EPB Passat 3C error
Go to page: 1, 2  Next
pfaelzer02
2006 Volkswagen Passat
Post20-11-2016, 13:55    Subject: EPB Passat 3C error Quote
Hello everyone,
I have the following problem, and I hope you can help me?
The yellow and red warning lights are illuminated on the instrument cluster. If the EPB button is pressed and held, the red light will begin to blink for the duration of the press. Autoscan file below.
"After the motor seized, I replaced both of them. Subsequently, I also replaced the button from the dealer and the control unit. I also replaced both connectors. The errors still persist." Fuses all replaced.
Follow the RossTech Wiki instructions for adaptation. However, the last step: "Coding the control unit for the parking brake is not working." Does this require setting up access permissions first? Has the power supply to the control unit somehow been deactivated and needs to be reactivated? I'm at a loss...
Christian
Autoscan:
Code:
Sonntag,20,November,2016,13:38:53:64577
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: RKS 16.8.3.3
Datenstand: 20161025 DS267.0
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ6P151260 KFZ-Kennzeichen:
Kilometerstand: 206890km Reparaturauftrag:
Fahrzeugtyp: 3C (3C0)
Scan: 01 02 03 08 09 13 15 16 17 18 19 22 25 37 42 44 46 47 52 53
55 56 5D 62 65 72 76 77
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ6P151260 Kilometerstand: 206890km
00-Lenkwinkelsensor -- Status: i.O. 0000
01-Motorelektronik -- Status: Fehler 0010
02-Getriebe -- Status: i.O. 0000
13-Distanzregelung -- Status: Fehler 0010
18-Standheizung -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
53-Feststellbremse -- Status: Fehler 0010
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
5D-Bedieneinheit -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
65-Reifendruck -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
76-Einparkhilfe -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Adresse 01: Motorelektronik Labeldatei: 03H-906-032-BLV.clb
Teilenummer SW: 03H 997 033 K HW: Hardware No
Bauteil: P3.2 FSI-EU4 A00 2368
Revision: --H08--- Seriennummer: VWZCZ000000000
Codierung: 0000175
Betriebsnr.: WSC 42706 126 53954
VCID: 354E7A255CBD37EA21-8060
1 Fehler gefunden:
005717 - Bitte Fehlerspeicher des ADR-Steuergerät auslesen
P1655 - 004 -
Umgebungsbedingungen:
Fehlerstatus: 01100100
Fehlerpriorität: 0
Fehlerhäufigkeit: 1
Verlernzähler: 255
Kilometerstand: 206896 km
Zeitangabe: 0
Datum: 2016.11.19
Zeit: 00:25:16
Drehzahl: 627 /min
Last: 19.6 %
Geschwindigkeit: 0.0 km/h
Temperatur: 75.0°C
Temperatur: 20.0°C
Druck: 950.0 mbar
Spannung: 14.097 V
Readiness: 0110 0001
Adresse 02: Getriebe Labeldatei: DRV\02E-927-770.clb
Teilenummer SW: 02E 300 047 J HW: 02E 927 770 AE
Bauteil: GSG DSG 070 1112
Revision: 04507000 Seriennummer: 00000511291104
Codierung: 0000020
Betriebsnr.: WSC 00028 028 00001
