DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post19-06-2016, 15:04    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
My friend's Octavia is experiencing issues, but for now, it's only indicated by a flashing wrench symbol alternating with the gear display on the instrument cluster.
This is a 7-speed DSG (Direct Shift Gearbox).
Error codes read from the transmission control unit indicate "overspeed protection" three times, and also a problem with the hydraulic pump.
Unfortunately, I can't make any sense of this, so I'm asking for your help.
These errors could no longer be cleared from the engine control unit when the vehicle was cold and the engine was not running, and the "Sporadic" status disappeared.
In the control modules (ECUs) of the transmission, a voltage reading similar to that of the battery was detected at the hydraulic pump.
Interestingly, no driving behavior issues were noted, except for a very rare, somewhat unusual jolt when starting.
The error symbol in the dashboard appears sporadically, and it also disappears again for a few days or weeks.
I immediately suspected that there were errors or shortcuts taken during the scheduled transmission oil change at 60,000 km, but this inspection was not actually performed by an independent mechanic, and according to the service booklet, only the oil was changed and nothing else was done.
Best regards from Munich!
Autoscan:
Code:
Sonntag,19,Juni,2016,14:59:53:34514
VCDS -- Windows-basierter VAG/VAS-Emulator lÀuft auf Windows 7 x86
VCDS Version: RKS 15.7.4.1
Datenstand: 20160226
HĂ€ndler-/Werkstattname:
Betriebsnummer:
Fahrzeug-Ident.-Nr.: TMBFK61Z6C201XXXX   KFZ-Kennzeichen: M-XXXXXX
Kilometerstand: 62760km   Reparaturauftrag: Tini
Fahrzeugtyp: 1Z (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62
          72 77
Fahrzeug-Ident.-Nr.: TMBFK61Z6C201XXXX   Kilometerstand: 62760km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: Fehler 0010
04-Lenkwinkelsensor -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
42-TĂŒrelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
52-TĂŒrelektr. Beifahr. -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
62-TĂŒrelektr. hi. li. -- Status: i.O. 0000
72-TĂŒrelektr. hi. re. -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Adresse 01: Motorelektronik (CDA)       Labeldatei: DRV\06J-907-115-CDA.clb
   Teilenummer SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Bauteil: 1.8l R4/4V TFSI     0020
   Revision: AAH16---    Seriennummer: 00000000000000
   Codierung: 0203000C24070160
   Betriebsnr.: WSC 55140 141 97987
   VCID: 3565537E5CC7A4969D-8060
Readiness: 0000 0000
Adresse 02: Getriebe        Labeldatei: DRV\0AM-927-769.clb
   Teilenummer SW: 0AM 300 051 R    HW: 0AM 927 769 D
   Bauteil: GSG DSG AG7     421 2710
   Revision: 00042014    Seriennummer: TFK01105200016
   Codierung: 0000020
   Betriebsnr.: WSC 73430 790 00064
   VCID: 397D5F4E70DF40F679-806C
3 Fehlercodes gefunden:
006079 - Hydraulikpumpe
               P17BF - 000 - Spielschutz - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00100000
                    FehlerprioritĂ€t: 0
                    FehlerhĂ€ufigkeit: 4
                    VerlernzĂ€hler: 10
                    Kilometerstand: 62729 km
                    Zeitangabe: 0
                    Datum: 2016.06.16
                    Zeit: 15:12:36
               P17BF - 001 - Spielschutz - Sporadisch
                    FehlerprioritĂ€t: 0
                    VerlernzĂ€hler: 10
                    Zeitangabe: 0
                    Datum: 2016.06.16
                    Zeit: 15:12:36
               P17BF - 002 - Spielschutz - Sporadisch
                    FehlerprioritĂ€t: 0
                    VerlernzĂ€hler: 10
                    Zeitangabe: 0
                    Datum: 2016.06.16
                    Zeit: 15:12:36
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\1K0-907-379-60EC1F.clb
