Audi A6 Fuel Consumption (AGR Rate)
andy1609
Post27-05-2014, 14:20    Subject: Audi A6 Fuel Consumption (AGR Rate) Quote
Good day!
Audi A6, Modell 1999, Motorcode. AFB
The following problem:
LMM, N18, and N75 were replaced.
The AGR had been deactivated by the owner and was then reactivated.
Subsequently, a logging operation was performed, and the AGR (Automatic Gear Ratio) rate at full load was 95.5%.
is located.
Shouldn't the control values for the solenoid valve (N18) be close to zero within this speed range?
The target and actual values are very similar.
Am I correct in understanding that the AGR (AbgasrĂźckfĂźhrung valve) is completely open at full load?
File attachments: Log file (AGR) and Autoscan report due to engine control unit issue.
Best regards, Andy.
Autoscan.txt
 File name:  Autoscan.txt
 File size:  3.63 KB
 Downloaded:  1605 times
Kornek.csv
 File name:  Kornek.csv
 File size:  7.08 KB
 Downloaded:  505 times
Translated on 09-09-2026, 0:08.
Post27-05-2014, 15:24    Subject: Audi A6 Fuel Consumption (AGR Rate) Quote
Am I correct in understanding that the AGR is completely open at full load?
A vacuum measurement taken directly at the EGR valve can shed light on the situation.
To me, it looks like the duty cycle is low when the EGR valve is open and high when it's closed. In any case, the EGR rate doesn't seem to be too high.
Unfortunately, the accelerator pedal position is not visible in the individual states.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 09-09-2026, 0:09.
andy1609
Post27-05-2014, 15:33    Subject: Audi A6 Fuel Consumption (AGR Rate) Quote
Thank you for the response.
A vacuum test was performed using a vacuum pump.
The valve retracts or returns to its default position (with a clicking sound).
How do I understand your interpretation correctly?
Best regards, Andy.
Translated on 09-09-2026, 0:10.
Post27-05-2014, 19:27    Subject: Audi A6 Fuel Consumption (AGR Rate) Quote
No. This allows you to determine how the AGR (Adaptive Gain Range) rate changes with the duty cycle.
Duty cycle approximately 100% ---> no vacuum present = AGR valve closed.
Translated on 09-09-2026, 0:11.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI: Log Fahrt, ASZ Engine, Power Loss Upload
No new posts AGR Rate: What it is and how it works On-Board Diagnostics (OBD)
No new posts AGR Rate Guide: How to Calculate & Optimize On-Board Diagnostics (OBD)
No new posts VW AGR Tester Rate On-Board Diagnostics (OBD)