VCID: 1F62B88DCE419DBADB-804A
Adresse 03: Bremsenelektronik Labeldatei: DRV\3C0-614-095-C2.clb
Teilenummer SW: 3C0 614 095 R HW: 3C0 614 095 R
Bauteil: ESP 440 C2 H015 0003
Revision: H015 Seriennummer: 0100000643
Codierung: 0046535
VCID: 31464E35A8D51BCA7D-8064
Adresse 08: Klima-/Heizungsel. Labeldatei: DRV\3C0-907-044.lbl
Teilenummer SW: 3C0 907 044 S HW: 3C0 907 044 S
Bauteil: ClimatronicPQ46 050 0404
Revision: 00050005 Seriennummer: 00000000000000
Adresse 09: Zentralelektrik Labeldatei: DRV\3C0-937-049-23-H.lbl
Teilenummer SW: 3C0 937 049 L HW: 3C0 937 049 L
Bauteil: Bordnetz-SG H37 1301
Revision: 00H37000 Seriennummer: 00000003685427
Codierung: E7868F0701041A00000A00000F000000000F5D435C0000
VCID: 32444139ADD320D204-8066
Subsystem 1 - Teilenummer: 3C1 955 119 Labeldatei: DRV\1KX-955-119.CLB
Bauteil: Wischer VW461 012 0503
Codierung: 00063445
Subsystem 2 - Teilenummer: 1K0 955 559 AF Labeldatei: DRV\1K0-955-559-AF.CLB
Bauteil: RLS 201207 046 0204
Codierung: 00208933
Adresse 13: Distanzregelung Labeldatei: DRV\3C0-907-567.clb
Teilenummer SW: 3C0 907 567 J HW: 3C0 907 567 J
Bauteil: AC201 RDW M 031 0232
Revision: 00031000 Seriennummer: 00000000024649
Codierung: 0010100
Betriebsnr.: WSC 17301 666 74123
4 Fehlercodes gefunden:
01314 - Motorsteuergerät
013 - bitte Fehlerspeicher auslesen
Fehlerstatus: 01101101
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 118
Zeitangabe: 0
Datum: 2016.11.19
Zeit: 00:28:58
Anzahl: 4
004 - kein Signal/Kommunikation
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 118
Zeitangabe: 0
Datum: 2016.11.19
Zeit: 00:28:58
Anzahl: 4
00473 - Steuergerät für elektrische Park-/Handbremse (J540)
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 118
Zeitangabe: 0
Datum: 2016.11.19
Zeit: 00:28:58
Anzahl: 12
02085 - falsches Steuergerät verbaut
005 - keine oder falsche Grundeinstellung/Adaption
Fehlerstatus: 01100101
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 118
Zeitangabe: 0
Datum: 2016.11.19
Zeit: 00:28:58
Anzahl: 30
Adresse 15: Airbag Labeldatei: DRV\3C0-909-605.lbl
Teilenummer SW: 3C0 909 605 K HW: 3C0 909 605 K
Bauteil: 10 AIRBAG VW8R 029 2521
Revision: 10029000 Seriennummer: 003A3PSCVS1C
Codierung: 0012592
VCID: 2E7C5549B9EB043260-807A
Subsystem 1 - Seriennummer: 6332MSME0D693D23K
Subsystem 2 - Seriennummer: 6342MSME0E3E7D2F/
Subsystem 3 - Seriennummer: 6351HTS63IKQL7G2-
Subsystem 4 - Seriennummer: 6361HTS63IKML9U26
Subsystem 5 - Seriennummer: 00000000000000000
Subsystem 6 - Seriennummer: 00000000000000000
Adresse 16: Lenkradelektronik Labeldatei: DRV\3C0-953-549-SW20.lbl
Teilenummer SW: 3C0 953 549 E HW: 3C0 953 549 E
Bauteil: J0527 0015
Revision: 00005000 Seriennummer: 3C5953507Q
Codierung: 0001321
Subsystem 1 - Teilenummer: XXXXXXXXXXX
Bauteil: E0221 007 0050
Adresse 17: Schalttafeleinsatz Labeldatei: DRV\3C0-920-xxx-17.lbl
