Oil Change: How to Check & Understand.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post26-07-2015, 16:41    Subject: Oil Change: How to Check & Understand. Quote
Hi, is there a way for me to find out if the dealer actually performed the oil change they promised?
The service interval has been reset and now displays 29,000 km or 700 days until the next service.
2.0 TDI, 103 kW.
Thank you.
Sven.
Translated on 28-08-2026, 8:30.
Post26-07-2015, 20:55    Subject: Oil Change: How to Check & Understand. Quote
Yes, it is possible, and it can be done through an oil analysis. You don't know how long the old oil has been in the engine, or what condition it's in. As is well known, the fresh oil is immediately mixed with the remaining oil, so it becomes black right away.
If you lack trust in the dealer, I would change the oil myself... icon_wink.gif it's possible that he might have put some cheap, low-quality oil in.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 28-08-2026, 8:34.
Post26-07-2015, 23:00    Subject: Oil Change: How to Check & Understand. Quote
Right, only an oil analysis would provide any information. However, I don't think it's really worthwhile, as it would cost at least 50% of the price of an oil change.
Therefore, my advice is: if there is any doubt, switch. icon_wink.gif
Translated on 28-08-2026, 8:35.
Post27-07-2015, 7:02    Subject: Oil Change: How to Check & Understand. Quote
"We can only agree with what has been said before. A very vague possibility, if available, would be to check the production date of the oil filter on the top. If this date is after the second-to-last oil change, you would have some increased certainty. However, like the previous speakers, I would recommend changing it again, because if you already have doubts, it might also be a question of oil quality."
Translated on 28-08-2026, 8:36.
bloesch
Post27-07-2015, 8:26    Subject: Oil Change: How to Check & Understand. Quote
Why so complicated?
Just take a look at the oil filter or the oil filter housing. Or the drain plug. Can you see any oil residue anywhere? Any oil splatters? Or, conversely, does it look like someone might have cleaned something there recently?
Aside from the fact that an oil change costs a dealer almost nothing... unless there's already a really bad atmosphere, why would a dealer try to rip you off over a small amount?
vwSchrauber
Post27-07-2015, 9:28    Subject: Oil Change: How to Check & Understand. Quote
Just take a look at the oil filter or the oil filter housing. Or the drain plug. Can you see any oil residue anywhere? Oil splatters? Or, conversely, does it look like something might have been cleaned there recently?
A very vague possibility, if available, would be to check the production date of the oil filter on the top side... If this date is after the second-to-last oil change, you would have some increased certainty
Get the oil filter from the exact same dealer and compare the manufacturers (Mann, Mahle, Knecht, Bosch, etc.).
It would be very unlikely that he would receive either of the items from his supplier.
Aside from the fact that an oil change costs a dealer almost nothing... unless there's already a really bad atmosphere, why would the dealer try to rip you off over a small amount?
Because he's a greedy jerk? I know of a case where, in the past, the old oil filter would be meticulously polished with rags and rust remover to make it look like it had been replaced. This was a dealer with an official brand dealership (!).
Translated on 28-08-2026, 8:38.
scrdel
Post01-08-2015, 18:37    Subject: Oil Change: How to Check & Understand. Quote
I took a look at the oil filter today, what do you think?
1000 km or 30,000 km mileage?
Around the oil filter, everything looked untouched; there wasn't a single oil splatter, and nothing had been wiped clean.
 Ă–lfiler 2.0 TDI
 File size:  1.92 MB
 Viewed:  972 times
 Ă–lfiler 2.0 TDI
 File size:  1.86 MB
 Viewed:  644 times
 Ă–lfiler 2.0 TDI
 File size:  1.86 MB
 Viewed:  641 times
 Ă–lfiler 2.0 TDI
 File size:  2.22 MB
 Viewed:  633 times
 Ă–lfiler 2.0 TDI
 File size:  2.15 MB
 Viewed:  659 times
Passat Variant Highline 2,0 TDI 103KW
Translated on 28-08-2026, 8:40.
Post01-08-2015, 18:51    Subject: Oil Change: How to Check & Understand. Quote
Thank you! Based on their "level of wisdom," I would say they haven't been here for very long. icon_smile.gif
Of course, without any guarantee.
Translated on 28-08-2026, 8:41.
No new posts Power steering fluid change? Diesel Engine Technology
No new posts Oil change questions for the 2L TSI engine Gasoline Engine Technology
No new posts Haldex Oil Change: Service & Costs Transmission, Chassis, Body & Interior
No new posts Ölwechsel Intervallverlängerung Diesel Engine Technology
