VCDS 16.8.0: Channels Unavailable After Update
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
thorsten1965
Post05-09-2016, 18:04    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
Has anyone updated their VCDS to version 16.8.0 and then tried adjusting various channels in the central electronics module (control unit 09) of a Golf 7R or Seat Leon Cupra (5F)?
"In version 15.7.4, I was able to adjust channel 24 in control unit 09 on a Seat Leon Cupra (5F). However, with version 16.8.0, channel 24 is no longer selectable via direct input. There is a channel in the dropdown menu with an equivalent description (now suddenly called "ENG10563-ENG11665-Mirror Adjustment,..."), but that channel is not available."
Unfortunately, there was also a firmware update for my USB KKL+CAN interface, which I accepted after some initial failed attempts with version 16.8.0. However, this means that the interface is no longer compatible with version 15.7.4. A downgrade of the firmware is not possible (and there is a corresponding warning message).
I have also tried reinstalling version 16.8.0 and installing the English version, but nothing has worked.
Therefore, my diagnostic software is currently very limited in its functionality.
I would appreciate any advice on how to get out of this difficult situation.
Translated on 02-08-2026, 3:58.
Post05-09-2016, 18:29    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
All German versions of VCDS have been exclusively available directly from Ross-Tech for some time now (the differences are limited to links and addresses). Distributors are no longer able to make their own modifications, so developing custom tests is hardly worthwhile.
That's why we have created separate configurations for all the programs that we provide in addition to the main software (KPower, KDataScope).
To allow us to better understand your issue and provide relevant background information about the vehicle when emailing Ross-Tech, please perform a scan of the vehicle(s).
Translated on 02-08-2026, 4:01.
thorsten1965
Post09-09-2016, 13:03    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
Hello Rainer,
I don't want to make the files available here on the forum. I am not allowed to send you a private message (I haven't made enough posts yet). My email to the webmaster remains unanswered (it is probably not being monitored). An email sent through the contact page (which unfortunately doesn't allow file attachments) has also been ignored so far.
How can I provide you with the files (scan, log of changes in the old VCDS, Screenshot of the new designation, and errors in the new VCDS)?
"Best regards, Thorsten"
Translated on 02-08-2026, 4:02.
Post10-09-2016, 20:36    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
Your email has arrived, but I was out yesterday and today. It's the weekend.
Ross-Tech has now released version 16.8.1; please test this version for your issue. You can download it from your customer account as usual.
Translated on 02-08-2026, 4:03.
thorsten1965
Post11-09-2016, 12:42    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
Hello Rainer,
The same problem with version 16.8.1.
I'm sending a new car scan and a Screenshot via email.
Translated on 02-08-2026, 4:04.
Post11-09-2016, 15:00    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
Ross-Tech has been contacted; let's see what they say.
Translated on 02-08-2026, 4:05.
Post15-09-2016, 9:19    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
This will be fixed in VCDS 16.8.2 - we'll publish the updated version as
As soon as possible.
thorsten1965
Post04-11-2016, 13:03    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
With the new version 16.8.2, at least the channel settings are working again. However, it is still not possible to directly select channels by entering the channel number in the designated field, as the labels have completely changed and continue to change. This forces users to find the channels through the brief description in the dropdown menu. Even entering the new channel number in the field does not bring up the corresponding channel.
Translated on 02-08-2026, 4:06.
Post04-11-2016, 13:05    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
thorsten1965
dieselschrauber likes this.
Post20-11-2016, 19:36    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
It has been tested under version 16.8.3 and remains unchanged. The setting is possible, but due to the changed names, the channels can no longer be selected by entering them in the search field.
text
Product Information
Product: Ross-Tech VCDS Version 16.8.3.3 / Software Version DS267.0 / Date: 20161018
Installer Version: 3.2.6.233 compiled with NSIS v3.0.
Installation Directory: C:\Ross-Tech\VCDS-DRV
Installation Date/Time: 2016-10-21 @ 22:17:43 (UTC)
Old name (Channel 24):
Address 09:5Q0 937 084 recoded (ADP-(24)-Access Control 2-Radio Retractable Mirror Mode) from "convenience operation via remote control key" to "look command via remote control key".
New name:
Address 09,5Q0 937 084 AS, Adaptation Channel IDE08542-ENG116665, Access Control 2, Folding Mirror Mode, changed from "look command via remote control key" to "convenience operation via remote control key", Saturday, October 22, 2016, 20:12:12:32392.
Translated on 02-08-2026, 4:08.
Post20-11-2016, 19:48    Subject: VCDS 16.8.0: Channels Unavailable After Update Quote
Thank you for your feedback!
Translated on 02-08-2026, 4:10.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku 1J diverse MKB, Diverse MSG Fehlercodes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interface HEX+CAN is no longer unlocked after MFT update. On-Board Diagnostics (OBD)
No new posts 2,5TDI // AFB/AKN // Ersatzteil nicht verfügbar Diesel Engine Technology
No new posts Messwertblöcke beim Polo 6r nicht verfügbar On-Board Diagnostics (OBD)
No new posts Start/Stop is unavailable, what does the measurement bloc... On-Board Diagnostics (OBD)