Teilenummer SW: 3C0 920 870 P HW: 3C0 920 870 P
Bauteil: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Seriennummer: 00000000000000
Codierung: 0007105
Betriebsnr.: WSC 22282 123 92739
VCID: 30404B31A3DF12C272-8064
Adresse 18: Standheizung Labeldatei: DRV\1K0-815-007.clb
Teilenummer: 1K0 815 007 AT
Bauteil: Standheizer 020 3602
Revision: 00020000 Seriennummer: 09011559000000
Codierung: 0001112
Betriebsnr.: WSC 11111 111 11111
VCID: 76CCBD29013B7CF2E8-8022
Adresse 19: Diagnoseinterface Labeldatei: DRV\3C0-907-530-V1.clb
Teilenummer SW: 3C0 907 530 B HW: 3C0 907 951
Bauteil: Gateway 007 0040
Revision: 00007000 Seriennummer: 1200A057280020
Codierung: FFFF1E54EE1002
Betriebsnr.: WSC 47236 123 93462
VCID: 2060BB71F33FA242E2-8074
Adresse 22: Allrad Labeldatei: DRV\1K0-907-554.lbl
Teilenummer: 1K0 907 554 C
Bauteil: HALDEX 4Motion 0108
Codierung: 0000001
VCID: 2D7E5245B4ED7F2A59-8078
Adresse 25: Wegfahrsperre Labeldatei: DRV\3C0-959-433-25.clb
Teilenummer SW: 3C0 959 433 P HW: 3C0 959 433 P
Bauteil: IMMO 043 0364
Revision: 00043000 Seriennummer: VWZCZ000000000
Betriebsnr.: WSC 131071 1023 2097151
VCID: 3752702D46B1C5FA33-8062
Subsystem 1 - Teilenummer: 3C0 905 861 D
Bauteil: ELV 024 0370
3C0905861D ELV 024 0370
Adresse 37: Navigation Labeldatei: DRV\1K0-919-887-MFD2.lbl
Teilenummer: 1K0 919 887 F
Bauteil: Navigation 0028
Codierung: 0000101
VCID: 3C586F017F97E6A2DE-8068
Adresse 42: Türelektr. Fahrer Labeldatei: DRV\1K0-959-701-MAX2.lbl
Teilenummer: 1K0 959 701 L
Bauteil: Tuer-SG 024 2461
Codierung: 0000247
Adresse 44: Lenkhilfe Labeldatei: DRV\1Kx-909-14x-44.clb
Teilenummer: 1K1 909 144 K
Bauteil: EPS_ZFLS Kl.5 D06 1701
VCID: 334A443D52C929DA0F-8066
Adresse 46: Komfortsystem Labeldatei: DRV\3C0-959-433-46.clb
Bauteil: KSG PQ46 RDK 043 0213
Codierung: 18910A0801860E763804951570084FCE701900
Subsystem 1 - Teilenummer: 1K0 951 605 C
Bauteil: LIN BACKUP HORN H03 1301
Subsystem 2 - Teilenummer: 3C0 951 171 A
Bauteil: Neigungssensor 002 0508
Subsystem 3 - Teilenummer: 3C0 951 171 A
Bauteil: Innenraumueberw.002 0508
Adresse 47: Soundsystem Labeldatei: DRV\3C0-035-456.lbl
Teilenummer SW: 3C0 035 456 C HW: 3C0 035 456 C
Bauteil: DSP 10 Kanal 0012
Revision: 00009000 Seriennummer: 00000000001879
Adresse 52: Türelektr. Beifahr. Labeldatei: DRV\1K0-959-702-MAX2.lbl
Teilenummer: 1K0 959 702 L
Codierung: 0000246
VCID: 385073114BAFCA823A-806C
Adresse 53: Feststellbremse Labeldatei: DRV\3C0-907-801-53.clb
Teilenummer SW: 3C0 907 801 B HW: 3C0 907 801 B
Bauteil: EPB VC8HC001 013 0001
Revision: 013
Codierung: 0000012
Betriebsnr.: WSC 00516 210 87495
VCID: 2166BE75F835AB4AED-8074
02432 - Feststellmotor links Spannungsversorgung (V282)
011 - Unterbrechung - Warnleuchte EIN
Fehlerstatus: 11101011
Fehlerpriorität: 1
Fehlerhäufigkeit: 45
Verlernzähler: 109
Kilometerstand: 205928 km
Zeitangabe: 0
Datum: 2016.11.05
Zeit: 00:01:28
Spannung: 11.28 V
