30-08-2015, 19:54 Subject: VCDS 1507: Missing ASAM Data? |
During the diagnostic scan of my Polo, I encountered unusual error messages indicating missing ROD or ASAM data – see the attached files for addresses 03, 15, and 55.
Interestingly, the ASAM dataset that is being criticized is located just a few lines above it.
I'm writing this because VCDS is asking me to send the Autoscan data to RossTech or the distributor.
BTW: What do these ROD and ASAM data actually mean?
| Description: |
 Download |
| File name: |
Log-WVWZZZ6RZEYxxxxxx-3600km.txt |
| File size: |
7.2 KB |
| Downloaded: |
1413 times |
Translated on 02-09-2026, 3:57.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
30-08-2015, 20:11 Subject: VCDS 1507: Missing ASAM Data? |
Hello Ulf,
This is roughly equivalent to the label files, i.e., descriptions of control units, descriptions of measured values, etc.
Translated on 02-09-2026, 3:58.
Profile PM WWW Garage |
03-09-2015, 14:24 Subject: VCDS 1507: Missing ASAM Data? |
Version 15.7.0.0 should generally be used with caution (see https://community.dieselschrauber.org/en/viewtopic.php?p=224853#224853):
Can I install VCDS DRV 14.10.0.0 alongside version 15.7.0.0 on my "Logtop" so that both versions are functional and don't interfere with each other?
If so, what should I be aware of?
Translated on 02-09-2026, 3:59.
Profile PM Garage |
03-09-2015, 14:39 Subject: VCDS 1507: Missing ASAM Data? |
Hello Ulf,
Yes, that's no problem.
03-09-2015, 17:39 Subject: VCDS 1507: Missing ASAM Data? |
During the installation of updates, you sometimes get prompts like "Uninstall old drivers?"
Should I then choose "do not uninstall"? Or is that option only presented when the update is installed in the same directory as the previous version?
Translated on 02-09-2026, 4:00.
Profile PM Garage |
03-09-2015, 18:21 Subject: VCDS 1507: Missing ASAM Data? |
You can leave the drivers as they are.
04-09-2015, 16:47 Subject: VCDS 1507: Missing ASAM Data? |
"Thank you!"
With this, you will no longer receive error messages on the Polo regarding missing files, and the basic LWR (Low Voltage Regulator) setting will also work  .
Translated on 02-09-2026, 4:01.
Profile PM Garage |
Xbuman
05-06-2016, 20:05 Subject: VCDS 1507: Missing ASAM Data? |
Unfortunately, I'm experiencing the same problem, and I don't have access to any previous versions to test whether they work better.
| Description: |
 Download |
| File name: |
Log.txt |
| File size: |
8.4 KB |
| Downloaded: |
515 times |
05-06-2016, 20:57 Subject: VCDS 1507: Missing ASAM Data? |
Hi Xbuman,
Please send a full vehicle scan to Ross-Tech in cases like this.
Translated on 02-09-2026, 4:02.
Xbuman
08-06-2016, 16:57 Subject: Quick Feedback: Get Fast Responses Now! |
My mechanic couldn't read the error code with the new diagnostic tool initially, but then he was able to read it with the older tool. The oxygen sensor was defective.
"The reason was that the car is old, but the engine is new," according to the friendly person.