   Teilenummer SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Bauteil: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Codierung: 113B401C092300FB881002E9901A0041350000
   VCID: 7BF18546FA63B2E62B-802E
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei: DRV\5K0-907-044.clb
   Teilenummer SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Bauteil: Climatronic   H16 0402
   Revision: 00001006
   Codierung: 0000000002
   ASAM Datensatz: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 76E79472C941EF8E54-8022
Adresse 09: Zentralelektrik (J519)       Labeldatei: DRV\1K0-937-08x-09.clb
   Teilenummer SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Bauteil: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Codierung: 40000AB8E80508C040080080510091E4437000AE726D8D605C8540000040
   VCID: 3F893156AEFB6EC647-806A
   Subsystem 1 - Teilenummer: 1Z1 955 119 D  Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: Wischer 26051  26  0601
   Codierung: 00D7B7
   Subsystem 2 - Teilenummer: 1K0 955 559 AH  Labeldatei: DRV\1K0-955-559-AG.CLB
   Bauteil: RLS 300511 05  54  0403
   Codierung: 0730ED
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei: DRV\1Z0-919-475-V2.clb
   Teilenummer SW: 1Z0 919 475 E    HW: 7N0 919 475
   Bauteil: PARKHILFE 8K  H06 0005
   Revision: --H06---    Seriennummer: 28291108961954
   Codierung: 108101
   Betriebsnr.: WSC 13765 790 00064
   ASAM Datensatz: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000.rod
   VCID: 43813DA6CA130A2623-8016
Adresse 15: Airbag        Labeldatei: DRV\1K0-909-605.lbl
   Teilenummer SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Bauteil: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Seriennummer: 0038PC25NZ1S
   Codierung: 0020790
   VCID: 3D754B5E64F77CD655-8068
   Subsystem 1 - Seriennummer: 6332MSME60456A327
   Subsystem 2 - Seriennummer: 6342MSME604471543
   Subsystem 3 - Seriennummer: 6351HSME271D2601%
   Subsystem 4 - Seriennummer: 6361HSME2719693FK
Adresse 16: Lenkradelektronik (J527)       Labeldatei: DRV\5K0-953-569.clb
   Teilenummer SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Bauteil: LENKS.MODUL   014 0140
   Revision: FF010040    Seriennummer: 20110531200666
   Codierung: 189A140000
   ASAM Datensatz: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF78C52E171A7CE0C-802A
   SteuergerĂ€t fĂŒr Multifunktionslenkrad:
   Subsystem 1 - Teilenummer SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-URO  H07 0012
   Codierung: 830000
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei: DRV\5K0-920-xxx-17.clb
   Teilenummer SW: 1Z0 920 843 Q    HW: 1Z0 920 843 Q
   Bauteil: KOMBI         H04 0607
   Codierung: 110E01
   Betriebsnr.: WSC 73430 031 00064
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 468724B2F9213F0E04-8012
Adresse 19: Diagnoseinterface (J533)       Labeldatei: DRV\7N0-907-530-V2.clb
   Teilenummer SW: 7N0 907 530 H    HW: 1K0 907 951
   Bauteil: J533  Gateway H42 1620
   Revision:   H42       Seriennummer: 300511F1002963
   Codierung: 352302
   VCID: 3565537E9CC7A4969D-8060
Adresse 25: Wegfahrsperre (J334)       Labeldatei: DRV\5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H04 0607
   Codierung: 000000
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADFB0028DF93B6EC0-803E
Adresse 36: Sitzverst. Fahr.        Labeldatei: 3C0-959-760.lbl
   Teilenummer SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Bauteil: Sitzverstellung     1102
   Revision: 00005000    Seriennummer: 00000000000000
   VCID: 2F696116BE9B9E46D7-807A
Adresse 37: Navigation (J0506)       Labeldatei: DRV\1T0-035-680.clb
   Teilenummer SW: 3T0 035 680 C    HW: 3T0 035 680 C
   Bauteil: RNS-MID       H06 3974
   Revision: AB001001    Seriennummer: SKZ6Z7L5152028
   Codierung: 04000402000100810000
   VCID: 306B626A63A581BECE-8064
Adresse 42: TĂŒrelektr. Fahrer        Labeldatei: DRV\1K0-959-701-MAX3.lbl
   Teilenummer SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Bauteil: Tuer-SG         009 2119
