vag-driver Profi-Schrauber
05-12-2019, 9:11 Subject: Sharan 7N crack in the body panel |
"Recently, I've noticed a clicking sound coming from the front drivetrain when driving at a slow speed in the following situations:"
1. When turning the steering wheel sharply without changing gears, for example, when maneuvering while parking.
2. When shifting between gears D and R, and also when turning the steering wheel sharply.
It sounds like a noise made when metal is relaxing.
Where can I start looking here? The situation is not currently 100% reproducible. Viele Grüße
Andreas
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
05-12-2019, 19:17 Subject: Sharan 7N crack in the body panel |
Hi.
Is the dome light stuck?
Profile PM WWW Garage |
06-12-2019, 9:25 Subject: Sharan 7N crack in the body panel |
I had the Sharan on the lift yesterday, and I couldn't find anything that could be causing the cracking noise. The wheels turn smoothly.
I replaced the stabilizer bars with Meyle HD ones this summer. They are noticeably stiffer and less flexible. Could it be that this creates more tension? Viele Grüße
Andreas
06-12-2019, 11:48 Subject: Sharan 7N crack in the body panel |
Are the strut mounts under stress when the wheels are not in contact with the ground?
06-12-2019, 12:01 Subject: Sharan 7N crack in the body panel |
They are under pressure. But by tension, not by pressure. Viele Grüße
Andreas
06-12-2019, 15:28 Subject: Sharan 7N crack in the body panel |
Translating... |
[Translating...]  |
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2560 Karma: +590 / -0 Location: bei Zwickau
dieselschrauber, Rüdi and Herbert likes this. |
06-12-2019, 18:07 Subject: Sharan 7N crack in the body panel |
Hi!
When I encountered such problems, I used the diagnostic tools in a pit.
The car will then be in the same conditions as it would be on the road.
My father, despite his age, is a careful and clever person who, when in a car, can drive forward, backward, steer, and even engage the handbrake.
Only that person is not allowed to drive into the pit.
I then got down on the ground under the car and tried to listen for any cracking sounds.
Then I manually examined the suspicious parts.
I have always had a very good success rate with this method.
In the described case, I would also check if the strut mounts are stiff or difficult to move under load, and if the springs are broken.
I would also generally view dome supports with a critical eye. Hopefully, you've installed it correctly. Grüße, Steffen!
11-12-2019, 9:03 Subject: Sharan 7N crack in the body panel |
Steffen G wrote: |
I would also generally view dome supports with a critical eye. Hopefully, you have it properly installed. |
I didn't do anything at the storage facility. I replaced the support brackets (the ones that connect the lower control arm to the chassis).
The feathers are not broken. I have already checked them. Since I don't have a pit available, it will be difficult to test it under load.
Interestingly, I'm not experiencing that cracking sound right now. Perhaps it's temperature-dependent. Viele Grüße
Andreas