Anzahl: 116
02443 - Bedienungsteil
012 - elektrischer Fehler im Stromkreis - Warnleuchte EIN
Fehlerstatus: 11101100
Fehlerpriorität: 2
Fehlerhäufigkeit: 35
Verlernzähler: 111
Kilometerstand: 206424 km
Zeitangabe: 0
Datum: 2016.11.10
Zeit: 18:45:53
Spannung: 11.59 V
Anzahl: 44
02433 - Feststellmotor rechts Spannungsversorgung (V283)
Fehlerstatus: 11111011
Fehlerpriorität: 1
Fehlerhäufigkeit: 40
Verlernzähler: 109
Zeitangabe: 0
Datum: 2016.11.05
Zeit: 00:01:28
Spannung: 11.28 V
Anzahl: 117
01087 - Grundeinstellung nicht durchgeführt
000 - - - Warnleuchte EIN
Fehlerstatus: 11100000
Fehlerpriorität: 4
Fehlerhäufigkeit: 46
Verlernzähler: 109
Zeitangabe: 0
Datum: 2016.11.05
Zeit: 00:11:44
Spannung: 13.56 V
Anzahl: 170
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\5M0-907-357-V1.lbl
Teilenummer SW: 5M0 907 357 HW: 5M0 907 357
Bauteil: AFS-Steuergeraet X016
Revision: H09 Seriennummer:
Codierung: 0000001
VCID: 71C68E3568555BCA3D-8024
Subsystem 1 - Teilenummer: 7L6 941 329 Labeldatei: 3D0-941-329.CLB
Bauteil: AFS-Lst.-Modul l X017
Codierung: 00000035
Subsystem 2 - Teilenummer: 7L6 941 330
Bauteil: AFS-Lst.-Modul r X018
Codierung: 00000035
Adresse 56: Radio Labeldatei: DRV\1K0-035-095.lbl
Teilenummer: 1K0 035 095 E
Bauteil: Radio 0028
Codierung: 0012072
VCID: 2772A06D9611557AA3-8072
Adresse 5D: Bedieneinheit Labeldatei: DRV\3C0-035-151.lbl
Teilenummer SW: 3C0 035 151 B HW: 3C0 035 151 B
Bauteil: J738 010 0018
Revision: 00010000
VCID: 171290AD2671E5FA13-8042
Adresse 62: Türelektr. hi. li. Labeldatei: DRV\1K0-959-703-GEN2.lbl
Teilenummer: 1K0 959 703 F
Bauteil: Tuer-SG 021 2432
Codierung: 0000144
Adresse 65: Reifendruck Labeldatei: 3C0-959-433-65.lbl
Bauteil: RDK 0391
Codierung: 0161211
Adresse 72: Türelektr. hi. re. Labeldatei: DRV\1K0-959-704-GEN2.lbl
Teilenummer: 1K0 959 704 F
Codierung: 0000144
VCID: 3448472157C72EE216-8060
Adresse 76: Einparkhilfe Labeldatei: DRV\3C0-919-283.lbl
Teilenummer SW: 3C0 919 283 B HW: 3C0 919 283 B
Bauteil: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Seriennummer: 82930534405880
Codierung: 0001014
VCID: 2870A3519B0F5A02AA-807C
Adresse 77: Telefon Labeldatei: DRV\3C0-035-730.lbl
Teilenummer SW: 3C0 035 730 HW: 3C0 035 730
Bauteil: Telefon 5009
Revision: 00008000 Seriennummer: 0000000003175
Codierung: 0010055
VCID: 5890D391EBEF2A82DA-800C
Ende----------------------------(Dauer: 02:05)-----------------------------
Post20-11-2016, 17:14    Subject: EPB Passat 3C error Quote
Perhaps the motors of the parking brake weren't actually defective.
Address 53: Parking brake Label file: DRV\3C0-907-801-53.clb
Part number SW: 3C0 907 801 B, hardware number: 3C0 907 801 B.
Part number: EPB VC8HC001 013 0001
Revision: 013
Encoding: 0000012
Operating number: WSC 00516 210 87495
4 error codes found:
02432 - Left-hand fixed motor, voltage supply (V282)
011 - Interruption - Warning light ON.