   Codierung: 0004606
   VCID: 76E794720141EF8E54-8022
Adresse 44: Lenkhilfe        Labeldatei: DRV\1Kx-909-14x-44.clb
   Teilenummer: 1K0 909 144 M
   Bauteil: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 34636E7A57BDBD9EAA-8060
Adresse 52: TĂŒrelektr. Beifahr.        Labeldatei: DRV\1K0-959-702-MAX3.lbl
   Teilenummer SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Codierung: 0004606
   VCID: 489B2A8A3B35297EF6-801C
Adresse 55: Leuchtweitenreg.        Labeldatei: DRV\5M0-907-357-V2.lbl
   Teilenummer SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Bauteil: AFS-Steuergeraet    0148
   Revision: 00H04000    Seriennummer:
   Codierung: 1507354
   Subsystem 1 - Teilenummer: 7L6 941 329 B  Labeldatei: 3D0-941-329.CLB
   Bauteil: AFS-Lst.-Modul l    0004
   Codierung: 00000023
   Subsystem 2 - Teilenummer: 7L6 941 329 B  Labeldatei: 3D0-941-329.CLB
   Bauteil: AFS-Lst.-Modul r    0004
   Codierung: 00000023
Adresse 56: Radio (J0506)       Labeldatei: DRV\1T0-035-680.clb
Adresse 62: TĂŒrelektr. hi. li.        Labeldatei: DRV\1K0-959-703-GEN3.lbl
   Teilenummer SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Bauteil: Tuer-SG         007 2101
   Codierung: 0000144
   Betriebsnr.: WSC 73430 790 1012544
   VCID: 326F6862ADA9B3AEB8-8066
Adresse 72: TĂŒrelektr. hi. re.        Labeldatei: DRV\1K0-959-704-GEN3.lbl
   Teilenummer SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Codierung: 0000144
   VCID: 33616D6652B3BAA6B3-8066
Adresse 77: Telefon (J412)       Labeldatei: DRV\7P6-035-730.clb
   Teilenummer SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Bauteil: TELEFON       H09 2730
   Revision: 1B001001    Seriennummer: 00007660141205
   Codierung: 0101000000010110
   ASAM Datensatz: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 3565537E94C7A4969D-8060
2 Fehlercodes gefunden:
13635840 - Versorgungsspannung
          U1011 00 [000] - Spannung zu niedrig
          Sporadisch - unbestĂ€tigt - geprĂŒft seit letzter Löschung
13893632 - FunktionseinschrÀnkung
          U1400 00 [000] - durch Unterspannung
Ende----------------------------(Dauer: 03:50)-----------------------------
Adresse 02: Fehlercodes gelöscht
EDIT: Title changed to [solved].
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
Translated on 09-09-2026, 10:43.
Post19-06-2016, 21:03    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hi Bear,
Speculation: The hydraulic pump is temporarily not delivering the required pressure.
If that were the case, the error would primarily occur when the DSG is hot.
Oil level okay and sufficient? Have you checked if you can find a measurement block for the hydraulic pressure?
Translated on 09-09-2026, 10:46.
DieselBĂ€r30x
Post20-06-2016, 14:06    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
It sounds plausible that it could be related to oil or oil pressure, but I want to logically rule that out, because the error messages changed from "sporadic" to "permanent" - without the engine running, completely cooled down!
In this state, no pressure should be requested.
Otherwise, no logs or similar records were created, because "it was just for a quick look."
I also don't understand what the term "Spielschutz" refers to.
Possibly, I'll take it in for a DSG transmission oil change, which is due anyway.
It's difficult to tell if there's enough oil in the VW concept's toilet system, so you often end up having to replace it immediately.
In any case, no oil stains or similar marks were reported on the garage floor.
You're very welcome!
Translated on 09-09-2026, 10:47.
DieselBĂ€r30x likes this.
Post20-06-2016, 15:03    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hi GlĂŒcksBĂ€rchie,
It sounds plausible that it could be related to oil or oil pressure, but I want to logically rule it out, because the registered errors changed from "Sporadic" to permanently static - without the engine running, completely cooled down!
