Audi RS6: Airbag Coding After Steering Wheel Install
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
klg
Post21-09-2018, 21:23    Subject: Audi RS6: Airbag Coding After Steering Wheel Install Quote
I retrofitted an airbag switch for the passenger seat on my RS6 (4F) so that I can install a child seat there. Now, I want to use VCDS to reprogram the airbag control unit so that it recognizes the switch and I can use it. However, in VCDS, I only see the existing code; no new code is automatically suggested. There is a mask to enter a new code, but I have no idea how to find the new code. I would be grateful for any help! Unfortunately, I am not an expert icon_redface.gif.
Translated on 18-08-2026, 22:28.
Karma: +647 / -0   Thank you, like it!
Post22-09-2018, 7:22    Subject: Audi RS6: Airbag Coding After Steering Wheel Install Quote
Did you also retrofit the "Passenger Off" airbag warning light?
dieselschrauber likes this.
Post22-09-2018, 8:54    Subject: Audi RS6: Airbag Coding After Steering Wheel Install Quote
Here's the continuation:
https://erwin.audi.com/erwin/showArticleProperties.do?articleId=48789
(Installation instructions for retrofitting a key switch to deactivate the passenger airbag).
VCDS will not provide you with coding suggestions; instead, it provides the function and status for individual coding points.
The specific details of what needs to be changed may be found in the relevant technical documentation (RLF) or possibly in a test procedure instruction (TPI).
And since you're dealing with the airbag system, be careful about using unauthorized information from the internet.
Translated on 18-08-2026, 22:29.
klg
Post24-09-2018, 13:56    Subject: Audi RS6: Airbag Coding After Steering Wheel Install Quote
Rüdi wrote:
Did you also retrofit the airbag light that says "Passenger Off"?
This one already works (see picture). Or do you mean a different light fixture? [/img]
 File size:  3.31 MB
 Viewed:  397 times
Translated on 18-08-2026, 22:31.
klg
Post24-09-2018, 15:54    Subject: Audi RS6: Airbag Coding After Steering Wheel Install Quote
Herbert wrote:
Here it continues:
VCDS will not provide you with coding suggestions; instead, it provides the function and status for individual coding locations.
Thank you for the link! I don't have access to it yet (it seems like you need to purchase it). Would I be able to get the correct code if I did? Because most of the mount assembly has already been completed; all that's left is the re-encoding.
I found another setting in VCDS (so that you might not need to reprogram, see the photo), but I'm not sure if it's the correct one. I assume that in this case, I would simply select "key switch installed"? I don't understand what "not parameterized" means or when it is used.
 File size:  3.7 MB
 Viewed:  278 times
Translated on 18-08-2026, 22:32.
Herbert likes this.
Post24-09-2018, 17:24    Subject: Audi RS6: Airbag Coding After Steering Wheel Install Quote
Modifications that affect safety are made at your own risk; it's unlikely that anyone here will approve of such changes.
You need to figure things out for yourself.
Translated on 18-08-2026, 22:34.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi S5 8T, 4.2L Manual Transmission, ACC Coding On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Airbag Coding Audi B6 8E 2.5 TDI On-Board Diagnostics (OBD)
No new posts Audi A4 Airbag: Rear Crash Sensor Ohms Value On-Board Diagnostics (OBD)
No new posts Airbag Warning: Seat Adjustment Issues Transmission, Chassis, Body & Interior
