Audi A3 CRB: Hot News & Updates
georgmech
Post04-10-2016, 12:04    Subject: Audi A3 CRB: Hot News & Updates Quote
Hello, we have an AUDI A3 with a 2.0L engine (110kW CRB) that occasionally overheats, reaching 120 degrees Celsius before returning to normal. It then runs normally for a while before the problem repeats. The coolant thermostat has already been replaced.
Does anyone have any ideas?
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 26-07-2026, 20:32.
Back to top Profile PM Email
Post04-10-2016, 12:15    Subject: Audi A3 CRB: Hot News & Updates Quote
Hello Georg,
In some water pumps, it has happened that the impeller detached from the shaft. In such cases, the pump may spin freely, but very little or no water is actually being pumped.
Translated on 26-07-2026, 20:33.
Post04-10-2016, 12:16    Subject: Audi A3 CRB: Hot News & Updates Quote
Water pump (with loose impeller) or cylinder head gasket.
Is there a certain pattern or system to it, so that you can, for example, trigger it by driving at full throttle on the highway?
georgmech
Post05-10-2016, 11:34    Subject: Best German Shepherd Breeders: Find Yours Now! Quote
Thank you both. I'm ruling out a leak in the head gasket because there's absolutely no water consumption. However, a water pump could be the issue, but I find it hard to believe that we're still having the same problems as we did back in the 90s – have they really learned nothing? I'll replace the water pump next. Our mechanic actually has one in stock, so there must be a reason for that.
Translated on 26-07-2026, 20:34.
georgmech
dieselschrauber likes this.
Post13-08-2018, 11:18    Subject: Water Wheel: History, Types & Working Principle Quote
Unfortunately, this is very late, but I'm not exactly an internet expert. The problem was with the water pump, specifically a sliding sleeve located above the impeller. This sleeve is controlled by a valve and water pressure, and it moves backward to open the circuit. However, this sliding sleeve got stuck.
Translated on 26-07-2026, 20:35.
vag-driver
Post13-08-2018, 13:00    Subject: Water Pump Wheel: Types & Applications Quote
georgmech wrote:
This sliding sleeve is stuck.
There are constructions where it is already clear what must come next icon_rolleyes.gif.
Andreas
Translated on 26-07-2026, 20:36.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 4B V6 TDI: Overheating Issues? Diesel Engine Technology
No new posts VW Touran Rear Brakes Overheating - Fix! Transmission, Chassis, Body & Interior
No new posts AGR valve not being activated, Audi A2 1.2 TDI EDC15 Diesel Engine Technology
No new posts got hot Diesel Engine Technology