Don't expect too much logic from the error memory. It's possible (!) that this error normally only appears when the engine is running and can only be cleared there. Since you're doing this with the engine off, the DSG control unit checks the pressure and determines that it's not correct, and therefore changes the error from "intermittent" to "static." This is just one possibility, but in the past, there have been error messages in the engine control unit that only appeared when the engine was off and could only be cleared when the engine was running. Therefore, I wouldn't rule it out for the DSG.
Back to the topic:
The internet suggests that the hydraulic pump is not building enough pressure, or that the pressure is fluctuating too much. Therefore, the DSG control unit (DSG-STG) believes that the pump has too much play and is trying to protect itself, resulting in a "play protection" error.
The causes appear to be varied, ranging from oil leaks and pump failures to a problem similar to the one that triggered a recall of 7-speed DSG transmissions in China (corrosion caused by sulfur in the DSG oil).
Nice examples:
http://www.polo6rfreunde.de/index.php/Thread/10889-Fehler-Motor-f%C3%BCr-Hydraulikpumpe-Unterspannung/
http://vagcomforum.de/index.php?showtopic=18772#entry105919
Good luck to your acquaintance, and hopefully it's just a lack of oil.
Greetings.
Guste.
Translated on 09-09-2026, 10:50.
LZ
Post20-06-2016, 16:00    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
"Spielschutz" refers to the fact that there is always a system pressure that keeps the two pistons at a defined point. While the mechatronic module has a pressure accumulator, it is not sufficient to maintain this pressure indefinitely.
Here you can see the pump.
https://youtu.be/xyp96e1p16Q?t=814
Translated on 09-09-2026, 10:52.
DieselBĂ€r30x
Post20-06-2016, 18:41    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
Once again, my sincerest thanks for the explanations!! icon_smile_thumb_up.gif
Here are two log files with mostly uneventful entries; proper logging of the time and location is impossible.
Here, I initially recorded various speeds and voltages, and later, I also recorded the desired and actual pressures, voltage, and current of the hydraulic pump using more advanced diagnostic tools.
I lack the experience, but Druck1 seems to be the static maximum value at 60 bar, while Druck2, with values of 42/45/52 bar, represents the corresponding minimum or target pressure.
The actual pressure is significantly lower than the previous value in some cases, but the actual and target pump speed appear normal at a constant 2,100 RPM.
Okay, the current draw from the pump is fluctuating quite a bit, but that might be normal *shrug*. The pump voltage remains stable and close to the vehicle's power supply.
The clutches seem to be working properly, and despite the error message in the onboard computer, the shifting and driving behavior remains consistently smooth.
Regarding the error memory:
Immediately after (cold) startup, the errors reappeared "sporadically" in the memory and could be cleared. Approximately 10 minutes later, they returned with a flashing wrench symbol on the instrument cluster, and this time they were persistent and could no longer be cleared.
It seemed that, for some reason, the factor at play here was time.
I have already found the relevant posts and was aware of the oil issue with the DSG even before. However, I see more speculation here than concrete solutions.
The service booklet for the vehicle does not contain any entries, and there are no visible action stickers on the A/B pillars either.
There should be three indentations on the oil drain plug to indicate that an oil change has already been performed, but I didn't want to disassemble anything there today.
My advice, as before: Have the DSG oil changed with a new filter, and possibly have the transmission control software updated, as there seem to be at least two newer versions available.
I will report back, and after the visit to the workshop, I will definitely run another car scan.
We would like to express our sincere gratitude once again for your assistance. icon_biggrin.gif
LOG-02-307-31B.CSV
 File name:  LOG-02-307-31B.CSV
 File size:  70.99 KB
 Downloaded:  1159 times
LOG-02-013-005-006.CSV
 File name:  LOG-02-013-005-006.CSV
 File size:  47.71 KB
 Downloaded:  882 times
Translated on 09-09-2026, 10:55.
DieselBĂ€r30x
Post20-06-2016, 21:06    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
P.S. GKB devices are NAT (Network Address Translation).
When looking at the RLF (..., one could have checked this beforehand, right? icon_wink.gif), it becomes apparent that this "0AM" DSG has TWO DIFFERENT oil fillings.
First, there's the standard gear oil, which can be drained through a drain plug and then refilled through the shift lever cover (which needs to be removed for this) with a precise fill volume of 1.7 liters.
