teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
26-01-2016, 13:00 Subject: Reset T5 2014 inspection |
Hello, until now, the reset function has worked either through the service's automated reset function or through the AI in channel 17, using the command "WIV reset" followed by the new value.
After resetting the AI, only the oil change reminder was cleared, but the inspection light is still on.
The latest version 15.7.1 is installed, and the TCU also accepted the reset.
With the hazard lights on and the reset performed via the buttons and ignition (turning it off and on), I still managed to reset it, but using VCDS doesn't work as described for me.
Is a different approach via the AI interface with VCDS necessary?
Best regards, Klaus.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
chli1976 Profi-Schrauber
26-01-2016, 13:18 Subject: Reset T5 2014 inspection |
Check it out at [website/place].
FIX: Kilometers since last inspection and...
FIX: Reset the "time since inspection" value for these two items to 0.
VCDS
26-01-2016, 13:47 Subject: Reset T5 2014 inspection |
Okay, I've implemented a flexible interval coding system.
Does that mean it can't be reset using the WIV (presumably a specific system or software)?
Joined: 04/12/2002 Posts: 18008 Karma: +786 / -0 Location: St.Gallen 2018 Volkswagen T6
26-01-2016, 14:14 Subject: Reset T5 2014 inspection |
Which car, the Touran? It works just like it has for years...
If in doubt, always include a car scan in your post. This way, people will know which car you're talking about and can also tell you which buttons they can see on your dashboard.
Profile PM WWW Garage |
26-01-2016, 14:26 Subject: Reset T5 2014 inspection |
Sure, here's the translation:
"Check this out:"
Post: January 26, 2016, 12:00 PM
Title: Resetting the 2014 T5 inspection service reminder.
26-01-2016, 15:40 Subject: Reset T5 2014 inspection |
The T5 has always been like this... it still lacks the Autoscan feature, and having a corresponding log for the adaptation channels would also be beneficial.
26-01-2016, 18:10 Subject: Reset T5 2014 inspection |
Here's the car scan.
edit: On an older T5 with a 2.5-liter engine, the service reset function automatically reset all values one after another.
However, this is not supported in the newer models. Previously, in models like the 2010 T5, it was possible to reset the system via the KI 17 interface and the WIV adjustment channel. I think something has changed again with the 14 model.
The oil change indicator can only be reset manually via the buttons on the clock in the case of an oil change.
Manually, but then with the hazard lights activated, this will reset the inspection reminder, but possibly only to a fixed interval.
| Description: |
 Download |
| File name: |
Log-MOS-XX856-WV2ZZZ7HZEH111183-91900km.txt |
| File size: |
6.71 KB |
| Downloaded: |
1163 times |
26-01-2016, 18:32 Subject: Reset T5 2014 inspection |
Use the VCDS function "Service reset".
See:
Oil changes and time-based maintenance are also different things.
What does VCDS display in the "Time since service" adaptation channel for your vehicle?
Please also provide a Screenshot of the selection box with the possible reset options and the SRILog.txt file...
26-01-2016, 19:45 Subject: Reset T5 2014 inspection |
The service request is being rejected with the explanation that it should be postponed due to a matter related to area 17.
I don't have the FZ here.
26-01-2016, 19:58 Subject: Reset T5 2014 inspection |
Translating... |
[Translating...] SRILog.txt?
26-01-2016, 20:13 Subject: Reset T5 2014 inspection |
I didn't create one this afternoon, but I'll submit it later when I regain access to the system.
dieselschrauber likes this. |
26-01-2016, 21:43 Subject: Reset T5 2014 inspection |
Try what I told you; the "FIX" setting is for the inspection. Even if you have a flexible setting enabled. This has been postponed several times already.
VCDS
26-01-2016, 22:02 Subject: Reset T5 2014 inspection |
Okay, I will. Thank you! It's just a workaround when I have to address individual values.
I'm going to try the "reset to factory settings" button one more time, and then I'll proceed.
26-01-2016, 22:29 Subject: Reset T5 2014 inspection |
The service function key is not working on any control unit that uses the UDS protocol.
VCDS
27-01-2016, 0:08 Subject: Reset T5 2014 inspection |
Okay, there's a message suggesting the use of adaptation channels, so a Screenshot would have been helpful...
You simply need to reset or adjust the corresponding WIV adaptation channels.