Environmental conditions:
Error status: 11101011
Error priority: 1.
Error frequency: 45.
Lost Count: 109
Mileage: 205928 km
Time: 0.
Date: 2016.11.05
Time: 00:01:28
Voltage: 11.28 V
Quantity: 116
02443 - Control panel.
012 - Electrical fault in the circuit - Warning light ON.
Error status: 11101100
Error priority: 2
Error frequency: 35.
Lost counter: 111
Mileage: 206,424 km
Time: 0.
Date: 2016.11.10
Time: 18:45:53
Voltage: 11.59 V
Quantity: 44
02433 - Right-hand locking motor, voltage supply (V283)
Error status: 11111011
Error priority: 1.
Error frequency: 40.
Lost Count: 109
Mileage: 205928 km
Time: 0.
Date: 2016.11.05
Time: 00:01:28
Voltage: 11.28 V
Quantity: 117
01087 - Initial calibration not performed.
000 - - - Warning light ON.
Error status: 11100000
Error priority: 4.
Error frequency: 46
Lost Count: 109
Mileage: 205928 km
Time: 0.
Date: 2016.11.05
Time: 00:11:44
Voltage: 13.56 V
Quantity: 170
If the errors cannot be deleted, you still have a defect in the circuit. Okay, I understand. Please provide the German text you want me to translate into English. I will focus on providing an accurate translation without any explanations.
Then, you check to see if "error in the circuit" or something similar reappears.
If applicable: Check the cables, connectors, and fuses, including the fuse box.
If no: Perform a functional test/function test of the parking brake.
Karma: +647 / -0   Thank you, like it!
Post06-04-2017, 14:24    Subject: Different car, same problem Quote
Hi.
Okay, here's the translation:
"Just chiming in here, this is about a friend's 2006 Passat Variant 3C, here's a brief history:"
Last fall, his parking brake suddenly seized. The cause was a leaking brake caliper, from which brake fluid had leaked into the actuator motor. As a result, the leaking brake caliper and both actuator motors were replaced.
"Sometimes the EPB warning light would come on, and the brake wouldn't always release. He would then briefly disconnect the battery, and it would work again. At that time, I didn't have VCDS, so he took it to an independent garage, which read the error codes and told him that the button was broken."
He then bought a cheap new one on eBay and installed it, but there was no change, so it remained like that until last week when he came to me. He hasn't used the parking brake since then.
I then ran a diagnostic scan, and the following message appeared:
012 - electrical fault in the circuit - warning light ON
I then got a brand new button from VW, but there was no change; the parking brake remains inactive, and there's no reaction when you press the button.
I then checked the corresponding field in the extended measurement data, and it showed "error" in relation to that button.
I still have the car here. What would be the most sensible way to proceed?
Thank you, Rüdi.
Post06-04-2017, 17:17    Subject: EPB Passat 3C error Quote
I still have the car here, what would be the most sensible way to proceed?
Check the wiring/power supply between the button and the EPB control unit.
Karma: +1354 / -0   Thank you, like it!
Post06-04-2017, 18:50    Subject: EPB Passat 3C error Quote
It may be necessary to perform a basic adjustment of the parking brake.
I don't have the specific instructions for the Passat, but in principle, it should work like this:
- Brake released;
- Ignition on;
- Clear errors in the ECU (Engine Control Unit);
- Select the "basic setting" function (in my case, this is function 006, but it may be different on other models and can be accessed via the actuator diagnosis).
- Perform initial setup.
Post06-04-2017, 19:00    Subject: EPB Passat 3C error Quote
The problem is that the error cannot be deleted; it's also dated back to October 2016, which is when the issues started.
What I've also noticed is that when the key is removed and I press the button, it lights up, as does the red indicator light on the instrument cluster.
chli1976
Post07-04-2017, 16:36    Subject: EPB Passat 3C error Quote
Try this:
• Turn off the ignition.
• Disconnect the battery.