The oil level cannot be determined directly, except by changing the oil and collecting the old oil, which, in turn, cannot be reused.
Now things are getting interesting - or sad: icon_eek.gif
On the other hand, there's a hydraulic oil filling in the mechatronics unit, which is precisely the area that is likely of interest in this post.
Here, no exchange is planned. The new mechatronic unit will be shipped with the correct amount of oil, and returns must be shipped with the oil still inside. icon_evil.gif
Accordingly, no maintenance procedures such as filter replacement, oil level checks, or oil changes are performed here.
The oil filter shown in the various pictures and videos is not actually present in this DSG transmission.
Let's see what the workshop says.
Translated on 09-09-2026, 10:59.
Post20-06-2016, 21:28    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Translating...
[Translating...]
Post21-06-2016, 6:25    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
"With the 6-speed DSG, they only managed to get through the filter because it involves wet clutches. The oil change was also interesting to me (I don't have much experience with transmissions). The fill plug is also the drain plug. Behind this plug, there's a plastic tube screwed in. This tube needs to be removed so that the used oil can drain out of the transmission. Then, new oil is added through the same opening, filling the transmission. Afterwards, with the engine running at operating temperature, the tube essentially indicates the correct fill level."
To the best of my knowledge, with the 7-speed transmission, the hydraulic circuit cannot be drained and refilled while the transmission is still attached to the engine... that's the nature of the lifetime fill. However, the actual transmission oil can be changed, but that probably won't improve the situation in your case... so it's likely going to require some work.
Translated on 09-09-2026, 11:02.
DieselBĂ€r30x
Post21-06-2016, 14:38    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
HAH!
I actually found something that suggests an oil change might be possible in the mechatronics system.
http://www.automatik-getriebe-berlin.de/automatikgetriebefaupel/getriebe/oelkDSG0AM.pdf
Translated on 09-09-2026, 11:03.
LZ
Post21-06-2016, 18:27    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Bingo, and the Prussians too!
It's worth a try, the new mechatronics system costs almost 2,000€! Go ahead and build yourself several funnels with extension hoses attached. icon_wink.gif
DieselBĂ€r30x
Post28-06-2016, 1:15    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
Yes, the prices... But it could still be worse icon_lol.gif.
First of all, I want to reiterate my sincere gratitude for the helpful tips - I can't thank you enough! icon_wink.gif
Here's a quick update on the matter:
Last Wednesday, we were together at a northern branch of the well-known Munich-based VAG fast-food chain, where the sign outside said "Skoda" and the car used to be brand new.
My acquaintance initially didn't want to, because she had developed allergies against the club, but she eventually agreed after I explained my reasoning.
Okay, the staff at that rental place were incredibly rude – they definitely have less decorum and probably less class than the people working at McKotz behind the counter *thinking out loud*.
The problem was briefly described and acknowledged with disinterest. Furthermore, I naturally had the VCDS printout, or Autoscan, with me in order to narrow down the error as much as possible.
The documents were pushed aside with the words "...I'm not interested..." (direct quote!!!), and from that point on, it was essentially impossible to have a normal conversation with the person.
I would also like to know if the current repair manual (RLF) describes an oil change for the mechatronics unit, and furthermore, whether they would still perform a hydraulic oil change at a customer's request, even if it is not described in the manual (as mentioned above!).
As expected, he didn't want to check the service manual (RLF) and continued to say that if it wasn't described exactly as it is in the RLF, or if it stated something different, they wouldn't perform an oil change, even if the customer wanted it!
Apparently, what was much more important to Mr. icon_rolleyes.gif was the assumption that the already signed repair order would cover whether the car could be washed, whether there were any valuables inside, etc. icon_arrow.gif
We definitely need to perform some troubleshooting, guided if necessary, and then we can proceed.
Upon my inquiry, I received the response: "That can cost around 200 EUR!"
icon_exclaim.gif ...and here, at this point, AGAIN my main reason for using VCDS icon_cool.gif
Also, 1x anstecken und blöd schaun dabei, rd. 200 EUR. Without any breakdowns!
(auch DAS kenne ich persönlich SO bei einem MStG-Update vom T5: 5min. klicken, 1h warten - OHNE Personaleinsatz: 130 EUR! Neija...)
