03-12-2013, 20:41    Subject: Rear Door Problems: Sensor Not Detecting Opening Quote
Since you are using VCDS, please enter the serial number in your profile so that your status is displayed correctly.
Regarding your issue:
Since the errors with the windows are intermittent, I would try clearing them and see what happens. They might have been there for a long time (perhaps due to a dead battery?).
Then, use VCDS to access the rear door control modules and check the door contact switch values to see if it's functioning correctly. If communication is established but the measurement block doesn't respond, then the respective door lock is likely faulty.
Greetings.
Guste.
Translated on 02-10-2026, 10:21.
Post04-12-2013, 8:59    Subject: Rear Door Problems: Sensor Not Detecting Opening Quote
There was a series of 1K0 door control units that can fail if the battery is disconnected.
It sounds like voodoo, but I experienced it on EOS!!
However, in most cases, the fuel injectors are installed backward, so pressing the accelerator pedal causes the engine to shut down. In that situation, the fuel injectors need to be swapped.
However, if everything is working properly, I would prefer Guste's approach.
Translated on 02-10-2026, 10:22.
highspeed1
Post05-12-2013, 7:58    Subject: Rear Door Problems: Sensor Not Detecting Opening Quote
Okay, I'll give it a try.
The battery probably isn't in the best condition anymore, but I haven't had any problems yet. How about a broken cable?
Martin.
Translated on 02-10-2026, 10:23.
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reducer flow not detected Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central Locking: Rear Doors Won't Open? Electrical Systems, Vehicle Electronics, Multimedia
No new posts USB Interface not recognized On-Board Diagnostics (OBD)
No new posts Control Unit Not Recognized: Troubleshooting Guide Diesel Engine Technology
No new posts How do I get speaker wire into the rear doors? Diesel Engine Technology