• Wait at least 5 minutes before reconnecting the battery.
• Turn on the ignition.
• While pressing the brake pedal, press the switch twice (ON-OFF).
Tip:
Wait 30 seconds between each activation of the EPB switch to allow the parking brake to respond.
Once EPB cycling is complete: Read and clear fault memory.
After that, perform the basic adjustments in the correct order.
VCDS
Post08-04-2017, 5:10    Subject: EPB Passat 3C error Quote
Tried several times yesterday, no change.
I'm getting the wiring diagrams today, and my friend is going to remove the center console so we can start troubleshooting.
dieselschrauber likes this.
Post19-04-2017, 12:11    Subject: EPB Passat 3C error Quote
Problem found: The connector from the EPB (Electronic Parking Brake) control unit was disconnected, and it was leaking oil. Two contacts were corroded, so we cleaned them as much as possible using a fiberglass pen, removed all the oil, and then sprayed the entire connector with contact cleaner. The brake is now working as it should.
I don't understand the issue with the oil. Are there also problems here, like with Daimler, where oil is drawn into the wiring harnesses via capillary action?
Post19-04-2017, 12:24    Subject: EPB Passat 3C error Quote
Thank you for your feedback! I haven't heard about that in relation to this topic before...
Post27-04-2017, 6:45    Subject: EPB Passat 3C error Quote
Update: The error has reappeared. We are now sourcing a different EPB control unit and a complete connector from a salvage yard.
Does anyone know where to get those small crimp connectors in the open market? VW apparently charges €14 for one with a 20cm wire attached icon_sad.gif.
Post27-04-2017, 7:30    Subject: EPB Passat 3C error Quote
Could it be possible that what's inside the plug isn't oil, but rather electrolyte from ruptured capacitors?
Or, if it was actually oil, it's probably also in the engine control unit (ECU). Just take a look inside, if possible.
Post27-04-2017, 7:39    Subject: EPB Passat 3C error Quote
"It seems like a lot of oil leaked out, and it couldn't possibly all be from just a few condenser cores. The control unit seems to be intact, but there's a contact problem. When I wiggle the connector, the warning lights suddenly go out."
Unfortunately, opening the control unit is currently not possible because it uses a type of Torx screw with 5 sides instead of the usual 6.
Styrian
Post27-04-2017, 16:49    Subject: EPB Passat 3C error Quote
"...so, a Torx Plus security bit should be somehow organized." It's probably cheaper than a new control unit...
Greetings, Styrian.
Post02-05-2017, 13:36    Subject: EPB Passat 3C error Quote
The control unit is on its way. It cost 30 euros, and the connector cost 10 euros. I'll let you know when there's more news.
Post19-05-2017, 6:52    Subject: Conclusion Quote
Hi.
The day before yesterday, we removed the "bad" pins from the connector housing and replaced them with pins from an eBay connector. One of them was completely corroded and likely caused all the problems. There was also corrosion on the copper wire inside, so we had to cut back quite a bit until we had clean copper.
Then I connected the replacement control unit, connected it to the battery, and turned on the ignition. This resulted in a flurry of warning lights on the instrument cluster: MSG, EPB, ABS, ESP, steering... The main cause was that the ABS/ESP control unit had lost its coding, for reasons unknown. I then took the coding from the last diagnostic report and, one by one, programmed each control unit until the lights eventually went out.
"But it was only temporary, then the "parking brake error" message reappeared. The diagnostic tool also showed a problem with the auto-hold system and a short circuit. I quickly disabled the auto-hold function so that we could go to the vehicle inspection (TÜV) on Monday without any worries, as it was already due in January 2017."
Best regards, Rüdi.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat 1.9 TDI: Error Codes G70, G81, G62 Diesel Engine Technology
No new posts Passat ABS/ESP Error: 2002 Model Troubleshooting On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. DSG Problems Passat CC - Solved On-Board Diagnostics (OBD)
No new posts Passat B4 1.9 TDI: Error 00546 Troubleshooting On-Board Diagnostics (OBD)