On Friday, I received a phone call informing me that the mechatronics system was broken.
They've never experienced anything like that before... (Why doesn't lightning strike them when they make such statements?!!)
We are attempting to file a goodwill request regarding the vehicle. We are awaiting a response, and the car must remain at the facility over the weekend.
Alleged response from Skoda: 100% parts, 0% labor.
Okay, my advice: Just go for it.
Today, she picked up the Octavia again, but she didn't receive any receipt and didn't have to pay anything – for now. And, of course, on the way home, she experienced the same intermittent jerking as before.
Whether anything was actually done or whether a learning cycle was simply not performed... we don't know. Not yet! icon_rolleyes.gif
Given that there are no new or different reported shortcomings in driving behavior, I'm inclined to believe the former is the case. }
If I happen to be in the area sometime, I'll do another car scan and keep you updated.
Translated on 09-09-2026, 11:07.
Post28-06-2016, 8:32    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
It kind of reminds me of "Mr. Kaufmann, we've repaired your car." - 3rd attempt and the check engine light comes on 50 meters after leaving... icon_cool.gif
Translated on 09-09-2026, 11:12.
Post28-06-2016, 8:45    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
"Auto muss ĂŒbers Wochenende dableiben" sounds more like an emergency room in a hospital and empty departments icon_wink.gif. Whereas, no bill with presumably no work would represent a rather positive correlation. Usually, for them, no work doesn't correlate with a high bill and possibly more errors than before. You probably marked the oil inlet screw beforehand somehow, right? icon_idea.gif
DieselBĂ€r30x
Post28-06-2016, 13:54    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
Yes, not only did Mr. Kaufmann have a Déjà vu, and my acquaintance immediately said after the initial acceptance of the vehicle: "Now I know why I don't like coming here!" icon_wink.gif
As a helpful addition, it should be noted that the mileage reading on the odometer changed exactly by NUHUULL kilometers before and after the repair.
(I have to check again whether the car was still in the same spot where she had parked it icon_lol.gif).
Generally, I don't like working on other people's cars, and even less so on the cars of acquaintances or friends - for reasons icon_rolleyes.gif.
In this case, I didn't want to make things any worse, and I certainly didn't want to jeopardize the possibility of a generous resolution.
That's why I haven't disassembled or marked anything so far.
I will report icon_wink.gif.
Translated on 09-09-2026, 11:14.
DieselBĂ€r30x
dieselschrauber, olli, Roger, matthiasTDI96, LZ and 3 others like this.
Post28-06-2016, 22:03    Subject: DSG P17BF Error: Skoda Octavia Hydraulic Protection Fix Quote
Hello everyone!
And now, here's the big reveal regarding the case:
LZ wrote:
Game protection means that there is always a system pressure that prevails to keep the two pistons at a defined point. While a pressure accumulator is installed in the mechatronic unit, it is not sufficient for an unlimited time. ...
That's exactly right!
I took some time this evening to look over the Octavia again.
Mechatronics is new, or rather, brand new.
I'm skipping the full system scan again, but the hardware part number is the same. The software part number has changed to: 0AM 300 058 Q, and the software version is now: (431) 6203. Finally, a different Vehicle Specific Code (WSC) is now applied.
By the way, I checked the extended ID: Mechatronics was created in 11/2015 and has been programmed twice so far.
So, contrary to initial assumptions, it turns out she was switched.
I don't know how the "0km learning" process works, but you don't have to know everything to the point of exhaustion icon_wink.gif.
Things are about to get really interesting with the newly implemented logging system.
In the recording provided, it is clearly visible that the hydraulic pump was running CONSTANTLY WITHOUT INTERRUPTION. Due to my lack of experience, I initially considered this to be abnormal. Furthermore, the setpoint/actual speed values displayed on the motor control board (MCB) indicated continuous regulation, rather than a "controlled" operation.
In SSP No. 390, on page 40, near the top, a single subordinate clause mentions that the GeStG system controls the hydraulic pump on and off based on pressure.
Ok, here too I didn't think much further, because in such a technical specification (SSP), details are almost never given, and everything is only described schematically. Incidentally, the SSP mentions contradictory filling quantities for Mechatronics, stating both 1.1L and 1.0L. ...so it's all approximate & fits anyway icon_wink.gif
Actually, the hydraulic pump only runs at ONE speed of 2,200 RPM and is switched on or off depending on the pressure.
(originally, a technical step backward using a three-phase motor, which anyway has to be driven by a frequency converter (circuit), but I didn't study... you know icon_rolleyes.gif).
Here as well, there's a pressure of 1 with 60 bar, which is likely the maximum pressure (SSP states 70 bar...), and this is a fixed value. Pressure 2, on the other hand, appears to be the minimum pressure and is variably specified by the GeStG (depending on the required coupling pressure/load situation?), but never below 42 bar.
In the first log, these 42 bar were sometimes below the actual pressure, and it was unlikely that values above 45 bar were reached, all while the hydraulic pump was running constantly! Also, the current draw was much lower compared to now.
With modern mechatronic systems, the hydraulic pump typically only runs for a short period, builds up the maximum pressure, and then is completely shut off for approximately 10-30 seconds: the target/actual speed is zero.
The pressure here decreases more or less slowly towards "Pressure 2", which then triggers short activations (approximately 1-2 seconds) of the pump.
Findings regarding this case:
Either the oil level in the mechatronic unit was too low, causing the pump to also draw in air (which explains the continuous operation and lower power consumption!), or there was a leak in the hydraulic circuit, possibly due to a faulty valve, cylinder, seal, or membrane.
I'll keep that in mind, and I'll take the car out for a drive every few months to document any potential wear and tear.
Insights from other websites like MotorBlöd & Co.:
...and I had really read a lot, a lot, a lot about it, because my acquaintance is really a sweet person and it's definitely worth it icon_cool.gif.
Not a single post from "HalbSchlaubie" described the definitive on/off switching of the hydraulic pump, nor the continuous pressure drop over time during operation in relation to the control of the hydraulic pump. It was always just talk about "...you need to check...", "the pressure should be at least 45 bar...", "*blah blah*", and that is ABSOLUTELY WRONG!
It is correct that the pressure is ALWAYS in the range of 42-60 bar, with occasional overshoots. It can be temporarily requested to be different by the relevant authority (GeStG) if needed, and it is ALWAYS charged up to 60 bar, as there is a pressure accumulator present.
icon_arrow.gif Ultimately, for error analysis, the decisive factor is the maximum pressure achieved (TARGET: 60 bar! and nothing else!!), how long it takes for the minimum pressure to be reached after the pump is switched off (approximately 20-30 seconds, depending on the switching and coupling requirements), and finally, that the pump is only activated for very short periods.
The longer this hydraulic pump has to run under pressure, the greater the problem becomes in the DSG (Dual Clutch System).
As a reference, please find the relevant log in the attachment. If I had known this information earlier, ... exactly icon_smile_thumb_up.gif.
And finally, a heartfelt thank you to our QuotenÖsi LiZ, who was absolutely right with his prediction! (I can't give more than one thumbs up, sorry icon_cool.gif).
Why VAG chose to implement "game protection" despite the existing and quite extensive error messages remains a mystery, but that's okay...
"Spielschutz" is described in English-speaking VAG forums as "play protection," for example, referring to the constant raising and lowering of windows, which acts as an "overload protection" (due to user error and/or improper use)!
That's why I was so disoriented and unsure at the beginning, reading something like that in the Data Protection Act.
Many thanks again to everyone icon_exclaim.gif.
Should anything significantly new happen, I will post more details here again icon_wink.gif.
EDIT: SW-T-No., SW-Version, Log.
LOG-02-138-307-31B.CSV
 File name:  LOG-02-138-307-31B.CSV
 File size:  214.84 KB
 Downloaded:  516 times
Translated on 09-09-2026, 11:22.
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. DSG Problems Passat CC - Solved On-Board Diagnostics (OBD)
No new posts LWR Error: Unrecoverable Memory Corruption (Solved) On-Board Diagnostics (OBD)
No new posts Skoda Octavia ABS Fault Transmission, Chassis, Body & Interior
No new posts Skoda Fabia Steering Assist Error On-Board Diagnostics (OBD)
